Old 11-25-2017, 09:46 PM   #26
Not at all! That's not even logical..Come on, you gonna work on cars there are logical things to do and to have any happiness---and that is the whole point of being here---then you must learn to be logical---within the illogical world.
here's a basic thing you must grasp:
Engine torque is pretty much a function of engine volume and (dynamic) compression ratio,,
The camshaft moves the powerband around--where peak tirque is in the revs and as a result of where peak torque is, where peak HP occurs..
But its torque that moves the car..
Fapping about one POS emmissions cam over another POS emissions cam is max fapping.
You want more fun?
Pull the head and surface (mill) it about .040"
Then get a cam that is supposed to be a FUN cam, not a POS emissions cam in a car designed and built and sold to crusty ol sprout eating white guys...
The car will be boo-coo funer-er...
Get the static comp up to somewhere between 11 and 11.4 and the K cam is fun.
But since people want stupid money for them I'm getting some cams out of Sweden that are FUN cams on new sticks that cost less than people have been asking---and getting---for used cams here in Fapp-central
Don't mean to be a spoil-sport but I'm guessing you missed the based in California bit?
Old 11-26-2017, 02:41 PM   #27
Can play the blues
Originally Posted by Wren View Post
I'm going to disagree about the hushers. $25 in my wallet sounds much nicer than the minimal amount of valve noise they prevent.
Yes that is a good point Wren. Gotta say I agree with you. I have installed the V15 cam with new hushers in my turbo and without replacing hushers in my 93 wagon and it really didn't make much difference. Maybe for about 10k or so. Just take your time and adjust the valves carefully.
Old 11-26-2017, 02:57 PM   #28
No but that's his choice..and problem.
I have done cams up to around 286 duration that passed emissions up here as long at it had an O2 sesnsor working
And that was KeJet
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-26-2017, 03:08 PM   #29
Can play the blues
Never an emissions fail for me with enem V15 cams in turbo kjet and LH2.4 cars. It is called the street performance torque cam. My state used the California IM240 test for many years till they realized the expense of testing like that was too much when you can just plug into the cars computer from 1996 and newer. So anything older than 95 has no emissions testing or inspection here.
Old 11-26-2017, 03:11 PM   #30
2manyturbos
^^ Washington is much more lax on their emissions standards than California. It always has been. Here in Oregon you can pretty much do anything you want as long as you don't live in Ashland or Portland and the surrounding cities.
Old 11-27-2017, 06:54 PM   #31
GeneralBurrito
GeneralBurrito's Avatar
Now I have possibly 2 sources for cams. A V cam and an RSI Stage 2 turbo cam. Which would be a better/funner cam for daily driving for my NA?
Old 11-27-2017, 07:04 PM   #32
Streetliight
Volvo Noob
Yeah, I don't think that's going to work very well.
Like some others have said in here, post in the wanted section for an A or B cam. I got my B cam a year ago for $60 or something like that. No matter what cam you get, it's still going to be sort of a turd because it's NA (and there's nothing wrong with that). The biggest improvement is that it no longer sounds like it's going to explode above 3500RPM like the M cam does
Streetliight is offline   Reply With Quote
Old 11-27-2017, 07:12 PM   #33
GeneralBurrito
Lol yeah the M cam sounds horrible near 3500. People have used the IPD turbo cam in their NAs without any problems, I'm just looking at my options here. I'm being offered a V cam for $180 so far and that seems like a big jump from a $60 B cam.
Old 11-27-2017, 07:14 PM   #34
Streetliight
Volvo Noob
I'm sure it would run, but it probably wouldn't be ideal. And yeah, I'd just ask around for a B cam.
Old 11-27-2017, 09:25 PM   #35
GeneralBurrito
Yeah I'm thinking of just going with a mild jump to a B cam, should be a lot cheaper too.
Old 11-28-2017, 11:10 AM   #36
Ryan_R
Mind you, eBay Volvo cams are usually from a Penta marine engine, so you're seeing marine prices.
I appreciate the folks saying you gotta do more than just add a cam, but that's not really true. It all depends on your end game. The reality is that driving characteristics will change hugely for the better with a "mild cam". The M and T cams are just restrictive. And 'A' or 'B' are liberating. They're not really performance cams per se. If you're going to put a more aggressive cam in, you want to start looking at exhaust upgrades.
You *do* want an adjustable cam gear to advance these slightly. This'll bring the power band a smidgen. I strongly recommend one of the slidy ones with set screws vs. the ones with holes drilled in them. I have an Avalanche gear that worked great.... but when I tried to reproduce my results with another cam gear, I had troubles. Then I measured the Avalanche gear, and found all the holes wildly off (the 2 degree advance was actually 4 degrees).
You'll definitely need to re-shim.
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 11-28-2017, 01:08 PM   #37
2manyturbos
A B cam is a nice step up from the stock M cam in an otherwise stock 240. It is still mild mannered, yet, has more mid range and top end power.
