Old 12-01-2017, 06:47 PM   #1
90volvo
Default last cam question promise?
Heres my specs. 1990 volvo 240 w/5speed M47. Stock B230 with No Turbo. Gears in rear 3.31 but have 3.73 I can go to but not crazy about it.
Factory weight 4 door with electric windows. I did the homemade ramair with a K&N filter. The exhaust is one muffler in rear and 2.25 diameter no cat. Im lookiing for mid range power.
Saved my pennys to buy a cam. I dont want to change valve springs. Im rarely going to rev over 4500-5000. Engine is in good solid shape and is low miles. Dont want to pull the head and get milled. What do you recommend. Basically have found cams A, B, H, T. I thinking of IPD turbo cam? Thoughts
Old 12-01-2017, 06:48 PM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
A or B cam.
-Stephen
#mclovethesenuts
Old 12-01-2017, 06:50 PM   #3
PromiseRing
We don't even like Volvos
I’d say A or B. I have experience with M, T, B, and iPd turbo. No na experience with with the B and iPd turbo though. People will tell you the B sucks turbo cus of overlap or whatever. But i assure you it’s more revable than the M cam. Even if you lose some low end
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
-94' M-Edition Miata-Stock with a hardtop
Past
-80' 242gt m46-
-92' 940 turbo, got for free, fixed, sold
Feedback Thread
can't replace u joints
Old 12-01-2017, 07:39 PM   #4
petiww
petiww's Avatar
A cam. But there is no real noticeable torque increase at midrange as i experienced over the M cam. It revs much more freely into rpm limit, and actually make power there.
1980 Brown 244 GL
Old 12-01-2017, 08:48 PM   #5
Can play the blues
Get an enem V15 n/a cam. It's better than the IPD cam because it is the same with lift and duration but the lobe separation is for an n/a. I also just chipped my ezk box and that really made it come alive. Low range, mid range, high rpm power all there. I also don't rev over 5k because of the high miles on my engine.
Old 12-01-2017, 09:15 PM   #6
90volvo
I might add, that i dont have toworry about smog test. Im in Mo. Possibly ill pull the head and have it milled and ill prt it. I dont rev much over 3500 but i have a M cam. With a performance might be fun to bump 6000 every now and then.
Old 12-01-2017, 09:23 PM   #7
Pro Sneaker Peddler
It will never make power at 6000 NA unless you do some pretty drastic work to the cylinder head.
Old 12-01-2017, 10:17 PM   #8
John V, outside agitator
No
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
John V, outside agitator is online now   Reply With Quote
Old 12-01-2017, 10:20 PM   #9
PromiseRing
No
Old 12-01-2017, 10:21 PM   #10
I recommend you don't bother...
Cam is only one part of things and you don't want to do the more important things then there's no point of doing the final things..
You also didn't bother to say what gearbox you have or what kind of driving you plan on optimising..You don't want to do anything but want it to do something better..
Confusing.
Try again.
Old 12-01-2017, 10:46 PM   #11
PromiseRing
Confusing.
Try again.
Pretty sure his first post says he has an m47.
Try again.
Old 12-02-2017, 12:03 AM   #12
90volvo
Confusing.
Try again.
Really dont know what to tell you its an M47. Just like the first post said. It has 5 gears. Are you wanting ea. gear? Well here. Confused?
M47
Type: 5 speed manual
Manufacturer: Koping Engineering, AB Volvo
Gear ratios: (1) 4.03:1 (2) 2.16:1 (3) 1.37:1 (4) 1.00:1 (5) 0.82:1
Notes: Fully synchronized, apparently not as strong as the M46. Road&Track in 1989 says OD is 0.80
Appreciate everybody advice and help. Some people have to do little at a time vs. all at once. Thanks
Old 12-02-2017, 01:39 AM   #13
90volvo
Default common
Confusing.
Try again.
To bad we dont live near ea. other. I think we could be best friends. I want to go fast w.o. doing anything (LOL). You want to respond to post w.o. reading them. We have one thing in common.
Old 12-03-2017, 01:48 PM   #14
PromiseRing
Bump
Old 12-03-2017, 02:51 PM   #15
Mogly
280WHP Regina
Mogly's Avatar
D cam and 4:10 gears is what I recommend.
403whp, profile picture
Ford Colonge V6 in the works.
Mogly is offline   Reply With Quote
Old 12-03-2017, 03:30 PM   #16
PromiseRing
Interesting. I have not heard much of that cam before.
http://forums.turbobricks.com/showthread.php?t=11302
Old 12-03-2017, 04:11 PM   #17
M47
Very good..Even the old veteran Promise ring managed to catch and point out that error..
Truth is I skim over these things when they are so poorly written.
So M47, just like my car>
But just like ya din't want to do any of the important things to make the car quicker--involving work, you din't say any more really aside from mansplaining the box.
Final try and I'll leave you to the experts who know more>
Cam moves where peak power is and shape of curve..Not peak or max>
You want more you may have to expend some effort away from the keyboard
No back to fapping about how many angels can dance on the head of a needle>
Old 12-03-2017, 05:46 PM   #18
Cams are overrated, there is no TB¢heap™ replacement for displacement, plop a V8 in there and go go go.
Old 12-03-2017, 05:57 PM   #19
PromiseRing
Less skimming more reading. The dude wants to feel a power difference in his otherwise stock 240 with a 5 speed. Stop with all this science nonsense bull****. Putting a B cam in the car WILL make it more fun to drive. And WILL make more power over the M cam. Don’t have any scientific evidence to prove what i said other than that I’ve tried them both. The B can actually rev a little bit
Old 12-03-2017, 08:20 PM   #20
Mogly
280WHP Regina
Mogly's Avatar
Came off of a boat I scrapped.
It's a good cam, I ran it 3° advanced. Did 385whp 401lbs tq in my last setup.
The engine it came off of had dual solex carbs.
Old 12-03-2017, 09:06 PM   #21
Can play the blues
The Penta engines with a single carb use an A cam. The Penta engines with twin carbs have the V cam. Either way a win compared to the M to T cam lol.
Like that Power!
Old 12-04-2017, 05:28 PM   #22
darksider415
K-Jet or Bust
darksider415's Avatar
W cam.
Member: TBCCS
'80 Volvo 242GT
Originally Posted by zdriver123 View Post
You have to remember, TB members are experts on everything, except keeping Volvo's running.
Originally Posted by centason
This place is like a brothel. Men, women, tits, vag, dicks, fish, and mikep. What else could anyone ask for?
She has a weird 262C fetish thing going on
darksider415 is offline   Reply With Quote
Old 12-04-2017, 10:13 PM   #23
brian smith
Heres my specs. 1990 volvo 240 w/5speed M47. Stock B230 with No Turbo. Gears in rear 3.31 but have 3.73 I can go to but not crazy about it. Im rarely going to rev over 4500-5000.
T, retarded 3 or 4 degrees, plus a chipped ezk.
the howdeedoo:
Old 12-06-2017, 10:14 AM   #24
Ryan_R
You want an 'A', advanced 3-4 "real" degrees at the crank. I say "real", because I measured a popular timing gear offering with the drilled holes, and found the holes off by miles. My 2 degrees at the cam, was in reality 4 degrees at the cam. Classic Swede and STS machining sell gears that'll fit under the timing cover. Yer looking at $200-250 all said and done, plus valve shims.
Looking at the dyno charts on the OVT page, the 'A' bests the 'B' by a smidgen.
A mild Volvo cam really wakes these engines up and requires *zero* other mods (aside from new shims) for there to be a very noticeable difference. Especially with the M47.
Of course, if you want to go further, get a different cam and do more mods. All up to you!
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 12-06-2017, 10:27 AM   #25
KeizerBrickGuy
Sh*t pot stirrer
Ahem...glad my first post wasn't on point...
