J_Jones
- May 1, 2005
- Lincolnton, NC
1991 240 with 2jz swap, shouldn't make a difference. Happened all of a sudden: Started car, no issue, alternator working and volt gauge showed 14+v. Moved car close to the house so I could vacuum it out, parked car, cleaned the interior real good. Started car and battery light stays on, volt gauge now shows 12ishv and dropping. What the hell? I start trying to figure it out. Fuses all good. Battery connections cleaned and tight.
Battery light comes on when key is on, stays on when car is running. Time to follow the circuit. Alternator showing same reading, 12.3v, as battery. Followed big red positive wire to distribution block on driver fender and all of those have 12.3v. Pulled cluster and knee boltster, 12.3v at the big red wire coming into the ignition switch. 0.4v at the small red wire in the circle plug that goes into the back of the cluster. 0.4v at the red wire at the bulkhead connecter. 0.4v on the little red wire coming into the alternator (signal wire).
So that is the entire circuit I do believe. The way I see it, I am not getting the same 12.3v coming out of the ignition switch as is going in. Ignition switch randomly failed after 200k?
Did I miss anything / do y'all want me to get you anymore info?
Thanks as always for sharing your experiences and thoughts.
