Old 12-04-2017, 03:40 PM   #1
alfavs.volvo
alfavs.volvo's Avatar
Default Ebay exhaust manifold
Has anybody tried one of these?
https://www.ebay.com/i/232581199023?...D1382760564655
I am looking to +T the B230 in our 122 Lemons car. We need to mount the turbo up high to fit. This will be a low-boost setup for engine longevity (stock boost, or less) What turbo should we use? Junkyard availability is a must.
alfavs.volvo is offline   Reply With Quote
Old 12-04-2017, 03:41 PM   #2
EivlEvo
Yeah, but the flange is reversed and the manifold kind of sucks.
Old 12-04-2017, 04:13 PM   #3
alfavs.volvo
Wow, the flange is backward! Do they intend to mount the turbo facing down? I guess the flange can be cut off and re-welded, but if the rest of it sucks...
Old 12-04-2017, 04:31 PM   #4
turbotankshane
There's a handful of us using them without issue, I've got one in my s10 that's had the flange flipped, its not braced, and had 25-30psi from a t3/t4 shoved through it without issue for a while now, along with a shot of nitrous. No cracks, and it never felt like it wanted to stop pulling clear up to 6800. With a t cam.
So if it sucks, it doesn't suck quite as bad as a 90+ and a td04.
Of course, someone could make you something much better, but it's a cheap, readily available header, it is what it is and you usually get what you pay for.
turbotankshane is offline   Reply With Quote
Old 12-04-2017, 05:14 PM   #5
EivlEvo
This is a better articulation of "sucks".
Basically, it's fine. You need to cut and re-weld. If you were going to get into it all anyhow, I'd probably suggest bracing it but again... for $100... who cares? Plus then you can relive that scene from Fast & Furious 1 where his laptop says danger to manifold and then for some unknown reason all of the nuts come unthreaded and his floor comes out?
It was a very realistic film.
Old 12-04-2017, 05:23 PM   #6
Grr baby, grr
I just assumed he was going so darn fast that the floor flew off and was coincidental with the manifold danger.
Old 12-04-2017, 06:31 PM   #7
maxitoman007
I am currently running one with an adapter plate on top and a T3/T4, my hood doesn't close all the way so the hood is quite mangled on that side to make it latch...
maxitoman007 is offline   Reply With Quote
Old 12-04-2017, 07:42 PM   #8
EivlEvo
^ Nothing on your car works right haha
Old 12-04-2017, 09:19 PM   #9
maxitoman007
True! Slowly but surely. Not even surely haha
Old 12-04-2017, 10:26 PM   #10
EivlEvo
Old 12-04-2017, 10:48 PM   #11
alfavs.volvo
I went ahead and bought the ebay manifold. One of my teammates can weld stainless on his TIG, so we will reverse the flange and maybe add a brace. SO, considering we are after dependability before all out boost, do you guys think the TD04 is the way to go? They are certainly plentiful! Also, we are currently running an RSI NA cam, how will that be with the turbo?
Old 12-04-2017, 11:04 PM   #12
centason
CNT-FAI
centason's Avatar
Would give a low end grunt like it probably does, and give good mid range. May or may not run out of steam. Only speculation. Would have to test it and see how it works out.
Member: TBCCS
"Democracy is also a form of worship. It is the worship of Jackals by Jackasses." -H. L. Mencken
You sons of bitches are the biggest thread de-railers in forum history.
Any forums history.
Old 12-04-2017, 11:10 PM   #13
towerymt
the real Towery
towerymt's Avatar
We always ran T3's in our 240 lemon. No water lines, no problem. They're a bit beefier than the TD04. We broke a turbine shaft once, but generally didn't have turbo issues...unless you count the wastegate actuator vibrating loose and we lost boost pressure. Turbo was reliable once rebuilt. Probably around a dozen races with a Turbo on the side of our B230F.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
Originally Posted by Poik View Post
244s are drop dead ugly and suck.
Old 12-04-2017, 11:53 PM   #14
EivlEvo
Towery and/or any of you other racecar peeps. It would be super nice for you to write up a how to and what realistic things/costs looked like. I know it's kinda dumb, and the info is KIND of out there... but it's still never as easy as it seems.
Old 12-05-2017, 10:26 AM   #15
turbotankshane
I don't think there's any point to putting that header on if there's a td04 sitting on top of it.
Old 12-05-2017, 02:15 PM   #16
alfavs.volvo
We would use a stock manifold if it fit. The only reason we need this header is to hold the turbo up high for clearance (and if there is a performance gain, that would be nice too!)
Old 12-05-2017, 06:02 PM   #17
Tuff240
240 Ninja
Tuff240's Avatar
Make an educated guess, then multiply by 10.
-Patrick
Old 12-05-2017, 09:05 PM   #18
EivlEvo
Right but whats the path of least resistance?
Old 12-05-2017, 09:15 PM   #19
sbabbs
sbabbs's Avatar
Don't forget with the ebay turbo header flipped and welded then the one runner is real close to the water pump inlet. Better figure that out also.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 12-06-2017, 12:23 AM   #20
maxitoman007
Forgot about this, I have an intricate setup of zip ties holding my water pump inlet hose about 1/4 of an inch away (air is the best insulator). Also had to use zip ties to hold the top power steering hose away from the header as well. Might give the hoses a 1 or 2 layer wrap in that mirrored duct tape to try and reflect some of the heat away. I’ve heard it’s better to have a thin space of air than to say wrap the header and have it touch.
Old 12-07-2017, 11:51 AM   #21
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Forgot about this, I have an intricate setup of zip ties holding my water pump inlet hose about 1/4 of an inch away (air is the best insulator). Also had to use zip ties to hold the top power steering hose away from the header as well. Might give the hoses a 1 or 2 layer wrap in that mirrored duct tape to try and reflect some of the heat away. Iíve heard itís better to have a thin space of air than to say wrap the header and have it touch.
Mine melted my ps pump line...i have mine wrapped
'91 744t...it's fast as phuck
Old 12-07-2017, 01:03 PM   #22
turbotankshane
I insulated the w/p hose, hasn't ever been an issue.
Old 12-07-2017, 03:03 PM   #23
Sounds like expensive stainless scrap metal to me...
Old 12-07-2017, 03:14 PM   #24
alfavs.volvo
Cheapest/easiest way into Lemons racing is to do an arrive and drive with an established team. You get to race and not worry about building a car and transporting it or prepping it. Teams typically charge $500-$600 for the weekend. This includes race fees, fuel, etc.
The next step is to buy an established car. There was a 780 turbo Lemons car for only $1500 a while back. This is great deal because you will easily have twice that into a car if you build it yourself.
Plan on at least $600 for personal safety gear if you can share a hans device with your teammates.
For a team of 4, other costs are roughly per person:
Fuel $50-$75 per race
Tires $50 per race (we get 2-3 races out of a set of tires)
Misc Parts $100 per race (my team is constantly upgrading and fixing stuff)
Entry Fee $330 per race
So, not cheap, but compared to other racing it is a deal for the amount of seat time.
Old 12-07-2017, 09:53 PM   #25
megulon-7
why not use the NA exhaust main and make a set of "J pipes", lets you put the turbo right where you want it.
megulon-7 is offline   Reply With Quote
