Old 11-15-2015, 07:31 PM   #101
Volvo Thief
Volvo Thief's Avatar
Well mine broke in half. I can assume its ok that I bypass this valve completely in my 97 V90 if I don't plan to use my air conditioning? But will the heat be strong enough for the winter?
Volvo Thief is offline   Reply With Quote
Old 11-15-2015, 08:59 PM   #102
gsellstr
gsellstr's Avatar
With the valve bypassed completely then you will have full flow thru the core, so yeah, you should be nice and toasty. I'm not sure if the V90 uses the 7/9 style heater setup or the 850 style. The 850's run a constant flow core using just a blend door for temp control.
Your GM valve broke? Any chance of pic's? We're getting to be a few years into this mod so I'm curious to see what the failures are on these. I've had to replace mine after it started seeping from the shaft, otherwise no issues.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-15-2015, 09:07 PM   #103
Volvo Thief
Sorry, I never used the modified one. Mine had to be original oem at 221k. Im just interested in bypassing it completely.
Old 11-15-2015, 10:33 PM   #104
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
The GM valve is 28 bucks for an OE gm one on amazon iirc. Works well. Bypassing should be no issue
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 04-18-2016, 04:52 PM   #105
Ursan
Bored Member
Ursan's Avatar
Doing this soon.
how psi a stock can support?
I admit I'm stupid...
Old 04-21-2016, 12:28 PM   #106
zimmerdale
I'm trying to sort out the various options for this part. From what I'm finding, there seem to be two different models, one labeled as "bypass" and one as "non-bypass."
The one that I think you all are using is:
NAPA 6601357
Murray 74607 (O'Reilly)
Everco 74607 (Autozone)
Four Seasons 74607 (Amazon)
These all seem to be the same part (and all made by Four Seasons). They all say something along the lines of "Vacuum Closes Heater Valve" and "Non-Bypass."
The other option, and the one I'm thinking of using, is:
AC Delco 15-5543 (Amazon)
Or on Ebay for $27
"GM Original Equipment Heater Bypass Valve"
This one says "When the heater valve is closed, the bypass valve diverts the coolant flow back to the engine. The valve maintains coolant flow through the thermostat housing to ensure correct operation of the thermostat."
Am I missing something? Are these labeled wrong, or are some of these bypass valves and some of them not? Are you installing the non-bypass ones backwards to make them work, or are these all exactly the same?
zimmerdale is offline   Reply With Quote
Old 04-21-2016, 12:40 PM   #107
gsellstr
gsellstr's Avatar
Incorrectly labelled on the non-bypass units. By design they either allow coolant to the core, or to bypass the core. The stock valve is a non-bypass, that either allows coolant to flow thru the core, or not flow at all.
Old 05-26-2016, 01:46 PM   #108
DarkKratoz
DarkKratoz's Avatar
Got a month out of my most recent scantech HCV. Off to the parts store
Update with my thoughts from the job: Getting the hoses on there kinda sucks. Bring some silicone lubricant to help things along. How do hose clamps disappear? Get 4 new hose clamps, trust me. And you're probably best off getting new hoses on at the same time. Rubber, not silicone. Looking forward to 5+ years of not changing the damn thing though!
1995 Volvo 960 - Absolute turd that I despise
DarkKratoz is offline   Reply With Quote
Old 06-11-2016, 07:34 PM   #109
Johann245
Volvoholic
Johann245's Avatar
So I just picked up this, did I grab the correct one? http://m.oreillyauto.com/h5/r/oap/si...2708&ppt=C0331
Real Wood Trim
"Classic" Project 1993 Classic 245 with 29” BFG KO2s
Feedback
Johann245 is offline   Reply With Quote
Old 06-11-2016, 11:32 PM   #110
Johann245
Volvoholic
Johann245's Avatar
Did i do this right?
Old 06-11-2016, 11:44 PM   #111
gsellstr
gsellstr's Avatar
Yup, that's the ticket.
Old 06-11-2016, 11:47 PM   #112
Johann245
Volvoholic
Johann245's Avatar
Yesss
Old 07-21-2017, 12:01 AM   #113
Ursan
Bored Member
Ursan's Avatar
Doing this soon.
This time I mean it.
Old 07-25-2017, 05:19 PM   #114
Ursan
Bored Member
Ursan's Avatar
Which hose is which on this?
My inlet hose almost turns back on itself and the outlet isn't much better.
Originally Posted by thelostartof View Post
Bump
Just installed this, works great so far, install was a PITA because of my giant intake manifold, a nathan intake would make life so much easier.
Everyone should do this on their 7/9, I shall update the 944 with this in the coming months
Old 07-25-2017, 09:11 PM   #115
gsellstr
gsellstr's Avatar
Look at your existing plumbing before you remove it. The top pair on the new valve go into the bottom port of the heater core, bottom pair go into the top port of the heater core.
Old 09-09-2017, 08:20 PM   #116
Ursan
Bored Member
Ursan's Avatar
Doing this now. Problem is I'm using hoses from do88.se and they aren't "quite" right. I'm going to get imaginative.
Old 09-11-2017, 10:41 PM   #117
will740turbo
On the one hand, I believe there is also a "bypass" passage for the thermostat, which closes when the thermostat opens. I'm surprised that this is even an issue. The pump is set up to feed water from inside the head to the lower rad hose, and to ultimately pull that water back through the upper rad hose, head, and block, and optionally heater core. Maybe that one passageway that is/n't tapped if the valve is closed makes the difference, but I'm skeptical.
When you were checking head temps, was the original design valve new or old and crappy? Was the heat on? If the only difference in temps is from coolant flowing, then disconnecting the vac line to the heater valve should open the valve and give you the same drop in temps in the back of the head.
On another note... I'm never putting a plastic control valve in my volvo. There's an ACDELCO all-metal version. The OE design was all-metal. This plastic business is to reduce manufacturing costs... and maybe help accelerate the death of older cars to sell more new ones.
will740turbo is offline   Reply With Quote
Old 09-11-2017, 11:52 PM   #118
gsellstr
gsellstr's Avatar
The temps measured at the head were taken with a fresh replacement OE style valve that I did confirm had a full range of movement before install. Temps with the valve closed and open were taken. With the OE valve closed, as used in normal operation were approx. 20-30* higher than with the GM valve installed, with the valve in it's normally closed position as well.
At the time I was looking for a replacement, I did see the metal version but had no specs on it, plus the one place I was able to find info on it was unable to attain one, their supply chain was out of stock.
When mine is due for replacement the next time, I'll see if I can find the metal one, assuming the inlet/outlet pipes are indeed the same size.
Old 09-12-2017, 11:35 AM   #119
Ursan
Bored Member
Ursan's Avatar
The concept makes perfect sense. The outlet from the head (with the stock valve) gets blocked off when the AC is on MAX. If the coolant can't flow, it gets hotter there (likely on the hottest days)
With this GM valve, the coolant is allowed to continue on it's way back to the water pump (and oil cooler if it's a coolant style) and just ignore the heater.
That said, I'd prefer an all metal one. But I wouldn't know how to even look it up.
Old 09-12-2017, 02:59 PM   #120
gsellstr
gsellstr's Avatar
Actually it's not even just with the AC on max. Any time the temp slider is on the full cold position, the heater valve is closed. Once you crack it open just a hair, it opens the valve. I usually leave mine cracked just a little just so the core does a little cooling, except on the hot days.
I'll have to look for a metal one at some point...
Old 09-12-2017, 06:09 PM   #121
lummert
lummert's Avatar
I have a GM heater bypass valve installed inline with the OE valve. When the heater valve is closed the bypass valve bypasses the OE valve. Works perfectly.
Old 09-12-2017, 11:39 PM   #122
swedishiron.com
I sell Volvo parts!
Got a part number for this?
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 09-13-2017, 11:35 AM   #123
PCH
PCH's Avatar
If you do google search for "heater bypass valve" there are few metal versions but without the actuator. They are mostly from older American cars that used the cable instead of vacuum. I'm sure it's possible to adapt them though.
Old 09-13-2017, 01:50 PM   #124
lummert
lummert's Avatar
Maybe rig up a choke cable to operate on of these.
Old 09-13-2017, 06:29 PM   #125
PCH
PCH's Avatar
Pretty sure one can rig up a bracket for the vacuum actuator. If using metal valve is a must that is. Plastic unit looks fine to me, very compact and will not corrode.
