Old 03-22-2016, 04:35 PM   #26
sbabbs
sbabbs's Avatar
Guy I got my m90 from told me they are the same as M56 transmissions and you could put the gears from the m56's in the m90's if you want. Not sure on that but if so then parts like syncros and bearings should be same then right?
Old 03-24-2016, 08:01 AM   #27
eabras
Most of the internals are the same, i used a syncro from an m56 when I broke the m90 third gear syncro. Just be sure to get the right type, m90's first came with single syncros and later three piece syncros.
eabras is offline   Reply With Quote
Old 03-24-2016, 08:05 AM   #28
Chris Wilson
Do Volvo sell internal parts for the M56 `box? Thanks.
Chris Wilson is offline   Reply With Quote
Old 03-24-2016, 09:10 AM   #29
no
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-09-2016, 11:14 PM   #30
sbabbs
sbabbs's Avatar
I figured why not have a pro welder weld it. Pics maybe video probabbsly showing how to take it apart coming or is it put it back together. Basically if you want to take it all the way out you gotta take out all the bolts out from the front of it, then there is a snap ring you gotta take out, then all the guts will fall out if you turn it upside down. Sort of how I did it.. That is the input shaft Eric is holding there in the pic above. Also the turd gear stop ring weld shaft. Same thing. Don't forget to take that bolt goes into shift rod in trans and drop out ball bearing first...
Fortified one M90L1 with 38k to take the forthcoming abuse.
Old 11-09-2017, 07:04 PM   #31
petiww
petiww's Avatar
Anyone has any info about setting up coutershaft axial clearances in these boxes? Just by curiosity...
1980 Brown 244 GL
Old 11-09-2017, 08:00 PM   #32
petiww
petiww's Avatar
Oh well, it probably has a small preload, but how much, and where are the shims placed?
Old 12-01-2017, 10:36 AM   #33
kpax6
Thanks to all the fine folks that posted here. You are a big help to me on my 740 Turbo cheapo endurance racing car, the Happy Moose Racing sedan. I have an M90 in it, sourced from a friend in UK, but I did not do the weld upgrade...yet. Seems a big job, but smart to protect my rare bird tranny. Even got lucky on the ratios, it is the closer ones, whew. No, we didn't know beforehand, he just had one and sent it, boom.
kpax6 is offline   Reply With Quote
