Old 11-03-2018, 02:48 PM   #1
89_740Turbo
89_740Turbo's Avatar
Default It's going to rain in 2 days and my sunroof is stuck open. Heeeelp
The sunroof started to have issues when it fell off track and sagged on one side. Since then it's gotten worse without me even touching it.
When I go to close it, you only hear a clicking noise from the motor. It will only close so far.
Here is a video of what i'm seeing, hearing and dealing with. Qhat do I do! Replace the motor or is it just off the track? How do I get it back on track if off?
https://youtu.be/vJGvR_JSyn0
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
Old 11-03-2018, 03:42 PM   #2
Homer
OEMplus++
Homer's Avatar
Have you tried to manually close it? There should be a tool in the car to do so.
-Jacob:
2006 A4 - Comfy DD
Old 11-03-2018, 03:48 PM   #3
wyatt8740
wyatt8740's Avatar
Put a tarp over the car if the paint isn't spectacular to begin with.
My guess is the motor is OK, but there's some bad linkage/a broken gear somewhere. Don't know how the 700 series auto sunroof works specifically.
This might help:
http://www.swedishbricks.net/700900F...-Sunroof1.html
Converting to a manual sunroof would be my next move if possible. Less to go wrong.
1991 244 (manual 5spd)
1993 245 (auto 4spd [for now])
And the Dalai Lama smiled and said, 'Well my son, life is like a beanstalk, isn't it?'
wyatt8740 is offline   Reply With Quote
Old 11-03-2018, 04:05 PM   #4
Dan
TQ>HP
Dan's Avatar
The motor just bolts on in stead of a handle, no reason to do away with it if working. The sunroof is opened and closed by a spiral wound cable (like a spring) teeth on gear move it. there are tracks on either side that have covers held on with screws, look at it from the top and see if all screws are in tight.
Old 11-03-2018, 04:31 PM   #5
89_740Turbo
How do I manually close it?
And is changing it from automatic to manual difficult? I have a spare manual sunroof setup i could throw in. That was something i had thought about
Old 11-03-2018, 04:41 PM   #6
sbabbs
sbabbs's Avatar
Wut? It was already stated the manual sunroof and letric one are the same, one has manual crank other has letric motor. Other then that yes you can take out letric motor and put in manual crank, but everything else is the same.
Spare manual sunroof setup? What's that consist of? The manual crank arm and it's little gear and the plastic thing that covers it?
I've swapped both mine to manual crank, you unbolt the letric motor and bolt in the crank and the plastic cover thing if you got it..
Other then that I've also swapped out the whole sunroof assembly, not just the part that opens, the whole thing. You gotta take out the headliner to do it. Before that the one wouldn't close all the way correctly and the crank or motor did not work at all but I could grab the sunroof and pull it closed, but it wouldn't go up and seat correctly fully closed position, but it still didn't leak water into the car in oregon even..
Old 11-03-2018, 04:55 PM   #7
89_740Turbo
The spare manual sunroof that I have has all the workings including the manual crank arm, the little gear and the plastic cover that covers it.
And yes, it's currently automatic but I dont know how to manually close the automatic sunroof for the time being. My sunroof doesnt close all the way and wont go up either so that leads me to believe I need to take apart the headliner to get to it. The automatic crank stops at a certain point when the sunroof is about halfway closed and I cant even pull it shut using my own force.
If you watch the video I attached you can see what i'm talking about.
All in all, i'm thinking i'm going to need to remove the headliner to get in there
Old 11-03-2018, 05:21 PM   #8
sbabbs
sbabbs's Avatar
Try taking out the electric motor then you should be able to possibly move it by hand easier perhaps.
Yeah save the paint!
If your motor is clicking then maybe there is something blocking the sunroof from closing, check that again from above with it open on the sides look all in there. Or if it's a problem with the motor take it out and see if you can close it all the way then.
Old 11-03-2018, 05:57 PM   #9
89_740Turbo
This is what I will be working on tomorrow. I'm hoping to fix the issue in a day. In order to get to the inner workings on the sunroof, I need to remove the headliner, right?
Old 11-03-2018, 06:47 PM   #10
sbabbs
sbabbs's Avatar
Not sure about needing to remove the whole sunroof assembly to get to the inner workings. I did but I did it to replace the whole thing that didn't work. I've seen them fixed in the car before. You gotta know how to take them apart. I've never done it. Even if you take the whole assembly out you still have to figure out how it all comes apart. Maybe a book tells how or alldata. I had extra so yeah just swapped the whole thing. I took one out of my old race car sedan, they fit out the back door I think. In my wagon out the back hatch.
Yes the headliner has to come out of course it does. Other thing unhook the drain tubes and leave those in the car.... Don't pull them out.
I know people have replaced the sunroof with a moonroof but they just change the glass part I've heard that is a way to do it, once again, you gotta know how to take that part out. I don't. I did have a complete moon roof from a 960 in my 740 wagon. I put the whole thing in but it had a few different mounting locations. I used some self tapping metal screws and it fit okay but the sides didn't seal correctly and it leaked where the sides didn't seal so I just swapped back to the green stock 740 one you see in the pics, and now no leaks.. Guy I got it from(Harald) said it worked fine in his 940 but that had same mounting spots as 960. He said we'll just swap in the glass part, I said too late already swapped in stock 740 one. Over it, but leaks are gone! I do still have the glass one so maybe someday I'll tackle it.
So the sides of the moonroof cage have double sided tape to secure to the roof and that also is a water seal so keep that in mind. You'll see what I mean when you go to take it out after you take the bolts holding it up out.. You'll need some new double sided tape probably. I used the door seal roll stuff get at hardware store same size(thickness and width) as the stock tape stuff.
Also make sure the drain tubes where the tubes hook to the sunroof frame those are good and not broke before you put new sunroof frame in.. Those get easily messed up if you lean the sunroof cage up and on a concrete floor as they are then the things hitting the floor.. They stick out on every corner of it. If those are broke on your replacement you'll have leaks.
Old 11-04-2018, 07:44 AM   #11
S70T5fivespeed
S70T5fivespeed's Avatar
Start simple first like wyatt and sbabbs said get it to manual mode. Swapping the motor for the handle is probably the easiest job on a 740.
99 S70T5M black on graphite suede
91 740SE white on black
90 740TI oe aero kit black
In the barn: 67 123GT
S70T5fivespeed is offline   Reply With Quote
Old 11-04-2018, 09:45 AM   #12
buzz
To inspamity, and beyond!
buzz's Avatar
OR... as I've seen in the junkyard. Some valley tin, drywall screws and caulk. Lots of caulk.
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 11-04-2018, 03:01 PM   #13
S70T5fivespeed
Lol “in the junkyard” being the key phrase here. #savethe7s
OP did manual crank work?
Old 11-04-2018, 03:51 PM   #14
2manyturbos
OP, you can pull the entire sunroof assembly out through the top of the roof in order to fix it. It will be WAY quicker and easier than pulling the head liner. You just need to remove the screws that hold the wind deflector to the assembly and then you can get at all the screws that hold the rails and mechanism to the "cookie sheet" inner drain pan. Once all the hardware is removed, including the 2 screws that hold the motor up to the cable tubes, pull up on the rails and they will come loose from the drain pan. There are 2 plastic pegs at the end of the rails under the roof that guide/locate the rails way back in the roof where you can't get access. Once the assembly pulls forward an inch, you can tilt it up and pull the entire assembly out through the opening towards the front of the car. The lifter arm broke and it is now jamming the mechanism. To do anything else is just going to damage more parts.
Old 11-04-2018, 06:15 PM   #15
S70T5fivespeed
2manyTs clearly the expert on this. An aside can you explain why there are two different versions of 740 sunroof sealing strips? Between Pre-90/91+? I used a 91+ on my 90 and it worked but obviously 90 is a weird mixed MY. Wondering if there is an actual difference or just PN update.
OP if you end up needing parts and get desperate I think skandix had some stuff last I checked.
Old 11-04-2018, 07:57 PM   #16
tryingbe
Boosting along.
tryingbe's Avatar
I have a working 850 sunroof here that I couldn't give away for free.
85 GLH 367whp
00 Insight mpg > yours.
Old 11-04-2018, 08:50 PM   #17
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Get it most of the way closed with motor/switch, then get a large flathead screwdriver and insert it into the piece shown at 0:16 and turn until closed.
If it jams when manually turning, you may need to push up on the sunroof assembly itself to help unstick it.
Pull the fuse for the sunroof (or pop the trim cover and switch out and pull out the 'lectrical connector since I think that fuse is shared on 7/9) for no future worries.
Stay dry.
MV
Old 11-05-2018, 07:14 PM   #18
MasterBlaster
Maybe a bit of Duct Tape to keep it from blowing off?
472,000 km so far...
Old 11-06-2018, 11:14 PM   #19
A tough rowing ho
Has it rained yet?
