Old 10-06-2010, 11:18 AM   #1
mels
mels's Avatar
Default Wheel offset chart
Poked around, couldn't find a chart defining the offsets for the many different RWD OEM Volvo wheels.
Has anyone put one together here? If so, could someone throw the link to me?
I'm primarily concerned with the offset difference between the 15" Draco and Virgo, if any, and the offset of the 16" Geminis I've just picked up.
Thanks!
Mel & Cindy
1987 745 TI Automatic, daily driver
1994 945 NA Automatic, hangar queen
1973 Ford F250 Ranger XLT
1975 MG B
2002 SAAB 9-5 Turbo Linear Wagon, Wifes' daily driver
2003 SAAB 9-5 Turbo Linear Wagon, hangar queen
1975 FLHP / 1977 XLCR / 1979 FXEF / Schwinn Predator with a squeaky pedal
What if you woke up TODAY with only the things you thanked God for YESTERDAY?
mels is offline   Reply With Quote
Old 10-06-2010, 11:38 AM   #2
Dawson
Yes?
Dawson's Avatar
240 wheels are +20
7/940 wheels are +25
These are pretty much interchangeable (14" 240 wheels will not fit on the later 7/9s though)
FWD wheels are anywhere from +35 to +49 and require spacers to fit onto a 2/7/9
1966 122s B20, head work, cam, ignition, 45mm DCOE's, M40, IPD springs 'n sways, poly bushings, Bilstein HD's.
1993 Dodge D250
1993 245 Turbo Daily
Dawson is offline   Reply With Quote
Old 10-06-2010, 12:32 PM   #3
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Wheel Guide Thread
Old 10-06-2010, 02:54 PM   #4
Freq
Freq's Avatar
I've started compiling a list here: https://spreadsheets.google.com/ccc?...thkey=CIiCreAC
Obviously is pretty incomplete but I'll be updating it as I find time. If anyone wants to be added as an editor let me know. I'm looking for exact offset, not just "FWD", since I'm sure plenty of people are looking for ********** stance.
Freq is offline   Reply With Quote
Old 10-06-2010, 03:02 PM   #5
NotSoFresh
NotSoFresh's Avatar
I would sort out the 4 bolt wheels and put them on a separate chart, they wont be used here much....
Old 10-07-2010, 07:53 AM   #6
mels
mels's Avatar
Thanks for the help, guys.
I remember the photo ID thread which helps folks ID the many different wheels, which is helpful in that regard, but I was hoping for specific offsets of those wheels.
Nice spreadsheet, Freq, hopefully that'll get some attention and help you fill in the cracks!
Thanks Dawson for the offset difference between the 2 and 7/9 series. Curious if the Gemini and Virgo wheels were 200 series wheels and the Dracos were 7/9?
I ask because I need to put some winter hoops on the Virgos and get 'em on my 745, and the Geminis I'd like to get some good Summer hoops on for the rest of this season too.
The 205/55/16's that came on the Gemini's rub the frame when I turn the steering to its' stop, where the 205/65/15's that are on the Dracos don't. I understand there is a difference in treadwidth and sidewall height between the 55's and 65's, but I can't help but think there is enough of a difference in offsets to give me these clearance issues - issues I don't want to repeat with the snow hoops I'd like to hook the Virgos up with or the Summer rubber I need to replace on the Geminis.
What's everyone else's experience with using the Virgos and Geminis on a stock height 745? What tire size(s) could you go with, and did you need a spacer (I see there's a new member here taking orders for hub/wheel centric spacers)?
Thanks again guys, I'm kinda in a hurry to outfit these wheels with some nice tires and don't want any clearance issues - either in or out.
Old 10-07-2010, 09:28 AM   #7
NotSoFresh
NotSoFresh's Avatar
If you scroll down the wheel guide, alot of the wheels have offsets and sizes listed with them.
Old 10-07-2010, 10:06 AM   #8
Virgo's are 240 Turbo wheels at 15x6x20et.
Draco's are 740 Turbo wheels at 15x6x25et.
The 700 Multi X are an exception at 15x7x20et.
My post #90 on page 4 of the wheel guide covers the most useful stock alloys.
Old 10-07-2010, 12:51 PM   #9
Wagoon
Wagoon's Avatar
I have Virgos on our stock height 745 with zero clearance issues but they will only fit cars with the small brakes. As for tire size, 195 60 15 has tons of clearance.
Ed
95 945 B230FT AW71L 3.73 1041
91 744 SE, B230FT, m46, 3.73 1041
89 745, B230F, m47, 4.10 1031
88 744, B230F, m47, 3.31 1041
Wagoon is offline   Reply With Quote
Old 10-08-2010, 11:47 AM   #10
mels
mels's Avatar
Thanks guys, I had read down through the wheel guide and didn't see the offsets for those three wheels that I'm asking about. Thanks for spelling out the Virgo and Draco, RC.
Still don't know about the Geminis, anybody?
They're looking pretty good on the car, but the rub up front with 205/55's mounted is a drag. Figure if I go with a 215/60 or 225/60 it'll be tons worse without adding spacers...
Not diggin' the wheel gap with the 205/55's.
*EDIT* Wondering if the offset value is cast right onto the wheel as I see on many others. Hmm...
Old 10-08-2010, 10:41 PM   #11
mels
mels's Avatar
OK, pulled the centercaps on the Geminis and it looks like they are a 20. IF that's what the "20ET" represents...
Thanks again, guys.
Old 10-08-2010, 10:46 PM   #12
Yep et=offset.
Old 10-09-2010, 07:19 AM   #13
mels
mels's Avatar
Thanks RC
Old 10-10-2010, 05:39 PM   #14
Freq
Freq's Avatar
Added. Do the Multi-Xs have a name?
Old 09-17-2020, 03:26 AM   #15
BeaverMeat
Necro bump!
Can access the spreadsheet...
Anyways I'm looking for a set of 740 wheels for my 240. wheel-size.com lists a 6.5x15 ET22 wheel for the 740. I am wondering what this wheel looks like?
BeaverMeat is online now   Reply With Quote
Old 09-17-2020, 09:18 AM   #16
buzz
To inspamity, and beyond!
buzz's Avatar
Its round with spokes.
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 09-23-2020, 02:38 AM   #17
Otto Mattik
Chief Bottle Washer
Otto Mattik's Avatar
Yep et=offset.
ET is from 'Einpresstiefe (basically translates to insertion depth)
