Old 08-28-2020, 02:22 PM   #1
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Default Drain plug glued to the oil pan - how should I approach?
It's me again, with my problem child 144. Seriously, the problems never end.
Anyway, I went to drain the oil from the B20, and I couldn't get it to move at all. I was reaching in with a long wrench from inside a wheel well (can't really jack up the car enough to get underneath), so I reached in with a camera to see if the bolt was totally gacked.
Correct me if I'm wrong here, but this looks like it's been siliconed to the pan.
Any ideas on how to get this off?
Doing the wrong thing the right way.
Originally Posted by redblockpowered View Post
Will you do $14.99 shipped?
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
fatcatbestcat is offline   Reply With Quote
Old 08-28-2020, 02:49 PM   #2
Khrrck
Professional Amateur
I would say, figure out how to jack the thing up enough to get under and scratch at the unknown "stuff" - see if it's softer, like silicone, or hard like epoxy. If you're lucky it's just silicone added by someone who couldn't get it to seal or was missing the washer...
If you're unlucky someone has J-B welded it on there.
A good angle and a longer lever (breaker bar) would be my first attempt. Gasoline or brake cleaner may work to help loosen silicone. Unfortunately epoxy is pretty chemical resistant so heat would be the only available step up for that. Keep an extinguisher handy. Either way expect the threads to be munged up, you may have to re-tap to a larger drain plug size.
Worst case you will need a new pan but I think that's unlikely.
'87 240 budget wagon.
Old 08-28-2020, 03:07 PM   #3
fatcatbestcat
Professional Hack
Got another look underneath and scratched at it with a screwdriver (then my fingernails).
Feels hard like epoxy.
Old 08-28-2020, 04:30 PM   #4
Mr. V
Mr. V's Avatar
Soak the area in denatured alcohol or paint thinner to try to soften it up.
Heat it with a heat gun (not an open flame).
Use a stout ratchet wrench with the same number of points on the wrench as on the bolt head: using a cheater / breaker bar then remove it.
Old 08-28-2020, 06:15 PM   #5
iamrolling
That bolt looks big enough that even a good epoxy job shouldn't be able to withstand a good twist with a 6 point.
iamrolling is offline   Reply With Quote
Old 08-28-2020, 06:37 PM   #6
matt b
Leverage is going to be key in all this. Hopefully you find a way to raise the car safely so that you can crawl underneath it and use a long breaker bar.
That thing has been fighting you tooth and nail!
Old 08-28-2020, 09:41 PM   #7
nel621
Get a 6 point wrench securely on it then give it a solid whack. It should break free.
Old 08-28-2020, 09:47 PM   #8
2turbotoys
Hybrid moments...
2turbotoys's Avatar
I use a 6 point socket, 1/2" drive if you have it, and a long pipe on the socket wrench or breaker bar. A jack handle works well, I usually only need the upper half of the handle. It will not hurt anything if it is silicone, rtv, or just over tightened. I just did that today on a 240. Do get a new copper sealing washer, and maybe a new magnetic drain plug, that stuff is cheap.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-29-2020, 12:01 AM   #9
tintintin
Your photo is kind of blurry but it sure looks to me like a aluminum washer. Can you borrow/rent a bigger jack and jack stands? Who changed the oil last time? Worst case, maybe you use a Mityvac this time.
Old 08-29-2020, 12:14 AM   #10
James M
Bored member
James M's Avatar
Did someone say 1/2 drive impact?
James M is online now   Reply With Quote
Old 08-29-2020, 03:32 AM   #11
TurboDutch
You just did :P
TurboDutch is offline   Reply With Quote
Old 08-29-2020, 05:20 AM   #12
iamrolling
Originally Posted by tintintin View Post
aluminum washer
I think you're right. The points on the hex look like they're digging into it the same way they do on my 940 drain bolt washer.
fatcat, it's probably just in there really tight. Try using a mirror to make sure the socket is squarely on the bolt, and turn the wrench while holding it as straight as you can. If it still doesn't move, continue pushing counterclockwise and smack the end of the wrench with a mallet. If it still doesn't want to move, you should make sure that the bolt wasn't attached using a welder.
Old 08-29-2020, 02:43 PM   #13
Stock drain plug torque is 45ftlbs.
Old 08-30-2020, 01:26 PM   #14
fatcatbestcat
Professional Hack
The bolt head is already too stripped for me to actually get it off. A wrench + hammer just resulted in the wrench falling off.
I do have a temporary (knowing me, permanent) stopgap solution though!
Bought one of those cheap vacuum oil drain pumps, and threw the intake hose down the dipstick tube. Which then got stuck and broke off inside the tube.
I'm now able to drain through the distributor slot on the block, but I need to figure out how to remove the broken hose from the dipstick tube, since I imagine it'll just turn into a massive oil geyser if not addressed.
EDIT:
Old 08-30-2020, 01:38 PM   #15
culberro
culberro's Avatar
A borrowed/rented/loaned impact and the appropriate sized 6pt socket will remove it.
Old 08-30-2020, 02:11 PM   #16
TurboDutch
Oh boi you've gotten yourselve in some trouble for nottin there...
Old 08-30-2020, 02:13 PM   #17
fatcatbestcat
Professional Hack
Fixed the tube inside the tube problem. Just pushed it down into the oil pan and retrieved it with some pliers. It does seem that I'm going to have to drain oil through the distributor slot for now, so that sucks.
Old 08-30-2020, 02:15 PM   #18
I bet it's stripped, post in wanted for another B20 pan.
Old 08-30-2020, 02:17 PM   #19
TurboDutch
Oeff that sound like you where really lucky there retrieving that piece of plastic!
Old 08-30-2020, 03:39 PM   #20
Mr. V
Mr. V's Avatar
Since the pan's bolt head is too stripped for a ratchet wrench, that leaves you with Vise Grips.
Not nearly as good, but try them, and of course you'll need a bigger hammer.
Old 08-30-2020, 03:56 PM   #21
apachechef
Burnt Sierra Madre
wait, how did you grab it out of the pan with pliers? from what hole?
Dammit, Lummert.
Old 08-30-2020, 03:58 PM   #22
fatcatbestcat
Professional Hack
I pushed it all the way down from the dipstick tube with a large nail, and I think most of it just ended up in the pan. The engine's in the car, and I was just fishing blindly underneath a main bearing.
Old 08-30-2020, 04:28 PM   #23
apachechef
Burnt Sierra Madre
from the distrib hole?
Old 08-30-2020, 06:31 PM   #24
billkaz
Bomber Dream
billkaz's Avatar
https://www.amazon.ca/Vise-Grip-Lock...826606&sr=8-12
These are awesome for grabbing and holding onto bolts, even if slightly rounded off.
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 08-30-2020, 07:55 PM   #25
2turbotoys
Hybrid moments...
2turbotoys's Avatar
What in the heck is happening here?
The proper tool for the stripped bolt is a turbo socket.
https://www.amazon.com/M%C3%A1ximum-...05298090&psc=1
