Old 09-23-2018, 02:53 AM   #1
DrZiplok
DrZiplok's Avatar
Default Modern ABS for a tracked 240 (Teves MK60 swap)
ABS is nice to have on track. If you disagree, you're welcome, but this thread is not for you. 8)
The Bosch ABS-II unit that was fitted to late-model 240s is a lot better than nothing, but it's dumb, it's slow, and it doesn't modulate the rears independently. It would be nice to have something better...
A very common swap for BMW E30s (which incidentally also used ABS-II) is the Teves MK60 as fitted to the E46 (2001+) M3. Actually, this unit is a common swap into many platforms, as it runs standalone and can be flashed with some fairly interesting software. Even stock, however, it's a much better, smarter unit.
Most of the swap is prettymuch the same as for any other MK60 swap, but we encountered some 240-specific issues.
Rear reluctors: the 240 ABS system uses a single reluctor & sensor in the differential. The MK60 needs individual rear wheel sensors. Happily, if you are prepared to ditch the parking brake, there's a nice machined surface on the axle in that area outboard of the axle seal.
We sourced these from reluctorrings.com - if you call and ask they should have our measurements on file. Installation involves nothing more complex than a torch to heat the ring enough to expand it, and then it just drops into place (once you have removed the bearing, of course). If you want to make your own, the rear reluctors need to be made with 48 teeth (same as the front).
EDIT: see post #24 below for a better rear sensor option.
The rear BMW sensor has a long strain relief on the cable that needs to be carefully trimmed off, so that it can be tucked in under the parking brake drum. I can't say whether this would fit under the standard rear rotor, as we have S60 rotors on the car - you might need to shrink the ring or find another sensor to work with.
Shown here with a 3d-printed prototype mount, the sensor mounts using existing holes from the handbrake mechanism and a bracket fabricated using 1.5" L stock.
The front BMW sensor is a nice fit in the stock ABS knuckle, but it's not long enough. Here we copied the E30 guys and trimmed the sensor back. It looks terrible, but it works.
Engine compartment: ignore the M52, nothing to see here. The MK60 is normally mounted very close to the master cylinder in OE applications, but this is only required for DSC purposes. ABS-only installations work with it prettymuch anywhere.
Wiring is very straightforward. You can wire the stock brake light wire into the ABS unit; the warning light is a bit trickier as the output from the ABS unit is pulled to ground to *disable* the warning light. Either use an LED with a series resistor, or a relay.
Image taken from a mostly helpful document produced by facebook.com/bmwm3motorsport. Note that in other applications the MK60 is driving a bulb directly; I tested one on the bench as drawing ~100mA, meaning that if you want to use a brighter LED, you can use a much lower-value resistor. We see good results with a super-bright BA9 LED and a 680R resistor.
The DSC button input is not useful and can be left disconnected. Make sure to tie the fluid level sensor input to ground (or wire up a fluid level sensor...). DSC sensor box is installed under the driver's seat in the correct orientation (connector forward, mounting surface up). The steering angle sensor is not required for ABS purposes, so we pitched it.
Note that we don't have an ignition switch - you might choose to route pin #4 differently in a car that does.
Last edited by DrZiplok; 05-14-2019 at 12:26 PM.. Reason: Added more details. Mentioned better rear sensor.
DrZiplok is offline   Reply With Quote
Old 09-23-2018, 10:11 AM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Interesting.
Old 09-23-2018, 01:59 PM   #3
JW240
All idiot, no savant
JW240's Avatar
Originally Posted by MDVLN View Post
Interesting.
way cool, +1
One of my mates swapped E46 ABS into his E36 and it works great, didn't know the system was so standalone it could work in a completely different chassis without CAN.
240 | 1991 | 338K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Old 09-24-2018, 06:51 AM   #4
Chumley360
Nice!
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 09-24-2018, 01:30 PM   #5
good to see you making progress on this!
Is there a reason the stock 240 front ABS sensor would not work?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 09-24-2018, 02:04 PM   #6
JW240
JW240's Avatar
I found this:
Apparently E36 sensors VR work with some conversion trickery:
https://www.bimmerforums.com/forum/s...s-wanted/page3
https://s14net.vbulletin.net/forum/s...c-retrofit-kit
Somewhere in the middle explanation about the magnetoresistive sensors. Considering the price of the signal converters its probably a better bet to gather the modern sensors.
If doing the signal conversion, I wonder if the VR sensors found in the rare 740/760 traction control system could work, those are fitted close to the diff pumpkin. Sensors are still available new, usually $$.
For me, I follow this swap out of interest. My 240 is a long way from needing abs, if at all. Lots of other things to be fixed before I even think of this
Old 09-24-2018, 05:39 PM   #7
DrZiplok
DrZiplok's Avatar
The stock sensor is a passive thing; essentially it's just a coil and you get a low-amplitude AC waveform out of it.
The MK60 uses an 'active' sensor; there's a sensing element (Hall or reluctance) and then some signal processing and a current-mode driver. The driver alternates between sinking 7mA or 14mA to give you a nice square-wave output that's largely immune to electrical interference.
I believe signal converters exist, and certainly we didn't exhaust all our options looking at other 'active' sensors for something with a more suitable form factor...
Old 09-24-2018, 10:31 PM   #8
saffy4052
Awesome work so far! This project hits close to home, as I am planning a very similar swap. My swap includes a modern Bosch ABS unit, and while I've hydraulically plumbed it, I have yet to get to figuring out the wheel speed sensors and wiring (I'm a bit preoccupied with the engine swap at the moment) Looks like you did a bit of the work for me for the rear tone rings! I'll have to order a pair
Full disclosure, I'm a chassis controls engineer for Bosch, and I've got quite a few cool plans for mine. Easy part will be calibrating the system to operate how I'd like it for the Volvo (target slips optimized for the summer tires I put run, some vehicle rotation during trail-braking, etc). Where is will get fun is writing code for things like line-lock, hydraulic handbrake for drifting, Auto-LSD (brake torque vectoring), etc.
A couple of questions for you:
1) Did you consider the number of teeth on the new rear tone ring? Assuming the BMW had equal teeth front/rear, I bet you matched it to the front tone ring on the Volvo.
2) I'm having a hard time making out what you did to modify the front ABS sensor from the BMW. Do you have any other pictures? A before / after?
Here is a picture of mine so far:
https://drive.google.com/file/d/0B-5...ew?usp=sharing
saffy4052 is offline   Reply With Quote
Old 09-25-2018, 02:03 AM   #9
DrZiplok
DrZiplok's Avatar
1) Rear tone rings are 48t, same as the front, same as the BMW application for the MK60. Updated the first post with some additional measurements & the tooth count.
2) The OE front sensor has a large brass boss molded into the plastic (so that Hans doesn't crush it when he's bolting it all together). If you remove the boss and most of the plastic, you're left with an ear that locates the sensor at the right depth and which can be captured using a bolt in the stock sensor mounting location.
Was that your K75 I saw in the shop at Abstatt a few years ago?
Old 09-25-2018, 06:17 AM   #10
saffy4052
Nope. I’ve only been to Abstatt on business trips a couple times. I’m based out of the Detroit area.
Old 09-25-2018, 10:54 AM   #11
Does that mean you have all the software to be able to tweak the settings on these things?
Old 09-25-2018, 12:33 PM   #12
saffy4052
Yes, I have the full software. I can update standard parameters (easy) and write new logic/code (more involved). It’s essentially what I do at work everyday.
Old 09-25-2018, 04:49 PM   #13
We should talk.
Old 09-25-2018, 07:15 PM   #14
DrZiplok
DrZiplok's Avatar
We should talk.
I expect that he will say that he works for Bosch and that he's not allowed to share.
But if that's not the case, do tell. 8)
Old 10-01-2018, 11:51 AM   #15
rb92673
So how did it work last weekend? I was right behind you in the black 745 at tech.
Old 10-01-2018, 12:46 PM   #16
DrZiplok
DrZiplok's Avatar
G'day! How did your frakentransmission work out?
Best way to describe the MK60 setup would be that "it just works" (once we got everything bled properly), and night and day better than the old system.
Probably the biggest single improvement was how much better it worked when the car was not going straight, but with the R brakes we would have been in a world of lockup hurt without it (since they're super bitey compared to our old setup).
Definitely worth the effort.
Old 10-01-2018, 01:09 PM   #17
rb92673
My transmission worked amazing compared to the M46 I had before.
My brakes were awful, rears were locking up. I am evaluating what to do next with brakes. ABS would be nice, but I think the first step is getting rid of that wacky dual lines to the front brakes and putting in something where I can adjust the front and rear bias.
Your car looked great and really fast.
Old 10-01-2018, 04:54 PM   #18
DrZiplok
DrZiplok's Avatar
Thanks. Would have looked better if we had time to finish the artwork, but... priorities. 8)
One big learning from this system for me was that making your own brake lines isn't as scary as it seems. The breakthrough for me was finding the right flaring tool: https://www.amazon.com/gp/product/B01MDUHIE1
Old 10-01-2018, 05:13 PM   #19
rb92673
I don't know the 240 braking system, but did you use the stock master cylinders and is there a booster?
Old 10-01-2018, 06:02 PM   #20
DrZiplok
DrZiplok's Avatar
Since we're using the larger S60R calipers, we upgraded to an SN95 Mustang master, still on the stock booster. If we'd stayed with the stock calipers, the stock ABS master would have been fine.
You might want to see if you can hunt down Matt Wirth from Too Stupid to Know Better (the red-and-white 740 wagon). He has that car dialed right in and always seems to be happy to talk.
Old 10-01-2018, 06:14 PM   #21
rb92673
Thanks!
Old 10-07-2018, 06:36 AM   #22
Sander
Good news everyone!
Sander's Avatar
This is great, did you have to reprogram the abs unit to work well in the Volvo?
Old 10-09-2018, 02:29 AM   #23
DrZiplok
DrZiplok's Avatar
No re-coding was required to make it work.
We did use the usual BMW Tools (INPA in particular) to bleed the unit; I suspect a lot of the cheap Chinese scantools will do it as well.
Old 05-14-2019, 01:40 AM   #24
DrZiplok
DrZiplok's Avatar
Found a better sensor for the rear axles, no longer requires painful carving of the strain relief, etc.
It's a Nissan part (in my case a cheap clone sold under the 'Autex' brand), cross references 479007S025, ALS624, 5S10761, SU12214, 084-4776, 411.482.
EDIT: race-tested this last weekend, works just fine for us with ~1mm clearance to the reluctor.
STL for the bracket
Old 05-14-2019, 09:07 AM   #25
mikep
The MP
mikep's Avatar
Nice work, first time I have seen this thread.
This shit belongs in the virtue signaling thread. Let’s go back to talking about nazis.
