LC4CARL
Aero challenged
- Sep 8, 2008
- Vancouver, WA
245's rock.
75 b20 breaker less is vacuum retard
car is looking great
I have the same MIG clock
Or hook it with a bicycle spoke end.
You don't need to make a special trip, just bring back the tools when you're done. They're duplicates so I won't miss them if you keep them a while longer.
245's rock.
Still Ain't A Saab!
Thanks Ian, I appreciate it as always. Will do the valve spring this weekend and get the tools back to you next week. It appears I also need a gasket for this M41, the one between the gearbox and the overdrive housing - do you have those available? It's leaking like an Anglo-Swedish sieve.
Thanks for the tips! I did find that same picture in an earlier thread you'd posted in, and compared to what I was seeing. Below is my engine. I think it's off by one tooth in the clockwise direction, which correlates with the 2-wire connector ramming the block with the distributor turned clockwise to get it advanced as far as possible.
I'll try your methods for gear removal sometime in the next few days. I haven't had a chance to replace my broken valve spring yet but I could drop by your shop tomorrow to return the cam gear tools.
Yeah, I have all the gaskets and seals for M40/M41 in stock.
Clean the trans and OD real good and check for other sources for the leaks. Don't forget to check the shifter bushings, especially the forward one. If it's worn, oil will leak all over the top of the OD.
Another thing is that slot is offset to one side if you notice it. So it has to be on the right side also. I don't think it will drop in. I forgot about that spring till you mentioned it.
This car is so freaking cool!
Many years ago I purchased the same color Volvo but a 242 model at a police auction for my sister. Great car, cost me all of $225 and all it needed was a fuel pump relay that I had in my car. She drove that thing for about 5 years after before she started having a few issues with it. At the time i didn't have a place to keep so it was donated to a charity. Although it wasn't mine I and she still miss it.
Cool, will do. I'll get your tools back in a few days, as soon as I can.
Yeah, I noticed that after finding one of Ian's earlier posts. Still need to try popping the gear out and re-clocking. This thing has been running great though!
I got a nice redwood packed stick of front door trim from none other than Kenwood Chair himself, ordered some OE trim clips from Tasca, and finally got around to installing them today.
Takes a good amount of force to pop the trim on; helps to get the top edge seated first, then bop the bottom edge with the heel of your palm.
So Davis is happening for you after all?
Woo!
Yes, for sure. Will be there either way. Even if we have to drive the V60. But the 242 will be running for this year; it hath been proclaimed.
