Old 10-03-2015, 03:01 PM   #1
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Default 13c Dyno Numbers
I would like to see what other people have done with their 13c's.
My build thread is in my sig, but the current setup is, unported 90+ manifold, unported 13c @ 20psi, 940ic and piping, K cam, and E85. The car ran a 13.92 @ 100mph on 12psi.
I'm just curious what numbers and times people have gotten with the 13c.
Post up your graphs or slips, otherwise I'm claiming fastest 13c
This run was on a Dyno Dynamics rig(8% lower than a Mustang and 12% lower than a Dynojet) @ 20 psi
Sometimes good enough is better.
Slow p.o.s. et13.51 @ 105mph - 13c, lh2.4
UhAudoe is offline   Reply With Quote
Old 10-03-2015, 04:31 PM   #2
BDKR
Section 9
BDKR's Avatar
Normally I don't think people bother.
That said, isn't that turbo off the island at 20psi?
For all you Dijkstra fanboys:
Old 10-03-2015, 05:05 PM   #3
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Well that's one way to look at it.
Less is more, and I like to do more with less more or less.
Old 10-03-2015, 05:17 PM   #4
turbotankshane
If I'm correct, it's not quite off the charts at 20psi but you drop to about 70% efficiency and its spinning north of 150,000 rpm to make that boost, so the air coming out is pretty hot. Something better than the 940 ic to cool that charge down would do you worlds of good.
That being said, looks good for a 13c still. My old 740t with an IPD cam, exhaust and 15g @15psi only made 180hp/210tq but it had a timing issue I didn't know of at that point and had 5 degrees of timing pulled through the whole range..
Old 10-03-2015, 05:27 PM   #5
BDKR
Section 9
BDKR's Avatar
Sorry if I sounded like a d1ck. Didn't mean too.
It's just my understanding that a 13c wheel is not at all efficient beyond 13 to 14 psi. If you can cool all of that adequately then perhaps it's a different story, but you have to admin that 200hp at 20psi is just terrible.
How is this for more with less (more or less)?
* Get a 15g or 16t
* Break it down.... Pull out the shaft and remove the compressor wheel.
* Remove and take apart the 13c... Pull out the shaft and remove the compressor wheel.
* Put the 13c turbine wheel and shaft into the 15g CHRA.
* Put the 15g compressor wheel back on.
* Put the 15g compressor housing back on re-clocked.
* Put the 15g assembly onto the 13c housing.
* Put back in car.
* Profit!
I did this for two years on an '89 +T and it was one of the funnest cars I've yet owned.
Old 10-03-2015, 05:39 PM   #6
UhAudoe
Sittin' sideways
UhAudoe's Avatar
I have a something in the works that will eliminate a serious bottle neck to power, and help to cool the intake charge.
Old 10-03-2015, 05:45 PM   #7
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Sorry if I sounded like a d1ck. Didn't mean too. It's just my understanding that a 13c wheel is not at all efficient beyond 13 to 14 psi. If you can cool all of that adequately then perhaps it's a different story, but you have to admit that 200hp at 20psi is just terrible.
213hp and 260tq, using almost entirely parts from other Volvo's, and 100mph trap speed, I don't see what is terrible.
Old 10-03-2015, 05:50 PM   #8
Mueller
Mueller's Avatar
Not saying using E85 is cheating, but quite a few people that don't have access to it, not a fair call to say or claim "best or fastest 13c"
Old 10-03-2015, 06:01 PM   #9
turbotankshane
Yeah and the dyno dynamics stuff generally does spit out lower numbers than everything else, but its pretty hard to put a % on it. What gear was the pull done in, just out of curiosity? Also, hp and tq crossing at 4200 rpm doesn't seem right at all.
Old 10-03-2015, 06:01 PM   #10
BDKR
Section 9
BDKR's Avatar
Well, I'd have to say it's not too bad based on that point of view.
And E85 is cheating.
Old 10-03-2015, 06:04 PM   #11
turbotankshane
Cheating never felt so good
Old 10-03-2015, 06:05 PM   #12
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Pull was done in fourth gear.
And E85 is not cheating, It's not my fault if you don't live in an area that is going "green" So I am going to claim quickest and fastest 13c.
Old 10-03-2015, 06:12 PM   #13
turbotankshane
Wasn't there a guy already running low 13's on a 13c? Went to mid 12s just switching to a 15g IIRC
Old 10-03-2015, 06:18 PM   #14
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Not sure about that. But that's the sort of stuff I'm looking for.
Old 10-03-2015, 06:35 PM   #15
sbabbs
sbabbs's Avatar
Yeah Greg in Eugene ran a 13.06 or so with 13c and then I sold and helped him put a 15g on and then he ran a 12.61. He tried and tried to get into the 12's with the 13c, never did, so basically you wanna boast about having the quickest 13c car you are going to have to get into the 12's to beat his time... When he ran the 12.613, I ran a 12.615 same night. I helped him beat me, but he did let me use his slicks.
Real drag slicks, totally stripped out cars, Greg had meth injection and aw71. I didn't and I had Getrag 5 speed.
My dyno run with 15g 12.6 car. 232hp 277wheel torqes.
Simon
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 10-03-2015, 06:48 PM   #16
turbotankshane
Greg's 13.1 was also @ 98mph, so technically if this isn't the quickest on a 13c, his trap speed of 100mph puts him in at the fastest
Greg's 740 was also down to 2600 lbs, right? So if this 240 is at 3,000 lbs still, its making a few more ponies to push that extra 400lbs to a higher trap speed.
Old 10-03-2015, 06:51 PM   #17
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Simon
Awesome! My goal has been (for like a month) to get into the 12's with the 13c.
And I'm not being sold that the 15g is neccesary, as your car made 19hp and 12ft/lbs more than mine with a 13c. Was this the setup that went 12.61? If so, then I know 12's will happen, I knew before but yeah, more evidence.
And that's good info. So yeah, fastest 13c then.
Old 10-03-2015, 07:00 PM   #18
BDKR
Section 9
BDKR's Avatar
Didn't Frank Yee do some insane boost numbers with a 13c a couple of years back. 26psi or something crazy. If I remember correctly Kool-Aid man dropped by for a visit.
To the OP: Keep going for it. While it may seem doubtful, I love being surprised or taught something. E85 and some other tricks to cool all that fiery hot air coming out of the 13c will no doubt go
farther then most have done running dino.
Old 10-03-2015, 07:03 PM   #19
turbotankshane
I still vote that a bigass bar n plate IC would do wonders
Old 10-03-2015, 07:09 PM   #20
BDKR
Section 9
BDKR's Avatar
+1!
Old 10-03-2015, 07:26 PM   #21
grnmachine02
Indicating?
grnmachine02's Avatar
This. All dyno graphs cross at 5252, is there some thing weird going on with the scaling?
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually, and a lot of memories.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 10-03-2015, 07:43 PM   #22
UhAudoe
Sittin' sideways
UhAudoe's Avatar
+3. Next spring will be when the stock Volvo stuff goes away. Until then we will make do. And quite well I may add.
All *inertia* dynos cross at 5252, this dyno is not an inertia dyno and uses an electric motor to load the vehicle.
Old 10-03-2015, 10:16 PM   #23
sbabbs
sbabbs's Avatar
Are you using real drag slicks, seems you could be in the 12's with slicks. I ran 13.7 without the slicks...
Old 10-03-2015, 10:30 PM   #24
UhAudoe
Sittin' sideways
UhAudoe's Avatar
Not yet. It is high on the list.
Old 10-03-2015, 10:37 PM   #25
grnmachine02
Indicating?
Interesting! Learn something new every day.
