Old 11-28-2017, 02:32 AM   #1
maxitoman007
Default LH 2.2 timing advance for performance.
Have done quite a few mods on my 87 740 turbo but I haven't had the chance to play with ignition timing very much. I've heard of people running as much as 24 deg advanced. Lh2.2 is adjustable via the distributor conveniently at least for base timing so what should I do to optimize my performance?
maxitoman007 is offline   Reply With Quote
Old 11-28-2017, 02:54 AM   #2
Pro Sneaker Peddler
I ran 20° of static advance and a MSD BTM to pull timing with boost. It sort of worked but that is more than microsquirt money as is.
Old 11-28-2017, 10:15 AM   #3
maxitoman007
Yea I meant more just using the stock hardware.
Old 11-28-2017, 11:41 AM   #4
Pro Sneaker Peddler
That's playing with fire. At a certain point your EZK is already at max ignition retard and if you add more boost, it won't retard any more and that will cause detonation. The reason you would bump timing on EZK would be to get a bit more low and midrange torque.
Old 11-28-2017, 11:49 AM   #5
turbotankshane
Put it on a dyno and see what it likes, otherwise your guess is as good as anyone's.
Old 11-28-2017, 12:25 PM   #6
Mojo Stealer
Dump in some toluene or high octane gas, o thought about buying some 100-110 and experimenting with the base timing but went ms before I got around to it.
Old 11-28-2017, 01:38 PM   #7
maxitoman007
So best bet is just to keep it stock around 12 degrees btdc? Because I currently have it set around 14/15 thinking it would give me more power.
Old 11-28-2017, 01:47 PM   #8
Mojo Stealer
What kind of fuel are you using?
Old 11-28-2017, 02:57 PM   #9
maxitoman007
Currently 94 octane with up to 10% ethanol. Wondering if 91 non-ethanol would be better
Old 11-28-2017, 03:31 PM   #10
Pro Sneaker Peddler
Octane rating is octane rating. Specific energy is specific energy. Think it through.
Old 11-28-2017, 03:34 PM   #11
SquareD
An Anomaly
SquareD's Avatar
Advance it until it blows up and then back it down a degree or 5.
Old 11-28-2017, 04:48 PM   #12
maxitoman007
I'm very sorry but I do not understand those terms.
Old 11-28-2017, 04:59 PM   #13
Mojo Stealer
Gasoline has more heat energy than alcohol, so pure 91 will have more energy stored than 94 e10 however the 94 will be more detonation resistant.
Old 11-28-2017, 10:26 PM   #14
sbabbs
sbabbs's Avatar
You can always reprogram the timing map and burn a chip for it and stick it in your 2.2 ezk box that you cut the stock chip out of and put a socket in. Turnerpro xdf and ezk files here..
http://forums.turbobricks.com/showthread.php?t=268066
Best to probably pay me to burn a 40 pin dip chip if that is the route you want to go. Hard to find a programmer that will do it correctly. I had to modify mine so it would work.
The tuned bin I have has more timing low and less up high built for more boost!
Old 11-29-2017, 02:27 AM   #15
maxitoman007
Noted, might have to contact you for some chips once I find some money to play with, as for now, should I just leave it stock based on the fuel I'm running?
Old 12-02-2017, 12:51 AM   #16
maxitoman007
Bump, without chips should I return to base timing to around 12 btdc instead of 15?
Old 12-02-2017, 02:46 PM   #17
maxitoman007
Bump
Old 12-02-2017, 03:46 PM   #18
Mojo Stealer
How's it running? Getting any detonation? Leave it alone if you're happy with it.
Old 12-02-2017, 04:41 PM   #19
maxitoman007
Well I currently think I may have setup the timing belt a tooth off as my car only really comes alive above 4500rpm so I'm not sure. Does advancing base timing give you more power?
Old 12-02-2017, 05:35 PM   #20
lummert
lummert's Avatar
Advancing the timing too much will result in the knock sensor system retarding the timing.
Old 12-02-2017, 07:08 PM   #21
maxitoman007
Alright once I adjust the t belt I think I'll just set it back to stock.
