Old 08-31-2020, 09:10 PM   #1
iamrolling
Default Shift Lever Bushing Disintegrated
My AW71's shifter pin fell out along with the bushing. I was able to recover the pin, but the bushing is unusable. If I put a new e-clip on the pin, will I be able to drive it for a few days with no bushing? Or should I just leave it in park until I can order one? Is there any commonly available part that I can use so I don't have to order a bushing and wait for it?
1993 940 Turbo (Mostly stock)
WARNING: I am not a professional mechanic, and you should only base your repair decisions on my advice if I'm not corrected by someone who has worked on more than a few Volvos.
iamrolling is offline   Reply With Quote
Old 08-31-2020, 09:44 PM   #2
hessam69
You can still drive. It will just mean an awful lot of play in the shift linkage
Old 08-31-2020, 10:24 PM   #3
2manyturbos
Both IPD and FCP have those bushings in stock. Get 2. One for each end of the shift linkage.
Old 09-01-2020, 04:43 AM   #4
iamrolling
Thanks, guys. I have a set of the bushings on the way.
Old 09-01-2020, 01:55 PM   #5
kyote
Living The Dream
kyote's Avatar
Thin slice of fuel hose will do in a pinch.
Old 09-01-2020, 06:07 PM   #6
iamrolling
kyote, that worked. I knew I was saving that last inch of Barricade MPI for a reason. I'll explain what I did.
0. ONLY LEAVE IT LIKE THIS UNTIL YOU GET THE NEW BUSHING, OR YOU WILL PROBABLY LOSE THE PIN ON THE ROAD SOMEWHERE.
1. Cut off 8.5mm of 5/16" or 8mm fuel hose with an inner braid.
2. Slice it down to the fabric, and peel off the outer layer.
3. Put some lithium grease inside the tube, and insert it where the bushing would go.
4. Swing the shifter arm over the tube and insert the pin.
5. Install circlip.
It's still a little hard to pull the shifter because it's very slightly loose in the bore, but it feels like it will survive until I get the new bushing.
Old 09-01-2020, 06:14 PM   #7
kyote
Living The Dream
kyote's Avatar
Originally Posted by iamrolling View Post
kyote, that worked.
Even a blind hog finds an acorn every once in a while ;)
Old 09-01-2020, 06:36 PM   #8
iamrolling
It was a great stopgap solution. Thanks.
Old 09-12-2020, 06:38 AM   #9
iamrolling
My bushings arrived, and they sure are large compared to the openings they're supposed to go into. The FAQs suggest soaking them in hot water to make them more pliable, but are there any other tricks in case that isn't sufficient? What are the odds on destroying the things trying to install them? Should I lubricate them with something like lithium grease, or will that cause them to rapidly decompose?
Old 09-12-2020, 03:04 PM   #10
2manyturbos
Warm them up, spray the bushing and the hole in the linkage with Windex, use something like a straight blade screwdriver that doesn't have any sharp edges to collapse the bushing towards the hole in the middle. They will go in.
Old 09-12-2020, 08:15 PM   #11
iamrolling
That worked perfectly. It wasn't even a fight. Also, the improvised fuel hose bushing wasn't even scored when I removed it. Gates makes a good fuel hose.
