2turbotoys
Salaminizer
- Nov 13, 2007
- Reading pa
Howdy guys and gals,
I installed R brakes on my 242 Saturday. Car is 1979 242 base model. Calipers are from 2006 S60R, Powerstop drilled and slotted rotors, and Akebono pads. Removed rear brake reducer valves, replaced with a set stainless front brake lines from my spare parts hoard. The only parts not replaced were the solid tubing lines necessary for to get from front to back, left to right, and the damn distribution block.
Leaving my friends shop late last night, I hit the brakes to test them at approx 45 mph, car pulled very hard to the left, and didn't slow down very much. Approaching a stoplight, 1 tire locked up hard, also pulling me to the left. A 35 minute drive home turned into an hour of terror, almost no brakes at all.
The original distribution block has the brake failure sensor broken off, and the wire is unplugged, so its a fair guess that this is the problem.
What is the best replacement for this distribution block? I have read a lot of stuff from "I use a 740 one (very vague cause my 740s have all been ABS with no distribution block)" to "take the valve out of an original one but replace the sensor with a plug (no one seems to know the plug size)" I have a new factory replacement block but want some options or opinions.
Thanks!
PS: wanted to include pics but I'm old and used to use Photobucket, whats the best pic sharing thing now?
Thanks!
