Old 11-27-2017, 02:14 PM   #1
VolvoPrince
Default 1984 B23F to B21FT (KJet to LH2.2)
So I'm about to transplant an 83 B21FT into my 84 245 with a B23F. I have everything I need I think (the guy who sold me the engine gave me literally everything from his car plus some). I want to convert the KJet system to LH2.2, which is in my car right now. What else do I need to do this?
1984 245 (400K Miles and counting)
1998 V70R AWD
VolvoPrince is offline   Reply With Quote
Old 11-27-2017, 08:37 PM   #2
bobxyz
bobxyz's Avatar
Here's a start - look it over and see if it makes sense and if you have questions:
http://forums.turbobricks.com/showthread.php?t=286161
'85 245glt aw71 k-jet -> lh2.4 -> ms
Old 11-28-2017, 01:26 AM   #3
VolvoPrince
I took a look, what is the EZK wiring for? I was going to take my 160 head off my B23 and fit it to my B21FT I just bought since the 398 head on it has the KJet Ports, plus I would need to rebuild the 398 head since it hasn't been and my 160 has. I plan on taking my distributor and other parts like the intake manifold with rail and injectors, idle control valve, mass airflow, and a few other parts on the new motor. Won't that work?
Old 11-28-2017, 01:28 AM   #4
VolvoPrince
Sorry, I actually spoke wrong. My car currently has LH 2.1 on it. Will that still work?
Old 11-28-2017, 01:42 AM   #5
John V, outside agitator
Sure,,,But why? Didya pop the B23?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
John V, outside agitator is online now   Reply With Quote
Old 11-28-2017, 01:59 AM   #6
VolvoPrince
She has around 500k miles and needs a lower end rebuild...
Old 11-28-2017, 02:03 AM   #7
OH! That's a lot..
Old 11-28-2017, 07:32 AM   #8
DET17
Reformed SAABaholic
..... I want to convert the KJet system to LH2.2, which is in my car right now. What else do I need to do this?
My son went down this road to perdition..... fought various LH2.2 parts, ECUs, and the performance was random & poor. Frustrated with it, he ripped out the LH2.2, bought & built a MS1 from Megasquirt, built a wiring harness on a Saturday and had it running Saturday night.
I've heard similar laments from folks attempting to use LH2.2. For my money, MS and TunerStudio is a slam dunk.... and you'll learn a couple things while your at it
Old 11-28-2017, 07:47 AM   #9
Mojo Stealer
I made 209hp and 233ft.lbs to the wheels with lh2.2 wEZK and brown top injectors. The EZK is a computer controlled ignition linked to the fuel computer that retards the timing when knock it detected, this feature is not available with the regular breakerless ignition
Old 11-29-2017, 10:33 PM   #10
Wren
Porkchop Sandwiches
Wren's Avatar
Your car currently has 2.0. 2.1 was offered in the '84 760 Turbo that had LH with EZK ignition.
