Old 06-22-2018, 09:59 PM   #301
cosbySweater
cosbySweater's Avatar
Originally Posted by Duder View Post
Well damn, I didn't realize this many folks were hitting 130+ in their 240s. Good to know! I guess I don't pay much attention to drag racing trap speeds.
The belly pan should help reduce underbody drag a bit.
In my old 240 with the redblock I did 150 in it with cut springs and original shocks and it was okay. It had a belly pan and was lower then what I have now though. But the suspension on the ls car is so good. I will probably do the belly pan this weekend and see how it reacts to it
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 06-22-2018, 10:00 PM   #302
cosbySweater
Originally Posted by JanP View Post
Iirc on that car he has alot of sheet metal under the car to get the air out the back
Old 06-24-2018, 08:17 PM   #303
cosbySweater
Whelp this is gonna be easy, clears the hood perfect.
Old 06-25-2018, 02:27 AM   #304
cosbySweater
Just for a small comparison
Old 06-25-2018, 02:58 AM   #305
122power
dude
122power's Avatar
thats not big enough
Old 06-25-2018, 04:00 AM   #306
Duder
His Dudeness, El Duderino
Duder's Avatar
Is this better?
Old 06-25-2018, 12:05 PM   #307
cosbySweater
Is this better?
Lol that's awesome
Old 06-25-2018, 03:18 PM   #308
122power
dude
122power's Avatar
Sweet!
Old 06-25-2018, 03:22 PM   #309
Jack
junkman
Jack's Avatar
buy some Krud Kutter, spray engine and bay to show the bling blang you dirty cracker
Old 06-25-2018, 03:52 PM   #310
cosbySweater
Engine bay is rusty. Cars getting body work and paint after the cage goes in. Then I'm gonna pull the engine and do the engine bay and clean everything up
Old 06-25-2018, 03:59 PM   #311
Jack
junkman
Jack's Avatar
The KrudKutter works well for decreasing everything prior to paint too
Old 06-25-2018, 04:00 PM   #312
cosbySweater
Lol. You funny
Old 06-28-2018, 10:22 PM   #313
cosbySweater
Alright! So I reinstalled the s366 and drove the car he, took some measurements and figured out everything I need to do so I can perform the swap in a weekend. Ordered a 4-3 inch cnc exhaust adaptor, 3.5 yes 3.5 compressor outlet and a coupler to go from 3.5 to 2.5. then I need to do some more measurements for the new intercooler that's going in. It's getting exciting here and I am really looking forward to the swap. There is a guy that has the same engine/trans, cam, and fuel system combo that made like 800whp with it at higher boost. So I am interested to see what it will do and compare his graphs. The specs on the exhaust and compressor wheel are very similar to the billet 7875, almost identical actually. So it will be very exciting to see if the ball bearing and more efficient housings will help in power delivery!
Old 06-30-2018, 05:01 PM   #314
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
When I had my turbo apart replaceing the center section I was VERY close to buying the billet 7875 center section for $300 adn dropping it in place. I'm excited to see how your setup does for sure.
60' 1.66
1/8 6.53 @ 113.3mph
1/4 9.99 @ 140.4mph
20psi 11.5deg timing E85
3140lb no driver
3320lb with driver
Old 07-16-2018, 10:43 PM   #315
cosbySweater
The car is getting outfitted currently for leaving the crank on the ground. I'm converting back to a single 450 in the tank, 380lph externally mounted which will draw fuel from the bottom of the factory sump doing proper fittings on the sending unit. Mounting the regulator and all flex fuel associated parts in the trunk and running a single fuel line to keep up with the strict drag strip rules here. Running a single fuel line to the front. Bumping it up too a 8an fuel line and some billet rails. Engines are expensive out here so I want to keep it in one piece. I'm going to be finishing up the transbrake wiring and also work on getting another driveshaft for it after the cage gets finished.
Old 07-16-2018, 10:45 PM   #316
cosbySweater
And yes I realize that last post is a double negative. If I have to break it to get into the 9s I will but I want to make sure I have all my bases covered for if and when I have to swap engines
Old 07-16-2018, 11:51 PM   #317
gsellstr
gsellstr's Avatar
I want to witness said pass Erik.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 07-17-2018, 01:22 AM   #318
122power
dude
122power's Avatar
What what I thought an ls was cheap?
Old 07-17-2018, 02:17 AM   #319
cosbySweater
It is cheap. Compared to what you woild pay to get a redblock into the same bracket
Old 07-17-2018, 06:14 PM   #320
122power
dude
122power's Avatar
Yeah for sure
Old 07-24-2018, 01:30 PM   #321
cosbySweater
I was driving the car the other day, and it lost a ton of power and started surging on the highway, got it to work luckily and checked the basics on it. Fuel pressure was good, went to 100psi right away with the return line clamped off. Found that the number 5 spark plug was completely fouled out. So I unplugged the injectors and commanded the fuel pump on for about 1 minute and then cranked it with no plugs in it. No fuel shot out so I'm guessing the injector is okay. Pulled the valve cover and for some reason I think the cam was cut a little bit off. I found one of the push rods was too long. Super odd, so I ordered one pushrod for it and it's fine now. I have started on the fuel system for it and I'm hoping it works out the way I planned. Also the rest of the turbo parts are in and I got my Arduino standalone boost controller for it. So that should be interesting to test out. Now to tear it down and get the turbo installed and get the cuttout situated as well as the complete fuel system overhaul. Going to throw on a truck intake as well and see if it will clear the hood so I can squeeze a little more power out of it and iff it clears good I will see if the bread box intake clears as well. I have had some interesting things also happen to it and now I'm thinking I may need to get the converter swapped out in it because the car is making enough power now to push it to like 6500 rpm and it feels flat. Oh well more time and money but hoping by the fall I'll have it all sorted and hit the track
Old 07-24-2018, 03:54 PM   #322
Duder
Duder's Avatar
Weird, so your pushrod grew in length? Maybe it got a little to "excited" at the thought of all the power to come. Did you take limp measurements or...?
I think you should make a lexan mailbox hood scoop for this car, like Finnegan's Blasphemi has.
Let me know if you have any other turbo setup questions or concerns; I'm happy to advise wherever possible. I'm looking forward to seeing exactly what this thing can do with the GTX4202R on there. It's funny because in relative terms that's a nice new modern turbo, but the 42 family was the first one we gave the GTX treatment to, and that was over 10 years ago now. C'est la vie!
Old 07-24-2018, 04:13 PM   #323
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Ha! fab aluminum ala "Two Lane Blacktop"
1980 242 Turbo
2004 V70R
Old 07-24-2018, 07:07 PM   #324
cosbySweater
Haha I can't stand hood scoops. I am going to make a duct of some sort to where I can remove my passenger side high beam and use it as a velocity stack at the track
Old 07-24-2018, 11:12 PM   #325
cosbySweater
Also I have 55 150 like that in the picture, not going gasser. Going road race with it instead
