Old 09-08-2020, 06:40 PM   #1
bmdubya1198
Default New head gasket, coolant in intercooler piping, milky PCV
Here we go again... this car is driving me nuts. I recently replaced the head on my 940 with a freshly resurfaced 530 NA head that I had on hand, and since then it's been consuming coolant (and running very poorly, but no worse than before hand). Every time I drive it, I fill the coolant to the full mark, and when I get home is at the low mark. Same thing every time, and I've put probably 200-300 miles on it. No coolant leaks that I can find ANYWHERE. System holds pressure when I test it.
I've noticed a little milky oil at the top of my dip stick, but not really in the oil. Maybe a little streaky, but nothing major. After removing the IC piping today to check for boost leaks, I noticed a significant amount of oil (turbo is shot) and some coolant droplets in the elbow just before the throttle body. The PCV hose to the PTC is full of milky residue, and when I pop the hose off the oil trap, it's full of it too. The oil in the head looks fine when I pull the cap, but there is some milkiness on the cap itself. I figured before that it was just moisture from short drives, but this has persisted since I finished the head gasket job. Needless to say, I'm fed up with this car.
I'm pretty certain the head gasket is leaking, but why? I used an AJUSA head gasket kit and the cylinder head was perfectly clean and flat when I installed everything. I cleaned the block surface the best I could. Maybe there's a problem with the gasket itself?
Compression numbers are fine, still a little low on cylinder 1 just like it was before. Shaky vacuum gauge at idle like always. No issues I can find on that end, I have a whole long thread on that issue. All I can think is that the rings on cylinder 1 are totally shot since I have a good amount of crankcase pressure.
Here are a couple pics of the mess.
2000 V70R Venetian Red/Black M56 swapped
2003 S60 2.4T Silver/Black
1991 944 Turbo Dark Green/Beige
1992 245 Base White/Beige
1993 944 Base Beige/Beige- Sold
2000 S70 GLT Mystic Silver/Taupe- Sold
1998 V70 GLT Black/Beige- Sold
1998 S90 Silver/Gray- Sold
1988 744 TI M46- Sold
1995 854 GLT Auto- Crushed
2001 S60 2.4T Black/Black- Sold
bmdubya1198 is offline   Reply With Quote
Old 09-08-2020, 06:47 PM   #2
There is no problem. I got oil into my coolant when I had the head off, and I still haven't got the gunk outta the tank from the contamination.
Old 09-08-2020, 07:57 PM   #3
bmdubya1198
Good point, that's definitely a possibility. When I check the dip stick, the oil itself looks pretty good.
I'm still wondering where the heck the coolant is going. My only other thought is the heater core, but I don't have any coolant leaking onto my floor.
Old 09-08-2020, 08:56 PM   #4
Get a coolant pressure tester on there.
Old 09-08-2020, 10:26 PM   #5
bmdubya1198
I'll have to try it again. I wasn't able to find any leak the last time I pressure tested it.
Old 09-09-2020, 11:03 PM   #6
bmdubya1198
Well I think I found the problem... definitely a leak on the back left corner of the head, right under the #4 plug. It looks to be coolant, but it's hard to tell. The block is definitely wet.
The dipstick looks pretty milky too now after a drive.
Old 09-10-2020, 11:36 AM   #7
I had a core plug leak back there. Get a mirror in there.
Old 09-10-2020, 12:02 PM   #8
bmdubya1198
I’ll take another look, but it looks like it’s pretty obviously coming from the head gasket.
Old 09-10-2020, 12:14 PM   #9
Try retorquing the bolts.
Old 09-10-2020, 01:16 PM   #10
bmdubya1198
I'll pull the valve cover and see if that'll help. From what I've read, it's a bad idea since they're torque-to-yield, but it might help.
Old 09-10-2020, 01:32 PM   #11
iamrolling
You'll be fine. I had to loosen mine and start over when I blew up my torque wrench in the middle of angle torquing them.
1993 940 Turbo (Mostly stock)
WARNING: I am not a professional mechanic, and you should only base your repair decisions on my advice if I'm not corrected by someone who has worked on more than a few Volvos.
iamrolling is offline   Reply With Quote
Old 09-10-2020, 06:46 PM   #12
bmdubya1198
Retorqued the head bolts... seems to be leaking ever so slightly more now. Wonderful! I just cracked them slightly loose, then torqued them in stages per the specifications (15 ft. lb., 43 ft. lb., 90*).
Now the car is hesitating a little bit with steady throttle while cruising. It never ends!
Old 09-16-2020, 11:18 AM   #13
bmdubya1198
Did a compression test the other day. Nothing points to a combustion leak (although I can smell coolant while driving it) but it's definitely still leaking from that corner. I'll keep the hesitation related stuff in my other thread that's already far too long!
Old 09-16-2020, 11:33 AM   #14
F*ck 12
Difference between torque to angle and torque to yield:
https://www.onallcylinders.com/2016/...gle-fastening/
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 09-16-2020, 01:39 PM   #15
bmdubya1198
Good article, just from a quick scan it makes a lot of sense. I probably should have cleaned up the threads in the block a little more.
