SnakeRacingCo
- Jan 9, 2018
- Toronto, Ontario, Canada
So, the bottom bushing in my shifter blew out completely, and I had to replace all the bushings in the assembly. Fought with the shift pin for ages, tried a bunch of different things trying to get it out but just couldn't make it happen. Even got some plate steel and tried to push it out by remaking what I understand is the Volvo tool to remove it, to no avail.
Decided to try disconnecting the shift rod at the transmission end rather than the shifter end. Was a bit finicky but took maybe 5 minutes and then just removed the entire assembly out of the bottom of the car, then hammered on it outside the car.
To anyone struggling with the shift pin: try just disconnecting the whole shift rod. Saved me a whackload of time and headache. Replaced all the bushings and now feels like new
If there's anything that makes this the wrong way to do things, someone please let me know but it seems so much easier.
