Old 04-28-2017, 04:25 PM   #76
InTheWhite
InTheWhite's Avatar
Originally Posted by PCH View Post
Wow! Man you sure do very proper work. Respect from a fellow White 945 owner
Thank you so much! I do my best.
Old 04-28-2017, 04:27 PM   #77
InTheWhite
InTheWhite's Avatar
Originally Posted by +Kardboard+ View Post
Who built the air filter heat shield? Looks really good!
It´s BSR Optiflow heat shield that i painted white.
Old 04-28-2017, 04:28 PM   #78
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
This car makes my white 940 desires real hard to ignore, Great work!
1980 242 Turbo
2004 V70R
Old 04-28-2017, 04:31 PM   #79
InTheWhite
InTheWhite's Avatar
^^^ Says BSR Optiflow heat shield for airfilter in the earlier post https://en.bsr.se/products/performan...lter/opti-flow
Also listed the trans as AW71L. Was that swapped and how is it holding up? I thought lock up converter transmissions were not used on Turbos.
AW71L are original in all 940 Turbo here in Sweden. The tranny is holding upp very well.
Old 04-28-2017, 04:40 PM   #80
InTheWhite
InTheWhite's Avatar
Thank you! Glad to hear!
Old 04-28-2017, 06:14 PM   #81
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Sweet, thanks!
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking (sold)|'77 244DL, red/sold.|'90 744T C3P-LOL, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 04-29-2017, 02:04 PM   #82
InTheWhite
InTheWhite's Avatar
Sweet, thanks!
Your welcome!
Old 04-29-2017, 06:52 PM   #83
DET17
Reformed SAABaholic
First view of your Vaggen, very very nice! I'm planning an extra trans. oil cooler which might well end up similar to yours. I presume your custom bracket is attached above the bumper attachment framework? However, I thought the extra cooler was to be installed and junctioned into the TOP 8mm steel line. It's my understanding that the top line is the hot one coming from the AW71.
Keep on rocking' the white bricks! Polar White in my case.
Old 04-29-2017, 07:43 PM   #84
InTheWhite
InTheWhite's Avatar
Thanks!
The bracket is attached to the bolt that holds the fender chock absorbers in the frame.
The bottom line is comming from the transmission, the top is from the cooler to the transmission.
Old 04-29-2017, 09:23 PM   #85
DET17
Reformed SAABaholic
Well, that's opposite of what I thought. Will check my Greenbooks to see. Again, great work.
Old 04-30-2017, 05:28 AM   #86
InTheWhite
InTheWhite's Avatar
Do that to be sure. Maby there is a difference between markets?
Old 05-01-2017, 01:11 PM   #87
DET17
Reformed SAABaholic
Well I doubt the Greenbooks were tailored to various markets. Double checked and found the routing including a diagram for the "extra oil cooler". You are correct about the lower line entering the ordinary radiator cooler.... the bottom port is FROM the AW7X and the top port is TO the AW7X.
What appears to be different in your install is the position of the two; from the greenbook the
"ordinary cooler" is entered first, then at the TOP port the exiting oil is routed to the "extra oil cooler". It seems to me you have this sequence reversed where the "extra" is now first.
If you like, I can scan this page and host it for your review.... or, you can just believe me
Ref. Greenbook TP 31642/1
Old 05-01-2017, 01:29 PM   #88
InTheWhite
InTheWhite's Avatar
I have changed the positions on purpose, the oil was to cold in our climate if installed in reverse. Now the oil is coold down first and heated up a little bit in the stock cooler before going to the AW71.
Old 05-02-2017, 05:29 PM   #89
Roman_Turbo
Sweet wagon project.
I have a classic sedan with the m90, and I'm thinking about buying the bsr chip+wastegate, does it change the behaviour of the car much compared to a manual boost controller? what about reliability? I'm sitting on 310.000 Km right now.
Roman_Turbo is offline   Reply With Quote
Old 05-03-2017, 08:33 AM   #90
InTheWhite
InTheWhite's Avatar
I can realy rekommend the chip and wastegate from BSR. I have tested both bleed valve, Dawes device and stronger wastegate actuater. The actuator is easely recommended and gives the best boost curve. I have had this in my car now fore about 70.000km without any problem.
Old 05-06-2017, 04:21 AM   #91
InTheWhite
InTheWhite's Avatar
I'm planing to do some modifications on the crankcaseventilations.
Going to change to a B20 oilcap and put a bit siloconehose on to that and finaly a chrankcacefilter on that.
Old 05-30-2017, 12:46 PM   #92
InTheWhite
InTheWhite's Avatar
I bought me an do88 ciliconhose to the brake servo. Now I have changed every rubberhose to cilicone.
Old 05-30-2017, 04:46 PM   #93
Mattytup
Question Volvo 940 b230fk
Hi I am new to the Volvo scene and looking for advice on getting my 940 turbo a little more powerful.
Thanks
Mattytup is offline   Reply With Quote
Old 05-31-2017, 12:03 PM   #94
InTheWhite
InTheWhite's Avatar
Thanks
An adjusteble/harder wastegate actuator, and a fuel chip is good to begin with.
Old 06-06-2017, 01:44 PM   #95
InTheWhite
InTheWhite's Avatar
Today i have done an exterior rekond on plastic and rubber.
Old 06-08-2017, 07:00 AM   #96
InTheWhite
InTheWhite's Avatar
The rust protection was so worn so it was time for new.
Old 06-08-2017, 09:36 AM   #97
SquareD
An Anomaly
SquareD's Avatar
Really nice job! This thing is super clean and I love the white/black contrast!
Old 06-09-2017, 09:12 AM   #98
InTheWhite
InTheWhite's Avatar
Originally Posted by SquareD View Post
Really nice job! This this is super clean and I love the white/black contrast!
Thanks!
Old 06-09-2017, 09:13 AM   #99
InTheWhite
InTheWhite's Avatar
Bought me som extra spare-parts for the future...
Filter and gaskets to the AW71L from VParts:
Rubber spacers to the rear springs from Fordonsdelen:
Old 06-09-2017, 01:31 PM   #100
Gnomestur
Gnomestur's Avatar
Are you going to do a accumulator mod as well?
Gnomestur is offline   Reply With Quote
