Slammed to lifted 740 wagon
This thread rocks ! :)
if you lenthen the struts, you put spacers to the bottom or do you use different dampers?
Spacers on the bottom. It will allow you to retain your full droop and bump travel. The only thing that limits you is the LCA's need to be an inch longer. I'm working on that.
Unfortunately i need the raise.. in germany you have special regularyties on spinning parts close to other parts.. our MOT Testers check for clearance and i need a minimum of 5mm from the tyres profile to the springperch..
So with an unused Wrangler Grabber 195/80/15 i have 1,5-2mm left to the perch.. with 75/80 km/h it rubs cause the tyre is expanding..
I think those 215/75/15 would look absolutely more awesome but milage and this needed LCA-Mod makes it uneconomical to me..
I Dont do this for the looks, i do it because im moving into the forest 2015... i need more space between me and the treeroots :D
So.. Tyres orderes, no uberones... just 195/80 :)
Do you think i need any modifications on camber or such when i just lengthen the strut about 10-15 mm to make space for the tyre?
Monter Tuck (how I said or possibly spelt monster truck when I was a wee little boy)...
But :omg:
Also, those welds are pretty MIG-nificent... Keep up the stellar work.
:cheers:
So.. I need to adjust my speedo for this mod... Germany :rolleyes: ....
Has anyone experience how to do so? I see 2 possibilities:
Mod thr tonering in the diffbox or piggyback bix to adjust the signal via potentiometre..
Are there some solutions out there already whichbfunction with lh2.4 from 96?
I started tearing into it on Monday. Tuesday I had the b230 and trans out and ls mocked up. I need an adapter for the trans and I'll make mounts. Time for the fun. I'm going to get it running and throw an ls9 cam in. Then I'll get the turbo stuff over the winter/spring. I'm going for a Borg Warner S476 with Meth. Easy 550whp/700tq. I was dripping sweat from when I got home from work so shirt came off with unanticipated redneckness.
I'm hopefully picking up a 94 940 Turbo Wagon tomorrow.
I swear I've been over this thread 100 times.
But it doesn't appear we've come to a general consensus.
How much tube should be welded in? 2", 2.25", 2.5"?
What size tire fits best?
What rear shock fits best?
What about rear springs? Stock Spring + 2 Hockey Pucks, ZJ Springs, XJ Springs?
etc
I'd like to have this relatively ironed out before I make the leap.
I don't have a lift, welder, or a suitable garage for any of this. (Its currently about 12* F Outside) So I'll be using my friends shop, but I'll only have one day to get everything done. (Figured I'll do Pads, Rotors, Plugs, Wires, Oil Change and Air Filter while I'm there.)
Any insight would be greatly appreciated. I'm hoping to have an awesome winter beater.
etc
Dear lifted Volvo enthusiast,
There should be a sticky for this.
When I did this I wanted ground clearance above all else. I chose to go with 30 inch tires for that very reason and I had the LS that was planned for future so I didn't mind gearing changes.
If you're going to keep it stock turbo, I would go with 235/75/15 whateveryouwant tires. BFG's are my jam but there are some cool tires out there.
Front:
2.5 inch lift: Cut strut, add 2.5 inch tube in the middle area so you will not hit the perch with the bigger tires, weld up, put 2.5 inch spacer in bottom of strut housing for strut to rest on. Reinstall strut. 2.5 inches will clear the tires. 2 inches is stupid and not enough. The front strut tubes are 2.25 OD I believe and they're galvanized. Clean that **** off because zinc will wreck you. Bevel the tubes. Make it look nice.
Bonus points for building lower control arms to compensate for the positive camber you will now have. Remove the swaybar if you wish. I did. Never rolled. Never died. Corners well. Use your stock struts unless they really suck since Bilstein HD's are too stiff. Your suspension is now functioning outside it's sweet spot so it will be stiff. If you build the lower control arms or add heims (I can weld cast aluminum so I just got an idea) than you can remedy this issue.
Rear:
Remove stock springs.
Install I6 Cherokee front springs as they're softer than the V8 in the rear. You will have two inches of lift. If you so desire for more add hockey pucks for additional lift. One puck is around a half inch or so. Shocks will be the durango ones or whatever your heart desires thats a little longer travel than stock but with a relatively similar body so your bump travel will be nearly the same. The vanagon ones seems to be the right size and valving but untested.
Bonus points for chopping your panhard bar apart and threading in or welding an insert into the bar for a heim joint to correct your track. I did not. The car drives straight. I don't care. Now, your springs WILL pop out at full articulation. My solution was to cut some tow straps and wrap them around the seat and the coil and I cut them long enough so it will barely hold the spring in at full articulation so I would have maximum flex. Drill a hole through them and put a grade 8 bolt through it with some big washers. I wanted to mount a tab for limiting straps but I didn't know how to weld then. This will save you on the trail or wherever you decide to jump at 70. My top speed is 95mph. THIS CAR IS SLOW.
As for how it drives:
It's excellent. It's tall. It's badass. It goes over a lot of terrain. Your gas mileage will go down with 30's but improve with 235's. Everyone will look at it. Everyone will love it. You will be out of step with the world.
Congratulations. You have built a Jeep Cherokee with two less cylinders, two less driving wheels and it will still go many places. Put some XJ flares on it and 1 inch wheel adapters with 5x4.5 wheels and you have a Jeep imposter.
Ideas I have thought about:
Camburg I beams. Longtravel front. Modify car to fit them. Probably +12 width all around in the front. hahahaha
960 front suspension with xc90 or forester struts in the front. More travel and more options for struts.
Fox coilovers in the front.
Chopping out the whole rear and doing a triangulated 4 link like a trophy truck.
Basically making a prerunner.
Remember it looks cool.
Thanks!
Well, I'm now the owner of a 1994 940 Turbo Wagon.
Going to order a bunch of stuff from RockAuto and hopefully get started in a week or two.
