Old 04-14-2018, 06:57 PM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default Get on your stethoscopes...
So I've been doing some small maintenance... started up my car and it sounded like someone dropped a rock in the cylinder...
It sort of comes and goes, sounds like its coming from the cam or the piston head.
It will disappear for a second, then come back
https://photos.app.goo.gl/JcxAesmKBEvic6k52
Give me a heads up if this link doesn't work. Had to use google photos because youtube was stuck in a processing loop and wouldn't upload.
81 264 - Driveway ornament
90 245 - becoming 16v
Old 04-14-2018, 07:33 PM   #2
LeedomtoFreedom
update, seems to go away at idle after warming up a bit, which leads me to piston slap. It's consistent on revving it.
it's a 94 squirter motor.
Old 04-15-2018, 08:24 AM   #3
dorvin
idunno
dorvin's Avatar
Glad to hear you figured it out, the video also worked for me without issue.
'93 Volvo 240 Classic sedan - 683/1600
'77 Oldsmobile Cutlass Supreme
dorvin is offline   Reply With Quote
Old 04-15-2018, 04:36 PM   #4
JW240
All idiot, no savant
JW240's Avatar
My car had a very tiny amount of piston slap. When it's running rich with cold engine you can hear it slightly, when it's running leaner (difference between remap) it's not making any piston slap noise. Maybe it's running a tad rich, washing away a tiny amount of oil?
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 04-15-2018, 09:29 PM   #5
LeedomtoFreedom
alrighty so I had checked the oil before and it was in the clear, but I think someone siphoned my oil because there was very little in there...
Gave her an oil change and it seems to have gone away or reduced greatly. Always check your oil
Old 04-30-2018, 07:22 PM   #6
benski
Post
Can't go wrong with that for a mantra...
