nickvolvo746
- Nov 13, 2017
- New Jersey
1990 760 T b230ft lh2.4
Hey yall, sorry ive been posting so much, you guys have been super helpful and I very much appreciate it. Hopefully this will be my last post for a while, I just have one question which I was hoping to get opinions on before my dumbass tries to do it later today. I traced down my current problems (no pun intended) and think I have more or less figured out the electrical gremlin and have a solution in mind.
Heres the problem and stuff Ive checked through
-spark is fine
-battery is fine
-distributor is fine
-radio suppression relay is fine
-Fuel pumps arent getting juiced up.
-Relay is 100% fine, I have two good ones and fixed the bad one by reflowing it.
-Fuses are all good.
-Grounds have been cleaned and checked.
-test lamp and ohm meter showed fuel relay not getting enough juice
- ECU is maybe fine. I have a second one I will try if my "solution" fails.
-fuse slots for fuel injection and pumps are burnt up, probably due to poor wiring or grounds.
This picture depicts what the PO did to try and fix the problem that I believe has been ongoing and that I am now dealing with today (crap wiring)
https://drive.google.com/file/d/1FXxGE1FdMqyVLqcdEfUDU4IwUSzC-gOW/view?usp=sharing
Here is my plan:
-Totally ignore the fuel relay and all its wiring
-Rig up my own wiring from both fuel pumps to my own relay, fuse and switch.
This will allow me to hop in the car, flip a switch and turn both pumps on manually. If I do it right, I will know that the wiring is good, grounds are solid and I will have a sweet switch to flip to make me feel cool. Back on the road.
I have a buddy who knows a great deal more than I do about electrical and this was mostly his suggestion. I have a relay and switch at the ready and im about to track down the wiring that comes from the pumps.
So, how dumb, how cool, how turbobricks is this idea? Obviously I will have to remember to flip the switch back off and it wont be quite as convenient as having it set up properly, but I am at the end of my wits with this whole wiring nonsense and this solution seems doable. Let me know and thank you all again for being so knowledgable and willing to lend words.
I am slowly starting to understand that having this car as a daily is more of an undertaking than my noob brain can handle, and it is time for me to buckle down and read myself silly. If anybody has a "volvos for noobs" book lying around or something similar let me know. My kingdom for knowledge.
-spark is fine
-battery is fine
Here is my plan:
