Hi all, I was wondering if after cleaning out the head bolt holes to keep them from loosening, could one apply thread locker to the treads to keep them in place? I know that you are supposed to just lightly oil them and torque in the correct sequence after carefully cleaning and chasing the threads, yet this will be the second time in the past 5 months that I've had to remove the head for this problem. One bolt seemed not to tighten with new head bolts (felpro).
I had the head tested for leaks, new valve hushers, and planed down, yet I've been getting misfires after sitting, and a milky substance under the cap, and after doing a dye test, verified the leak. The car is a 91 240.
Was I supposed to use rtv sealant to apply to some of the bolt holes in order for the coolant not to mix with the oil? The reason why I ask is because I didn't do this for my 88 240 and it turned out just fine.
