Old 09-12-2020, 02:02 PM   #1
jherguth
Default Weird Idle and Turbo issue
Ď83 GLT Turbo. Cold start, starts right up, no problem. Once is starts to warm and hits that second stage it will stall if I donít keep giving it gas. Once itís warmish, if I start to drive, it will lag and feel almost like itís not getting fuel. Weird. Where do I even start? I replaced the IAC valve when it had a ridiculously high idle and it was good for maybe 6 months.
Also, different issue altogether, my turbo will not get over 50% boost no matter how hard I push it. What could that be?
jherguth is offline   Reply With Quote
Old 09-15-2020, 08:25 PM   #2
espbassist88
espbassist88's Avatar
I'm not too sure about the idle issue, as I am chasing my own idle issue too on my 86' 740 Turbo. The boost issue sounds like a leak issue somewhere within the intake/intercooler route, or maybe a wastegate issue.
espbassist88 is offline   Reply With Quote
Old 09-15-2020, 11:20 PM   #3
Mr. V
Mr. V's Avatar
A high idle could be from a bad coolant temp sensor or its wiring.
Old 09-17-2020, 11:04 AM   #4
jherguth
Fuel pump is shot. Its been wheezing for quite a while now so assuming the in-tank pump failed awhile ago.
