Old 11-13-2017, 03:49 PM   #1
ElHefe910
ElHefe910's Avatar
Default I know.. twin turbo B230f
So I have a spare 240 with lh2.4 and big rods. I am getting into welding and getting better at it. I wasn't trying anything crazy. I was hoping to adapt the twin 11gs that come off of first generation S80T6 or XC90 which are plentiful at the pull apart junk yard, and run microsquirt or something on that level. Does anyone have any mock manifolds that I can take ideas from. PS. Don't say just put a hx35 on it or something because my other Redbook has a 16v with custom 8.5.1 cr and rsport rods with a k24 for now.
ElHefe910 is offline   Reply With Quote
Old 11-13-2017, 04:47 PM   #2
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
That actually seems like it’d be pretty neat. Those little turbos are tiny. I have no idea about manifolds though. Maybe you could copy what the s80 manifolds look like, just minus 1 cylinder on each one?
Essentially just using 2 cylinders to spool each turbo.
I look forward to updates.
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata
95' Camry auto
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW17
If you stop and think about it, it’s literally not worth your time to get on TBOT every day and argue about politics.
Old 11-13-2017, 05:04 PM   #3
ElHefe910
ElHefe910's Avatar
That's what I had in mind. I recently rode in a BMW 2.0TT and it had a fair amount of tq and hp and plenty of low end power and sustainable boost pressure at higher rpms. The td03 11gs are small in fact small enough that Hayabusa drag bikes put them on their bikes, but I think it could make a very balanced 250 whp 240.
Old 11-13-2017, 05:10 PM   #4
ElHefe910
ElHefe910's Avatar
The OEM T6 manifoldso are cast I think so it would be hard to modify that one, but I was thinking of getting a flange and starting from there. I think it has to be somewhat compact due to the passenger strut housing. I'm just trying to utilize what we have available for Volvo at the junkyards these days and who knows maybe it could turn into something, however I do think it probably would need microsquirt or something like that to tune it correctly
Old 11-13-2017, 05:11 PM   #5
okoye
okoye's Avatar
It's been done before. There is a guy in the UK that's done it on a hotrod.
Old 11-13-2017, 05:14 PM   #6
ElHefe910
ElHefe910's Avatar
Yeah I imagine it has been done before, just don't see it often most likely due to the fact it's easier for single turbo
Old 11-13-2017, 05:19 PM   #7
ElHefe910
ElHefe910's Avatar
I just see them at the pull apart everywhere and its usually the transmision that put it there not the motor. It's not like 10 years ago when every given saab, Volvo and MB still had their turbos intact at the junkyard.
Old 11-13-2017, 05:19 PM   #8
okoye
okoye's Avatar
Old 11-13-2017, 05:54 PM   #9
ElHefe910
ElHefe910's Avatar
Looks pretty effecient. No windshield washer fluid but that is not a concern by a long shot. From that picture it looks like a simple 4 cylinder TT compact manifold with up-pipes to put the turbos in a location where there is little to no obstruction
Old 11-13-2017, 06:40 PM   #10
740atl
educator monkey
740atl's Avatar
I think if you were going to take this seriously you’d just do it. I personally think it might be useless on a 4 cyl unless you’re considering a compound setup with a small turbo feeding into a larger one.
What are your plans for the car? That would help you in your decision making. Otherwise...
Old 11-13-2017, 07:05 PM   #11
ElHefe910
ElHefe910's Avatar
I think a single TD0311g would be a good fit for 2 cylinders on a B230f. Plans for the car is just a 250whp but I want to see if a small TT setup would give the car a much broader powerband. Sure I could use an HX35 and spray gas down low but that's not what I am trying to do. The car is a project and sitting in my garage now just looking to hone my welding skills and try something unique. I planned on using a microsquirt unit off of my old jet ski and trying to adapt a TT setup from the junkyard and the Volvo seems to be the best choice. It wouldn't necessarily be a daily driver because I have so many cars and toys already. I got the car for basically free. I was hoping to get ideas for a manifold design
Old 11-13-2017, 07:16 PM   #12
cwdodson88
pairing cylinders is going to be iffy. I think you'd want to pair 1-4 and 2-3... so it may be a bit wonky to work out runner length.
The Build Thread
SVEA - PUSHROD TURBO!
Old 11-13-2017, 07:25 PM   #13
ElHefe910
ElHefe910's Avatar
Good advice I haven't taken that into consideration much. I figured most of the kinks could be worked out through tuning, maybe megasquirt with 2 injectors per cylinder might help or might not but I am not trying to do that anyway as I plan to run micro
Old 11-13-2017, 07:43 PM   #14
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Put an HX35 on it
Hello My Glorious!
Old 11-13-2017, 07:51 PM   #15
cwdodson88
running a NA b230 manifold, then two J pipes out to the turbos will keep the pairing correct, but you might need 2 feet of j pipe.... Well actually thats about what I have and my 15g on a 2.0l spools and builds 15psi before 3100rpm, 7# by 2800, so its not too bad.
Old 11-13-2017, 08:03 PM   #16
gross polluter
They see me trollin'
gross polluter's Avatar
What 2.0 BMW is twin turbo? Seems like you’re confusing it with twin scroll.
A properly sized single on a red block will outperform hacked in twins all day.
Old 11-13-2017, 08:10 PM   #17
ElHefe910
ElHefe910's Avatar
Maybe I am because I didn't think BMW made a 4cyl TT. My friend got a brand new X3 2.8X drive rental while he was looking for a car He claimed it was twin turbo. I didn't look at the motor but he said it said twin charged or something like that IDK the thing was pretty quick
Old 11-13-2017, 08:17 PM   #18
gross polluter
N20 engine. Single turbo.
BMW calls it “Twin Power Turbo” becuase of the twin scroll.
It’s just a single turbo 4 cylinder engine. Nothing fancy.
Old 11-13-2017, 08:24 PM   #19
ElHefe910
ElHefe910's Avatar
Gotcha I thought that it might be BMW'so answer to the Volvo 2.0 4cyl TT+electric supercharger motor or something like that even though I have never seen one of those Volvo motors but Polestar got it to 425hp.
Old 11-13-2017, 08:30 PM   #20
Do it to prove everybody wrong.
Old 11-13-2017, 08:42 PM   #21
ElHefe910
ElHefe910's Avatar
I'm kind of old school and don't know all the recent websites, but I am sure Yoshifab can sell me an 8v header/manifold flange to start with. If anyone has a flange for sale let me know.
Old 11-13-2017, 08:56 PM   #22
Vincent Gagnon
Vincent Gagnon's Avatar
Vincent Gagnon is online now   Reply With Quote
Old 11-13-2017, 09:00 PM   #23
culberro
culberro's Avatar
I do, and a twin scroll turbo flange for an EVO 8 turbo, and a twin scroll EVO 8 turbo. Buy my crap!
Old 11-13-2017, 09:15 PM   #24
ElHefe910
ElHefe910's Avatar
I will buy the manifold flange. But someone could have a real fast 850 if they buy both our stuff..your turbo and my rods and pistons
Old 11-13-2017, 09:45 PM   #25
240240
Wookie drift missle
240240's Avatar
then supercharge it and make us all cry.
Originally Posted by Randomletters View Post
I think I'm probably the only person who really likes the 1st gen S40/V40s. I can't wait until they turn 25 so I can import a manual one from Europe.
240240 is online now   Reply With Quote
