Old 12-06-2013, 02:40 PM   #51
gsellstr
gsellstr's Avatar
Enjoy!
Still rocking on my car since I did this write-up. Heater output still sucks with the alum. core, but it was worse without this valve.
Damn 28* weather....
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-06-2013, 06:02 PM   #52
Bensin
Garrett whine rules
Bensin's Avatar
Rock-on - Thanks for update
Stage Zero Is A Smooth Machine (I'm not a racer but I play one on TB) 1986 740 Turbo wagon
Bensin is offline   Reply With Quote
Old 12-06-2013, 06:20 PM   #53
lummert
lummert's Avatar
FYI: NAPA 660-1357 is the front heater valve for 90-95 Chevy Astro Van and GMC Safari Van.
Old 12-06-2013, 06:30 PM   #54
gsellstr
gsellstr's Avatar
Dammit lummert....j/k
Thought I'd put that in the first post waaaay back, apparently not. Engage edit mode....
Old 12-06-2013, 07:23 PM   #55
OldGrandpaTune
The Road Warrior
OldGrandpaTune's Avatar
I am still not understanding the function of that valve. After mine broke I replaced the hoses to the core and did not put a replacement back in yet. It was -10F this morning and the heater ran great and warmed up quickly.
I can see a marginal increase in how fast the coolant warms up without the heater core in the circuit, but is that all it does?
The new valve is a huge improvement as everyone I know with a 7xx had that original valve break at a horrible time, but is the work involved absolutely worth the effort?
Perry
"Every man...should periodically be compelled to listen to opinions which are infuriating to him. To hear nothing but what is pleasing to one is to make a pillow of the mind."
St. John Ervine
OldGrandpaTune is offline   Reply With Quote
Old 12-06-2013, 07:53 PM   #56
lummert
lummert's Avatar
Yeah, I guess you did.
Old 12-06-2013, 09:30 PM   #57
gsellstr
gsellstr's Avatar
the extra effort is simply cutting the other hose as well, so not much. this valve allows coolant to flow from the back of the head back up to the water pump when closed which aids the cylinder head cooling. when open it allows greater flow thru the heater core for better heat output.
Old 12-07-2013, 12:40 AM   #58
r0k0
r0k0's Avatar
i should do this while my head is off when i check why im running on 3 cylinders.. lol
1994 854 2.4 5 Speed - Crashed in 06
1990 744Ti - Sold to Nephew
1993 245 - SOLD
1991 744Ti - Project - 16T@15PSI, Brown Tops, Side Exhaust, Intake
1993 244 M47 - SOLD
1996 854 2.4 Auto - SOLD
1987 744Ti - SOLD
r0k0 is offline   Reply With Quote
Old 12-07-2013, 01:07 AM   #59
mafoose
Boost Addict
mafoose's Avatar
Dammit! I just replaced mine with the ****ty all plastic mushroom valve the parts stores carry (not OE style).
I've noticed the heater in the 745 isn't anywhere near as hot as the 242.
- 84 242 - 92 740 - 72 240z - 78 280z -
mafoose is offline   Reply With Quote
Old 12-07-2013, 01:27 AM   #60
hunterkent
hunterkent's Avatar
on my 91 940 i just tied the valve open...it keeps everything flowing and the heat still turns completely off when you spin it to the cold position on the dial, just cold blows through the vents
hunterkent is offline   Reply With Quote
Old 12-07-2013, 02:07 AM   #61
gsellstr
gsellstr's Avatar
But it doesn't blow COMPLETELY cold, which is an issue for those of us who live in climates that need AC during the summer. The 7/9 use a blend door setup for temp control with an on/off heater valve, where the 240's use a TXV, and the 850's run a constant flow setup. Tying the valve open is an option, though it still doesn't flow as much even at wide open as the GM valve does, simply by design.
Aside from that, the GM valve seems to be made of much better plastic (never thought I'd see the day when I wrote that phrase).
Old 12-07-2013, 02:58 AM   #62
745 TurboGreasel
745 TurboGreasel's Avatar
Hey, GM have a ton of experience with plastic.
Feedback
Old 12-07-2013, 09:39 AM   #63
r0k0
r0k0's Avatar
GM builds cars base on 80% plastic :P
Old 12-07-2013, 12:09 PM   #64
OldGrandpaTune
The Road Warrior
Ah hah! Something just clicked.
Old 01-04-2014, 01:18 AM   #65
jerryc
jerryc's Avatar
Garyyyy, Garyyyy, Garyyy.....
Thanks! just put this in, actually Bret did, and it worked! A bit of a fuss to fit it all in but it does go and works.
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 01-04-2014, 02:24 AM   #66
gsellstr
gsellstr's Avatar
Cool, another one on the road. Should see a little better heat now and AC come summertime. Enjoy!
Old 01-05-2014, 10:18 PM   #67
thevolvokid
142 whore
thevolvokid's Avatar
I'm having issues where I'm losing a bit of coolant (having to refill the overflow tank) and then the heat gets cold when at stop lights but blows fine when moving. I think my control valve is fubared. Looks like it's been working for everyone else I'll try this and maybe it'll help.
Thanks for the write up Gary!
90 745 Turbo, tuned by myself made 365 whp completing a 1/4 mile pass at 12.93 @ 105.xx. Not bad for a stock block w/ 265,xxx miles that runs lh 2.4 and ekz
thevolvokid is offline   Reply With Quote
Old 01-08-2014, 01:35 PM   #68
DET17
Reformed SAABaholic
Originally Posted by DET17 View Post
Just picked up this NAPA valve (660-1357). Still only $34.
Should be fairly obvious to the installer the the blocked port (nearest the plated actuator crank) goes TO the heater core....top line IIRC from the BB information.
Looking forward to keeping that hot water flowing thru the head at all times. Gary, yours still working AOK after 1.5 years?
Well have had this for a year now...and I'm staring down the heater core R&R on my 9 series. This NAPA valve is going in at the same time. Just got to get my T8 lighting installed in my front bay on the shop, and this task is next. Will post some pics once installed....can't wait to get some heat in the old Swede, as it was 5*F here yesterday (that's DAMN cold for the Atlanta area).
Old 02-15-2014, 09:29 PM   #69
DET17
Reformed SAABaholic
Today was the day! I've gutted the dash of my 940 to get the friggin' heater core out. Cleaned out the obstructions in the area of the heater core connections, and after measuring, cutting hoses, the NAPA valve is in! I"ll get my pics loaded up and add them to this post. The male ends of the NAPA valve are sure bigger than the Volvo hoses...they go on, but it's tight.
NOTE - the 94 Volvo control valve I removed was normally open (no vacuum). I've installed the NAPA control valve the same way. Without a vacuum signal from the climate control system, the coolant will be flowing thru the heater core. Vacuum on the NAPA valve will block the inlet to the heater core, and bypass the head flow back to the waterpump return pipe. As someone noted early in this thread, the control valve may be closing the flow during MAX AC. I won't know for sure until I test mine to see what conditions are actuating the valve.
Top pic shows the valve closed by vacuum signal:
[IMG][/IMG]
Nice clean install, looks OE:
[IMG][/IMG]
View showing the auto dipsticks installed, no clearance issue:
[IMG][/IMG]
Old 02-15-2014, 11:18 PM   #70
gsellstr
gsellstr's Avatar
You are correct, they do default to normally open, with vacuum closing them, same for the earlier ones, but vacuum is applied once the car is running and providing vacuum to the system. That way if you have no vacuum due to a line issue or something the default will allow for flow, and your vents will default to defrost.
Glad it's in!
Old 03-01-2014, 03:30 PM   #71
jerryc
jerryc's Avatar
ok so now it appears the heater core is leaking. If so this means my 93, 94, and 95 all have failed.
This one is the 94 with the Astro valve. So question; does this valve bypass the core so that if I don't use the heat, I can drive the car without doing anything else? til I get time to fix it.
Old 03-02-2014, 03:11 AM   #72
gsellstr
gsellstr's Avatar
You will still have coolant pressurizing the core, just not flowing with the Astro valve. It simply directs flow either to return to the pump or thru to the core, but even when it's 'closed' so no coolant flows to the core, the other side will still have pressure. Time to install a bypass hose...
Old 03-02-2014, 03:42 AM   #73
jerryc
jerryc's Avatar
Dang. Thanks Gary.
Old 03-02-2014, 08:43 AM   #74
DET17
Reformed SAABaholic
Glad it's in!
Gary, my valve didn't actuate until I turned the AC on MAX (temp set at the bottom CLICK). The my climate control applied vacuum and it bypassed the heat core (matrix for UKers). However, when I switched the AC off, and returned to cool vent it stayed BYPASSED. Only when I shift the heat control to HOT did it remove the vacuum signal and the coolant again flowed thru the core.
It works! Putting my core back on the road this week and I'll report if any deficiencies.
Jerry, I just went to heater core hell and back....hope to GOD I never make that trip again. I'll have some pics up in my build thread soon.....what a job!
Old 03-02-2014, 10:41 AM   #75
koreycon
koreycon's Avatar
Pretty awesome. Thanks
koreycon is offline   Reply With Quote
