Old 09-05-2020, 11:56 PM   #1
oemoilleaks
oemoilleaks's Avatar
Default M40 gear ratios?
Was there any difference in gear ratios between an early 142 m40 and a 1975 240 m40?
I have no idea what I'm doing.
oemoilleaks is offline   Reply With Quote
Old 09-06-2020, 12:10 AM   #2
MasterBlaster
Well, let's see...
Starting at the start:
http://volvo.custhelp.com/app/homeV3
1970 140 Specifications page:
https://volvornt.harte-hanks.com/man...40_04.htm#pg59
M40
1st speed 3.13:1
2nd speed 1.99:1
3rd speed 1.36:1
4th speed 1:1
(with overdrive) - 0.79:1
Reverse 3.25:1
1975 240 Specifications page:
https://volvornt.harte-hanks.com/man...5_03c.htm#pg76
M40
1st gear 3.41:1
2nd gear 1.99:1
3rd gear 1.36:1
4th gear 1:1
Overdrive - 0.80:1
Reverse 3.25:1
If you believe them, first gear is a bit lower, overdrive (if it applies) a touch higher. Other ratios are the same.
500,000 km so far...
Old 09-06-2020, 08:35 AM   #3
84B23F
84B23F's Avatar
Originally Posted by MasterBlaster View Post
Well, let's see...
M40
1st speed 3.13:1
2nd speed 1.99:1
3rd speed 1.36:1
4th speed 1:1
Reverse 3.25:1
Based upon Chilton's Repair and Tune-up Guide for the Volvo (1969), Overdrive didn't exist then, and above ratios shown were the same for a M40 without overdrive.
Old 09-06-2020, 08:37 AM   #4
84B23F
84B23F's Avatar
Sidebar - SUPRA 5 speed Gearbox Conversion....By example this article contains VOLVO 240 / 740 / 940 fittment information
Old 09-08-2020, 07:53 PM   #5
oemoilleaks
Well, let's see...
M40
1st speed 3.13:1
2nd speed 1.99:1
3rd speed 1.36:1
4th speed 1:1
Reverse 3.25:1
M40
1st gear 3.41:1
2nd gear 1.99:1
3rd gear 1.36:1
4th gear 1:1
Overdrive - 0.80:1
Reverse 3.25:1
Well that would explain it. I wasn't sure if I was just imagining 1st gear feeling shorter in the '75 box. But what does confuse me is 4th also feeling shorter. I'm probably just imagining that one tho
Old 09-09-2020, 01:19 PM   #6
spock345
spock345's Avatar
According to the spec sheet the '75 wagon got a more aggressive rear end. So if you have a wagon you may be feeling that.
1967 122s, B18-D, M40
2012 VW Tiguan 6 speed auto
Old 09-09-2020, 01:46 PM   #7
oemoilleaks
I have a 4.10 Dana 30 rear end with a Detroit Trutrac in it.
I did also just build a new big bore b20 with a vv71 so I'm sure the cam profile being different (as opposed to the K cam I had in the old b18) is playing tricks on my mind as well.
I had an original 1968 m40 in there but lunched it the first 30 miles driving the new engine. I put a 75 m40 out of a first year 240 in it afterwards which is only a temp solution until I can get the m410 (yes m410) in there.
