Old 08-21-2012, 01:46 AM   #1
ahigdonchad
ahigdonchad's Avatar
Default Tranny mount replaced on my 245dl, driveline now rubs
I had an exhaust put on my 1984 245dl b23 today and when I did the mechanic told me my tranny mount was toast. On the way home from the exhaust shop the rubbing noise started and i assumed the exhaust was hitting the driveline. Jacked the car up when I got home to replace the mount, noticed there was some rubbing marks on the driveline and driveline well where it mates with the tranny and none on the exhaust. Replaced the mount, took it on a test drive and it still rubbed. Would bad motor mounts add to this problem? and the main question is how do I adjust the tranny so that it doesn't do this? Any input is appreciated
Thanks,
Chad
Chad
ahigdonchad is offline   Reply With Quote
Old 08-21-2012, 11:14 PM   #2
photoman327
Both motor mount are more than likely broke as well.
Old 08-21-2012, 11:53 PM   #3
ahigdonchad
thank you, just ordered both
Old 08-22-2012, 12:09 PM   #4
TrickMick
TrickMick's Avatar
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
*all you need to know to get it right*
http://www.hotrodhotline.com/md/html..._harmonics.php
http://jniolon.clubfte.com/driveline...nephasing.html
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
