Old 09-17-2020, 03:17 AM   #1
BeaverMeat
Default electric lock repair
My 1981 245 has the electric door lock/unlock feature when you use the key.
The rear passenger side door lock doesn't function 100%. The servo doesn't have enough power to lift the lock high enough to unlock the door.
New servo, or does it need some lube?
Old 09-17-2020, 10:14 AM   #2
kyote
Living The Dream
kyote's Avatar
I replace them with Universals or good used if available. A 15 dollar remote lock kit makes it feel like a new car also, highly recommend!
Old 09-17-2020, 12:08 PM   #3
cleanflametrap
cleanflametrap's Avatar
Two major issues I've found. One, the wire in the door jamb gets worked back and forth so much most of the conductor strands are broken, so it can't carry the current needed to operate the actuator. Not as likely in a rear door for most folks.
Two, the rubber boot dries out and breaks allowing water into the actuator. Needs a good clean out and ideally, a new boot. Where do you get those? Got me. Maybe others know where to get new actuators. I still have a spare or two from when the yards were full of these things.
Like kyote, I also recommend keyless entry, because the wiring to the button and key switch falls apart, and because beep-beep. They are inexpensive and easy to add http://cleanflametrap.com/keyless3.html
-Art
Old 09-17-2020, 04:05 PM   #4
BeaverMeat
That would make the wife happy, lol. She's upset it doesn't have keyless entry. lol
Old 09-17-2020, 06:56 PM   #5
TestPoint
TestPoint's Avatar
Default Remote locks
There is a detailed how-to on the 'Articles' forum.
http://www.turbobricks.com/forums/sh...d.php?t=224742
I converted both my 240's to remotes. Not at all difficult.
Ford V8 Conversion Manual -
Old 09-17-2020, 07:41 PM   #6
2 old for this
Take the disc out. Clean all contact points. If you are going out to update to keyless go the extra step and install a remote start.
Old 09-22-2020, 04:02 AM   #7
Remote start is dangerous. I recommend against it.
I have been trained to pop the hood to disable remote start when working on a vehicle. There have been cases when a customer has started an engine with the app on their phone, or a spare transmitter, while somebody is working on the car.
Adapting a remote start to an old car is asking for trouble.
Old 09-22-2020, 11:27 AM   #8
Khrrck
Professional Amateur
e: nvm, I missed a post
'87 240 budget wagon.
Old 09-22-2020, 11:47 AM   #9
BeaverMeat
Looking into the remote conversion... my wife will like that. She’s been complaining about the lack of features. “It doesn’t have heated seats to keep my bum warm”... geez, we’re spoiled people. Back in my day people were happy to have a radio. lol
Old 09-22-2020, 01:20 PM   #10
I recall the thread where a 240 Turbo (manual trans) started in its own and attempted to jettison itself thru the garage door!
He had left it in gear and the wiring harness shorted out and the starter engaged.
Old 09-24-2020, 06:42 AM   #11
cleanflametrap
...Adapting a remote start to an old car is asking for trouble.
Not sure how remote start got into this thread, but I agree. Had it in my first personal 240; it was a convenience on those cold, cold mornings. Pocket started once. Just imagine if I'd parked it in the garage.
