Old 11-05-2018, 08:17 PM   #1
nickvolvo746
Question TICKTICKTICK-maintenannnceee
Just a heads up, kind of noob here.
I have a 1990 760 T with a B230ft, with oil squirter (I have yet to take the thing apart so really who knows if thats true, but hey fingers crossed I guess)
Ive been experiencing a ticking noise since I bought the car a couple months ago and have been told many times by a friend that it is not the lifters, it is not piston slap and is a pretty normal noise. It is not a deep ticking noise and I am not too worried about it, but perhaps I should be? I cant hear it while I am driving, just when I pop the hood to mess around. Whats everybody else's experience with their properly functioning bricks? Is a slight ticking pretty normal? I check the oil pretty much every time I drive it cause I know it has a small leak, so I am inclined to think that a lack of oil is not the issue. Anywho, if youre still reading this, I really appreciate it and if you leave some feedback thanks even more!
nickvolvo746 is offline   Reply With Quote
Old 11-05-2018, 08:20 PM   #2
A tough rowing ho
Exhaust leak at the manifold
Old 11-05-2018, 11:02 PM   #3
Cap & rotor?
Old 11-06-2018, 12:09 AM   #4
PhysSDK2
Camshaft?
PhysSDK2 is offline   Reply With Quote
Old 11-06-2018, 01:09 AM   #5
iHateVolvoPeople
No squirters in 1990 unless someone installed them.
Post vid to YouTube and then share the link here so we can hear.
My guess is it’s normal Volvo noise.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 11-06-2018, 09:25 AM   #6
woodenpudden
lacks goats
woodenpudden's Avatar
https://www.brickboard.com/FAQ/700-900/
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 11-06-2018, 11:45 AM   #7
turbochimp
The other responses are more likely, but I have also had a more arrhythmic ticking - more pronounced on on decel - from a broken valve spring.
turbochimp is offline   Reply With Quote
Old 11-06-2018, 11:47 AM   #8
soclosenotnear
If it gets louder on acceleration, then this ^
Old 11-06-2018, 01:02 PM   #9
GeneralBurrito
GeneralBurrito's Avatar
Does getting louder on acceleration only happen with an exhaust manifold leak? I found a leak on the front pipe gasket that I fixed (hopefully, so far so good) over the weekend, but I still get the ticking on acceleration and silence when decelerating.
Old 11-06-2018, 04:38 PM   #10
iHateVolvoPeople
Exhaust manifold leaks (usually) only make noise under load, which is usually during acceleration.
