Old 11-29-2017, 02:51 PM   #26
oldschoolvolvo
oldschoolvolvo's Avatar
Ah ha. Understood.
-Mike
1998 V70 T5
Old 11-29-2017, 03:19 PM   #27
maxitoman007
Found this: http://forums.turbobricks.com/showthread.php?t=37653
Edit: found article in the vault: http://forums.turbobricks.com/showthread.php?t=41272
maxitoman007 is offline   Reply With Quote
Old 11-29-2017, 08:26 PM   #28
photoman327
photoman327's Avatar
Originally Posted by maxitoman007 View Post
Nice but not a B21F manifold that is the best flowing intake. I take pictures of my B21F manifold in the morning but still prepping it.
Old 11-29-2017, 09:00 PM   #29
maxitoman007
Th OP said they liked the look of the b230 manifolds so I thought this was what they wanted.
Old 11-29-2017, 10:22 PM   #30
photoman327
LOL. No problem here but some of this was done 10 plus years ago and I’m way behind.
Old 12-02-2017, 02:03 PM   #31
Canuckvolvo
Drunk as ****
Canuckvolvo's Avatar
Originally Posted by DET17 View Post
I made my decision based upon PM interviews with 3 folks who converted from the B230FT to the B21F; 2 in Europa and 1 in Canada. The only dyno data I've seen for the B21F (E in Canada ?) showed a brilliantly flat torque curve, as opposed to the peaky curves I've .
Mine?
https://youtu.be/w--Uw97zG7o
Man I had that thing running sweet. Was even nicer when I swapped out the huge T04b compressor for a 60 trim T3- boost came in even sooner and gave up little on the top end.
Currently Volvo-less
Canuckvolvo is offline   Reply With Quote
Old 12-03-2017, 04:20 AM   #32
photoman327
https://imgur.com/gallery/yYfpb
B21F intake converted for EFI.
Old 12-03-2017, 08:57 AM   #33
DET17
Reformed SAABaholic
Originally Posted by Canuckvolvo View Post
Mine?
Indeed! Looked near ideal. What trim did you have in the T04B, perhaps the Super V or S?
Old 12-03-2017, 08:59 AM   #34
DET17
Reformed SAABaholic
Looks identical to mine, a Nathan conversion. I didn't bother to polish the casting, just painted mine. As soon as I get my 57mm TB rebuilt, she'll be installed on the 940.
Old 12-03-2017, 09:21 AM   #35
photoman327
Started polishing and never got back to it. Polishing is a lot of upkeep but on the b21f it's fairly easy. Painting is better and ceramic coating is really the way to go. I think this is nearly if not as good as Nathan's sheet metal manifold in my mind because of the long runner up to 5500-6000 RPM. The intended target(Red 84 242 B21fT) was hacked with MS1 when I got it.
Old 12-03-2017, 12:20 PM   #36
Canuckvolvo
Drunk as ****
Not sure I knew exactly. Based on measurements I think I figured it was an S trim. That thing would have made serious power if LH could have provided more fuel and rpm. I had the cam advanced several degrees to bring the peak down as well.
