Old 09-15-2020, 09:08 PM   #1
VolvoScout
Default Replacing Early Volvo 240 Quad Headlights
Quick video I put together since I had to replace my low-beams.
https://www.youtube.com/watch?v=26qC...D-XWc&index=27
Old 09-15-2020, 09:17 PM   #2
philski o'flood
philski o'flood's Avatar
neat
philski o'flood is offline   Reply With Quote
Old 09-17-2020, 08:55 PM   #3
daniels740
Just a tip: a lot of bulbs from RockAuto are dirt cheap. I replaced all 4 of my quad headlights on my '89 740 with the Philips CrystalVision Ultra ones that they sell and they are, IMO, worth the price.
For ~$8 a pop, these provide a nice looking whiter light. They are not the brightest ones out there, though, so keep that in mind.
Low beams: https://www.rockauto.com/en/moreinfo.php?pk=6319587
High beam: https://www.rockauto.com/en/moreinfo.php?pk=6319584
daniels740 is offline   Reply With Quote
Old 09-17-2020, 11:31 PM   #4
84B23F
84B23F's Avatar
Originally Posted by daniels740 View Post
Just a tip: Philips CrystalVision Ultra
Those types will burn out sooner than a stock Halogen...so YMMV depending upon...
Video: https://www.youtube.com/watch?reload=9&v=4aGHkW59TNM
Old 09-18-2020, 12:15 AM   #5
BeaverMeat
Kinda on topic, but off topic.
Has anyone installed good quality LED or projector lights on the quad light cars? I’m not talking about the cheap eBay or Amazon garbage.
It this video is good to know. The fronts of these cars are like LEGO in comparison to most other cars. lol
Old 09-18-2020, 12:28 AM   #6
Sylvania Performance FTW.
Old 09-18-2020, 09:29 AM   #7
84B23F
84B23F's Avatar
Originally Posted by BeaverMeat View Post
Kinda on topic...
If full voltage is not getting to headlamps, your lights will appear dim. Alternator output voltage needs to be checked, along with ground(s) cleaned for headlamps and vehicle, and hot side voltage checked at headlamp's positive wire when circuit is loaded.
Headlight wiring for halogen uses some type of resistor wire so alternator voltage is reduced at headlamp terminal. Long story short, buy/get one headlight plug, plug it in to one side, and hook it direct to battery to battery terminals, then see the difference between a factory wire headlamp on the other side when engine is running at say 1,000 RPM.
Again, alternator voltage output can make a big difference, along with dirty grounds. Relays shoot craps also.
