Old 10-01-2017, 12:19 AM   #1
cookieboy
cookieboy's Avatar
Default What size exhaust diameter for N/A 240 with T cam ?
Hi guys, when I find my 240, I plan on getting a T cam to go with it and I was wondering if I should go 2.5" on the piping and muffler or is that overkill ? I remember someone telling me some years ago that his buddy had that set up and seemed to like it but I just don't know if that's too big or not. My last brick had a T cam and a 2.25" and it helped as well as sounded good. I plan on going with a chambered turbo style muffler and the car is likely to have an automatic. What say you ?
1990 244 DL, (Given to stepson 3-2-13)
cookieboy is offline   Reply With Quote
Old 10-01-2017, 01:30 AM   #2
mblue240
mblue240's Avatar
2.5" on NA cars is the way to go, single muffler in the rear with a bullet cat.
-Michael
Tbricks build
Yep, Michael is right.
Old 10-01-2017, 01:42 AM   #3
cookieboy
cookieboy's Avatar
So will that add more power than the 2.25" system then ? It's going to be a cat back system. Will there be any big loss in torque ?
Old 10-01-2017, 03:31 AM   #4
cosbySweater
cosbySweater's Avatar
I've always liked running a b21ft exhaust on n/a cars
Old 10-01-2017, 05:14 AM   #5
Lankku
Lankku's Avatar
I dont think that you'll benefit anything significant from a bigger exhaust on a stock engine. Just change a big free flow rear muffler for the sound/noise. But if you really want to go bigger, put a Turbo exhaust like cosbySweater said.
444 -55, 145 Express -71, 242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 "B6284T", V90 -98 4.6l
Old 10-01-2017, 10:58 AM   #6
classicswede
Volvo upgrades
I would go with a 2.25 inch system if you are running a T cam.
Old 10-01-2017, 12:22 PM   #7
cookieboy
cookieboy's Avatar
So it sounds like I Should stick with the set up I had the last time. Sounds good, thanks everybody !
Old 10-01-2017, 03:53 PM   #8
74green144
74green144's Avatar
I have a 90 NA with T cam and 2.25 inch cat back with single thrush welded muffler. I like it. I have an m46 with 3.73 rear end. Sounds good with very little drone at highway speeds.
1994 854 N/A 162k on chassis, 250k on motor
1974 144 k-jet 250k on chassis, "new" motor 25k ago (SOLD)
1966 122s solid running b18/m40 dual SU's and poly bushings
1965 122s parts car with good running b18/m40 dual Stromberg's and plywood floorpans
74green144 is offline   Reply With Quote
Old 10-02-2017, 02:23 AM   #9
cookieboy
cookieboy's Avatar
That's funny because that's the same setup I had except it was a regular Thrush non welded muffler. Do you think they flow well enough?
Old 10-02-2017, 02:35 AM   #10
74green144
74green144's Avatar
It's like a flow master chambered muffler knockoff. I think my stock cat is the most restrictive part of the exhaust at this point. I don't think the muffler is as restrictive as 114 N/A hp.
Old 10-02-2017, 09:28 AM   #11
quillc
yv1a.com
quillc's Avatar
I run a high compression B23 with an H cam for my DD. The 2 1/2 inch exhaust I have works well and isn't too loud. I also run a stahl header. No cat.
I've had a few different flowmaster mufflers on it (40, 50, super 50) and they all sound like sh*t. I ended up with a flowmax muffler and it sounds much better. All the flowmaster mufflers were just loud and ricey. 180 degrees between exhaust pulses is just too far for the flowmasters.
Chris
www.yv1a.com
Old 10-02-2017, 11:45 AM   #12
Ryan_R
Why is a T-cam suddenly a thing? If anything, it's a detriment over the already bad M cam. Nothing like a narrow pointy cam to make an impossibly tiny window to suck air into your motor at higher revs. I got rid of the T cam from my turbo car.
An A cam flows fine through stock pipes at high revs, so I'd think you're not hitting restrictions with a T or M cams.
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 10-02-2017, 11:58 AM   #13
-Ryan
In a word TORQUE where you need it.
People on here are driving their cars like normal law abiding human beings not boy racers, now that they're grown up with a wife, kids and house to take care of.
That said;
The walker 2.25" 240 Turbo exhaust kit is cheap from the usual suspects.
Old 10-02-2017, 12:17 PM   #14
lummert
lummert's Avatar
Turbo exhaust using adapter pipe to fit.
Old 10-02-2017, 12:47 PM   #15
15A
World's Oldest Brewery
15A's Avatar
Every NA car I do gets a T-cam and 2.5" stainless exhaust. If just doing a HG, a T cam is still a mandate. I have a shopping list of the components (free flow cat, resonator and muffler) if you want it. The difference in how it runs is very noticeable and 3/4 ask me what I did to it to make it so much 'peppier'.
Add a later AW71L behind it and its even better.
(IF YOU WANT ME TO LEAVE YOU FB AFTER THE FACT, JUST SAY)
I didn't sleep well last night so I made my coffee this morning with Red Bull instead of water.
I got halfway to work before I realized I forgot my car.
15A is offline   Reply With Quote
Old 10-02-2017, 05:13 PM   #16
Slip it on there and have somebody throw a bead of weld on it.
Old 10-03-2017, 11:37 AM   #17
Ryan_R
You're describing me to a 'T'. I'm a grown up. 41. House. Wife. No kids, but dogs and many, many fish. I rarely push my cars over 4,000rpms. I ran a T-cam in the NA 745. Benefits with a slush box? None! It's a waste of a cam seal and 8 valve shims.
-Ryan
Old 10-03-2017, 10:25 PM   #18
cookieboy
cookieboy's Avatar
-Ryan
I hear you, I'm 44, have a wife, a stepson and a daughter who like Volvos now because of me so while I need more grunt than an M cam can provide, I'd like to have somewhat of a useable power band, especially with a slush box. I have on other question, what performance muffler would you guys recommend for the stock 2" piping to hold me over until I could afford the bigger piped system ? I could get a cheap muffler and my buddy could weld it in at work so I wouldn't have to pay a shop to do it, any recommendations ?
Old 10-03-2017, 10:52 PM   #19
Don't waste your money on just a muffler.
As I mentioned above the 240T 2.25" walker stuff is under 2 bills and it all bolts up except possibly where it slips over the 2" stock stuff but you could slot it and clamp it instead of welding and not have to pay any shops.
Oh and my M cam in my 86 245 / M46 car was flat on it's face under 2K but the T in my 82 245GLT pulls back from 1K and doesn't seem like it's ever out of torque.
Maybe the slush box is golden with an M cam?
Old 10-04-2017, 12:47 AM   #20
cookieboy
cookieboy's Avatar
I'll take a T cam over an M any day of the week, regardless of the tranny..
Old 10-04-2017, 05:19 AM   #21
Grr baby, grr
Yeah but that W cam.... Wow!
Old 10-05-2017, 01:29 AM   #22
cookieboy
cookieboy's Avatar
Sure, that would be great, thanks!
Old 10-06-2017, 12:25 AM   #23
cookieboy
cookieboy's Avatar
Out of curiosity, isn't the Skandix sport exhaust only 2" piping ? What's the difference between that and just replacing the stock muffler with something more free flowing ? I prefer bigger piping of course, but I'm just wondering.
Old 10-06-2017, 01:07 AM   #24
Dunno look it up, but the skandix & IPD sport exhausts are more scratch than the 240T stuff from Eeuro / FCP, and this is TB home of the broke assed cheapskates is it not?
I mean you're already bitching about having to pay an exhaust shop $20 or $30 to put a car you don't even have yet on a lift and run a bead of weld...
Old 10-06-2017, 01:12 AM   #25
cookieboy
cookieboy's Avatar
Seriously ? I wasn't bitching, I just wanted to know. I can pay to have it welded on, I'm just weighing my options for the future and trying to budget accordingly.
