Time for a little update. Got my wheels worked out, and heres a little test fit
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQX0gxNnI4VXVhZUU/preview" width="640" height="480"></iframe>
Surprisingly, they fit really well, next to no rubbing at full lock without spacers. If I adjust the steering locks all the way I end up with maybe a mm of rub on the sway bar with a 245/40/17 tire.
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQY1VkUzAyelhmRFE/preview" width="640" height="480"></iframe>
Just before IPD I got the motor in and everything going back together.
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQb3lGMWtJSW1RRGM/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQU045bDUtMlZvamc/preview" width="640" height="480"></iframe>
and with tires mounted, I really like the way these 17's fill out the wheel wells.
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQN0hIdjFuUkxFd1U/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQbVA4MUV4OUptdlk/preview" width="640" height="480"></iframe>
After a ~90 mile shake down, everything seemed ok until the next day. Had some nasty knocking and decided not to drive it to IPD.
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQX3dacXFhWXZIU00/preview" width="640" height="480"></iframe>
So back in the garage it went, and after pulling apart everything, I found the problem. I appearently didn't go all the way through the proper torque sequencing when torquing my main caps, and in my haste I put it together. When I opened it up, I had one cap bolt loose in the oil pan, and all the others were somewhat loose as well. Since I dont know exactly what I was thinking or how I missed it, I had my torque wrench calibrated, and reinstalled everything. I need to get a whiteboard in the new garage so I dont miss stupid things like that...
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQam1YbnlwUUc0azg/preview" width="640" height="480"></iframe>
Anyway it is almost back together, on the list for tonight is to fill it with fluids, burp the radiator, resistor pack delete, and take it for a spin. I might install my new to me turn signal switch it I have time.
New motor specs:
6 bolt B20
Crank ground .010/.010
Bored .030 over, new cast pistons
Decked .030, pistons flush, giving me a final piston to head clearance of .030
Head is a B20 F head, mildly ported, double springs, static CR is ~9.5:1
K cam, summit lifters (IPD style) cromo tube pushrods
MS1 on a 36-1 front pulley trigger, single coil, 315cc/min browns running at 3 bar with vac disconnected (this will probably get an upgrade to MS2 and LS coils with a cam pickup in a gutted dizzy)
