Old 09-13-2020, 11:26 PM   #1
Dekoda244
Exclamation Leaky main fuel pump
Installing a new main fuel pump and it’s been leaking every time I put it all back together. New hoses, clamps, fuel pump and leads. It leaks from under the banjo to the check valve, with proper new copper washers in between everything. The old pump check valve won’t fit in the new pump and the old pump is shot, new pump works and pulls fuel but why the leak?
1982 244 Kjet b21f
Dekoda244 is offline   Reply With Quote
Old 09-14-2020, 01:34 AM   #2
MasterBlaster
With new washers, don't just tighten it once and hope for the best. I find it works a lot better to go tight - loose - tight - loose - tight - loose 6 or 7 times (you should notice the wrench move a bit further each time), before the final good-n-tight. Helps the washer slowly "squish" into the shape it needs to be.
500,000 km so far...
Old 09-16-2020, 04:35 PM   #3
lummert
lummert's Avatar
Sounds like a universal replacement aftermarket pump if the check valve has different thread size.
Old 09-16-2020, 09:56 PM   #4
Otto Mattik
Chief Bottle Washer
Otto Mattik's Avatar
Thanks for posting this advice, after doing fuel pumps a few years back, I used this method and it worked perfect.
