Old 11-11-2011, 05:47 PM   #26
volvogeek
I love this. I want to do it on a 240 but I'm having trouble figuring out how to actuate the vacuum valve.
edit: perhaps via the foot button? who uses the foot button when the AC is on? Nobody likes cold feet.
volvogeek is offline   Reply With Quote
Old 11-11-2011, 07:10 PM   #27
fidel
knox motorsports
fidel's Avatar
you need a heat/vent/fan control panel out of a 73' 140 (or other market 240), the heat/cold adjustment were vacume operated, not cable like the 74 140 and all US market 240's. i just went and looked to see if i have any left, but can't find one, maybe check with redwood chair or jimjmorris to see if they still have any.
fidel is offline   Reply With Quote
Old 11-11-2011, 08:27 PM   #28
gsellstr
gsellstr's Avatar
Hmm, really? I'll have to check into that. I didn't realize the 73 and 74 differed on that little detail, but that's very good to know!
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-03-2012, 09:33 AM   #29
ryank
ryank's Avatar
Mine control valve just broke changing hoses so I think i'm going to try this. To clarify the two ports furthest from the vacuum bulb go inline of the lower return line, the two ports closest to the vacuum bulb go in the upper supply line (stock location), correct? Were you able to use stock hoses, or did you have to buy some random bends to make it work? The stock valve sits with the port running vertically while this one it appears you have installed so they sit horizontally. Makes sense to T into the return line, but I assume you need to get a little more creative with the supply? Thanks.
'94 945T | '70 Alfa GTV 1750 | Ducati M800S | feedback
ryank is offline   Reply With Quote
Old 02-03-2012, 11:24 AM   #30
gsellstr
gsellstr's Avatar
You are correct on the installation direction. There's also a flow direction, should be marked on the valve, that'll need to go the same way as the stock one. You can run the factory hoses just fine, but you will need to cut out about 1.5" from the lower one to make room for the valve.
Old 02-03-2012, 11:25 AM   #31
Ryan_R
Originally Posted by jerryc View Post
So some basics that I think I gleaned; use this valve, GrpA the holes in the head, use a Hepu pump, and for a low/mid hp DD all will be fine, forever. That about right?
If you're gonna use a Hepu pump, buy all Volvo seals.... the top seal provided croaks within one year.
....of course, Hepu pump plus Volvo seals is more or less equal to Volvo pump in cost.
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
2011 XC60 3.2L AWD - Wife-mobile
Ryan_R is offline   Reply With Quote
Old 02-03-2012, 11:31 AM   #32
Ryan_R
Any idea what sorta car/vehicle this valve "goes" to? Pretty slick!
-Ryan
Old 02-03-2012, 02:56 PM   #33
gsellstr
gsellstr's Avatar
Posted up over on Brickspeed...
It's a GM part
Make Model Year Notes
Chevrolet Astro 1990, 1991, 1992, 1993, 1994, 1995 FRONT VALVE
GMC Safari 1990 FRONT
GMC Safari 1991, 1992, 1993, 1994, 1995 FRONT VALVE
Old 02-04-2012, 05:27 PM   #34
ryank
ryank's Avatar
So I just did this, had to hack up the hoses a little but it worked out nicely. The one thing I noticed though, was that it made no sense to install the valve with the flow of the coolant running the direction of the flow arrow on the valve. Installed that way it will act exactly like the stock valve, stopping flow at the valve. You have to install it backwards, so when the heat is off, it allows the flow of coolant to recirc as intended.
In looking at your install pics, you appear to have it in the same way I do (correctly) but the flow arrow is actually pointing towards the passenger side (not drivers side.) Not sure how exactly this is plumbed into the GMCs it was intended for, but clearly different for our application.
Thanks again for posting this, very glad I found it!
Ryan
Old 05-29-2012, 11:16 AM   #35
Lando
Arthur Digby Sellers
Lando's Avatar
Originally Posted by Volvoist View Post
Thumbs up!!
When mine blew and i replaced it with this IIRC.
http://www.truckerac.com/heater-valv...4az418495.html
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is offline   Reply With Quote
Old 08-31-2012, 12:06 AM   #36
Lando
Lando's Avatar
Just installed one of these on mine today.
Old 08-31-2012, 07:51 AM   #37
mels
mels's Avatar
Eliminated mine after it blew a couple years ago. ('87 745)
Mel & Cindy
1987 745 TI Automatic, daily driver
1994 945 NA Automatic, hangar queen
1973 Ford F250 Ranger XLT
1975 MG B
2002 SAAB 9-5 Turbo Linear Wagon, Wifes' daily driver
2003 SAAB 9-5 Turbo Linear Wagon, hangar queen
1975 FLHP / 1977 XLCR / 1979 FXEF / Schwinn Predator with a squeaky pedal
What if you woke up TODAY with only the things you thanked God for YESTERDAY?
mels is offline   Reply With Quote
Old 08-31-2012, 10:18 AM   #38
Lando
Lando's Avatar
I considered this, but I didn't want hot air blowing in on the highway, also my AC still works, so I didnt want to make that less effective either. So far the 4 port valve works as the 2 port for climate control, and I would imagine the pressure the valve is under is a lot less since and the back of the head has got to be cooler. We'll see how long it lasts.
Old 08-31-2012, 10:25 AM   #39
gsellstr
gsellstr's Avatar
I found about a 20* drop in temps on the back of the head, with a much more even temp spread vs. the stock valve (hooray for IR thermometers). Also the constant flow should allow for less pressure buildup.
Glad this thing seems to be getting out there a little more. Just about a year on mine, still doing well.
Old 08-31-2012, 10:28 AM   #40
Lando
Lando's Avatar
The only problem I ran into is the ports seem to be a bit bigger than 5/8". I didnt measure them, but it was MUCH harder to get the heater hose on the ports of the new valve than the old valve. It kinda gets in the way of my trans dip stick too, but not too bad. I probably just didn't cut enough hose off the return line.
Overall, Thumbsup. Anything is better than the ****ty valve that was in there. THat thing popping was an annual occurance.
Old 08-31-2012, 10:38 AM   #41
mels
mels's Avatar
Was a concern when I eliminated it, however as long as my temperature control is slid to the left, I find I have no heat blowing at all - in any mode (floor face windshield, A/C or vent)
Old 08-31-2012, 10:41 AM   #42
Lando
Lando's Avatar
Mine is one of those fancy auto units. It allows small amounts of air through all vents on the highway.
Old 08-31-2012, 11:30 AM   #43
saq
Do these have a manufacturer name somewhere, or at least country of origin?
I finally found the GM AC Delco version, it's part number AC15-5543. Not sure if there's the same junk vs OEM dichotomy in the GM parts world that appears to be in the Volvo world. Sadly, I finally found the right number after ordering the Motorcraft YG-136 replacement valve - though it might not be a problem for me as I'm more of a "Rolls Royce style" driver.
saq is offline   Reply With Quote
Old 08-31-2012, 11:48 AM   #44
Lando
Lando's Avatar
It's a Balkamp unit. I didn't look to see where it was made. The balkamp radiator cap I got was made in germany, and the radiator hoses were made in australia.
Old 08-31-2012, 01:08 PM   #45
gsellstr
gsellstr's Avatar
Don't recall where mine was made either, came out of the Balkamp catalog as well.
Also just found, not sure if it's the same valve, came stock, or what, by an early 90's Explorer had the same style valve, looked like 5/8 ports on all 4. Looks like it's a Balkamp 6601294, which shows 4 5/8" ports, but I haven't been able to figure out the operation of it. Sells for $19.99 from Napa though.
Old 09-01-2012, 10:12 PM   #46
mels
mels's Avatar
Oh, right on. My now gone '87 765 had that auto climate control. Hats off to you for finding a better replacement part for those who need it.
Old 01-16-2013, 07:12 PM   #47
DET17
Reformed SAABaholic
Just picked up this NAPA valve (660-1357). Still only $34.
Should be fairly obvious to the installer the the blocked port (nearest the plated actuator crank) goes TO the heater core....top line IIRC from the BB information.
Looking forward to keeping that hot water flowing thru the head at all times. Gary, yours still working AOK after 1.5 years?
Old 01-16-2013, 07:22 PM   #48
gsellstr
gsellstr's Avatar
Yup, not a hint of trouble thus far.
Old 03-14-2013, 11:40 PM   #49
thelostartof
unbalanced chemical
thelostartof's Avatar
Bump
Just installed this, works great so far, install was a PITA because of my giant intake manifold, a nathan intake would make life so much easier.
Everyone should do this on their 7/9, I shall update the 944 with this in the coming months
Old 12-06-2013, 12:52 PM   #50
Dan
Watching the World burn
Dan's Avatar
About to finally hook up the heater in my 740 (with SBC) this should work most excellent, thanks
1985 Chevy TPI V8 740.
