Old 11-02-2018, 03:29 PM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default Cooling fan wiring
Just curious if lh2.4 has an output for the two speed cooling fan on either ECUs. Currently wired to a 2-way switch, currently very annoying.
81 264 - Driveway ornament
90 245 - becoming 16v
Old 11-02-2018, 04:00 PM   #2
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Yep, need to wire it like a 9 series, and add the pins to the ECU connector, BUT, I had mine wired like factory and the temp settings that it uses are a bit higher than I liked and it would run warm before switching on the fan.
I used the ubiquitous SAAB T and switch in the lower rad hose YMMV
1980 242 Turbo
2004 V70R
Old 11-02-2018, 04:14 PM   #3
LeedomtoFreedom
Did you use the two speed relay? When I pulled it from my 940, it didn't seem to get too hot before kicking on.
I'll have a look at a wiring diagram and figure out what pins.
Old 11-02-2018, 05:15 PM   #4
Hayden makes a dual speed adjustable fan controller. The high speed fan comes on when the adjustable low speed fan temperature is exceeded by 10°.
https://www.summitracing.com/parts/hda-3654/overview/
Old 11-02-2018, 05:18 PM   #5
Uncleknucklez
bruspeed
I did use the two speed setup, I currently have the switch trigger the high, and the pressure switch for the AC trigger the low speed setup, it works ok I suppose.
Old 11-02-2018, 09:26 PM   #6
LeedomtoFreedom
Which Saab did that come from ?
Also does anyone know of a good two speed fan switch. I think BMW make one but is it really necessary to have both speeds or will low speed suffice.
Old 11-02-2018, 09:35 PM   #7
2turbotoys
Salaminizer
2turbotoys's Avatar
I just use the high speed circuit of the relay, it has always worked great. I have a Saab T if you need one, I don't remember what I pulled it out of, but I just use the pusher fan temp sensor in the radiator, lower temp version.
2006 V50 T5 AWD 16 PSI +
Old 11-03-2018, 12:53 PM   #8
bobxyz
bobxyz's Avatar
Not all ECUs can drive the fan relays. The 937 can, the 951 can't. If you open it up, there should be a ~1/2" x ~1/2" square black chip roughly between the heatsink bar and the connector. If this spot is empty (just empty silver solder pads), then the ECU can't drive the fan relays.
Old 11-06-2018, 09:58 PM   #9
80series
Ive got the electric fan/relay setup and the Saab T. Does anyone have the part number for the temp switch that goes in the T and any pics of everything wired up? I'm clueless when it comes to wiring.
80series is offline   Reply With Quote
