Old 11-27-2017, 01:58 PM   #1
okoye
okoye's Avatar
Default can non slotted get machined to be slotted?
Wondering if anyone has done it before?
Old 11-27-2017, 02:45 PM   #2
It can be done, but there's more to it than just cutting the slot. There needs to be a relief cut for the drive shoe and a hole for the shaft machined as well.
Old 11-27-2017, 03:11 PM   #3
John V, outside agitator
Did 30 of them at one time.
But for a onesy it sure as hell better be some cam you have strong feelings for or you'll feel you wallet get lighter a whole bunch.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
John V, outside agitator is online now   Reply With Quote
Old 11-27-2017, 03:16 PM   #4
Anything is possible unless you're on a TBudget™ and if you are not much happens at all.
Old 11-27-2017, 03:47 PM   #5
2manyturbos
Not true. On TB, a hand held drill, vice and a abrasive saw are all you need.
Old 11-27-2017, 08:37 PM   #6
Wren
Porkchop Sandwiches
Wren's Avatar
You left out the heater hose, Harbor Freight welder, and zip ties.
Old 11-27-2017, 09:01 PM   #7
freevolvos
is j.b. weld to much for t-bricks
Old 11-27-2017, 09:28 PM   #8
Can play the blues
You can always change to a block mount distributor or the wasted coil setups. Going to a block mount distributor will save you hundreds in tune up costs.
Old 11-27-2017, 11:54 PM   #9
ovlov760
ovlov760's Avatar
Yes. I've had it done to both a A cam and K cam.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
ovlov760 is online now   Reply With Quote
