Go Back   Turbobricks Forums > General > showroom > projects & restorations
Old 06-08-2017, 08:05 AM   #76
spruill242
spruill242's Avatar
Originally Posted by kingkong View Post
It is upside down. No access to the spark plugs.
They never had good access to the spark plugs. Yours is oriented correctly you just need to trim some of the meat in the flange between the ports. Bracing is 100% a must.
'90 Spec Miata.. The barbie car I never got as a kid.....
spruill242 is offline   Reply With Quote
Old 06-09-2017, 12:37 AM   #77
Tuff240
240 Ninja
Tuff240's Avatar
You ever put a exhaust gasket on backwards? Doesn't line up with the ports. Same thing is happening with his flange being on backwards. You can't just cut the extra material off of the flange. It needs to be flipped and oriented properly.
"The Parts Counter Guy"
