Old 09-16-2017, 04:56 AM   #26
karlis
karlis's Avatar
Awesome screen - reminds me of one of those old cashier screens.
An extra tip for those re-creating this gauge.
Incorporate a ambient pressure sensor to have even more precise boost readings in higher altitudes and changing climates.
How to can be found here. I wanted to do the same, but my barometer didnt come in mail till today :D
link
karlis is offline   Reply With Quote
Old 09-16-2017, 02:26 PM   #27
esmth
dirty swede
esmth's Avatar
That's exactly what it came from, funnily enough
1991 244 +T LH2.4 m46 287k miles with B cam advanced 4*, 962 fuel & 148 ezk, T5 white injectors, 2.5" exhaust w/ magnaflow straight-through & some kaplhenke suspension goodies
Old 09-17-2017, 02:02 PM   #28
bobxyz
bobxyz's Avatar
Nice stealth! For a simple baro sensor, you can just save the initial pressure reading at power-on before starting the engine (idea courtesy of megasquirt).
Old 11-27-2017, 05:51 PM   #29
Pete.M
Slow Member
Pete.M's Avatar
Getting this error when trying to upload the code. Any ideas?
C:\Users\Peter\Downloads\boost.ino\boost.ino.ino:4 :26: fatal error: SSD1306Ascii.h: No such file or directory
#include "SSD1306Ascii.h"
compilation terminated.
exit status 1
Error compiling for board Arduino Nano.
Pete.M is offline   Reply With Quote
Old 11-27-2017, 06:15 PM   #30
BDKR
Section 9
BDKR's Avatar
exit status 1
The compiler needs that file (SSD1306Ascii.h). You can download here.
You may as well download SSD1306AsciiAvrI2c.h as well since it's likely you don't have it. Based on the code, once you've fixed that first error, it'll just choke on the second include.
For all you Dijkstra fanboys:
Old 12-28-2017, 06:42 AM   #31
Pete.M
Slow Member
Pete.M's Avatar
I couldn't quite work out the wiring from the original pictures, so hopefully this picture helps others. Now working perfectly.
DSC_0697 by Peter Macdonald, on Flickr
Old 12-28-2017, 09:46 AM   #32
rom
rom's Avatar
well that's clean. i like it. looks great.
Religious people scare me.
rom is offline   Reply With Quote
Old 01-01-2018, 11:12 AM   #33
Roman_Turbo
I'm planning on doing this paired with a boost control solenoid to swap from my mechanical rig.
And maybe later add a wideband to the same program.
Will post it when done.
Roman_Turbo is offline   Reply With Quote
Old 01-02-2018, 04:57 PM   #34
Fa182
Stage 1
Fa182's Avatar
Thanks a lot for sharing, this is awesome! I just ordered all parts. No experience with Arduino yet but I'm excited to try this out.
- 945 Turbo, 1997.
- 245, 1993.
