Old 11-15-2018, 04:47 PM   #1
Sweep
Default Dump or Recirculation valve?
I've been eyeing up this recirc valve from Forge lately, the 940's been on the back burner for a while but it's back in the limelight.
https://www.forgemotorsport.co.uk/Tu...duct--756.html
It has a HY35 strapped to it, however we have idle issues which I assume is down to not having any sort of recirc valve.
Are there any pros/cons to either dump or recirculation? Does one prefer to work with 2.4 over the other?
Ben.
Sweep is offline   Reply With Quote
Old 11-15-2018, 04:52 PM   #2
crogthomas
crogthomas's Avatar
What is currently fitted?
I have no bypass or dump valve of any sort and no idle issues.
Old 11-15-2018, 05:15 PM   #3
LeedomtoFreedom
LeedomtoFreedom's Avatar
There was a thread started a while back that said a dump valve shouldn't cause stalling issues on lh2.4, but I'm pretty sure it prefers a recirc valve
81 264 - Sold
90 245 - coming BACK baby
Old 11-15-2018, 05:45 PM   #4
martin84
I have recently had the same issue sweep. I've got an Owen developments 19t and fitted an atmospheric bov where the original recirc goes and it would stall everytime coming up to a junction and struggled to idle. Refitted the stock recirc and the problem instantly went away.
martin84 is offline   Reply With Quote
Old 11-15-2018, 05:47 PM   #5
martin84
I've been following your thread on voc by the way and look forward to seeing the potential of your setup.
Old 11-15-2018, 07:45 PM   #6
Dirty Rick
Dirty Rick's Avatar
If your car has an airflow meter you should recirc because the air has been measured.
Dumping measured air will mess with fueling same as an air/vacuum leak.
Old 11-15-2018, 08:05 PM   #7
Your car is a much better sleeper if it doesn't make blow off noises. Plus it's better not to lose measured air as mentioned above. I use a Forge valve made as a replacement for Saab. It looks just like the Bosch ones only is metal and will handle higher boost pressures.
Old 11-15-2018, 08:26 PM   #8
LeedomtoFreedom
Search up the many threads already started about this. They explain everything
Old 11-15-2018, 10:17 PM   #9
white855T
That would be too hard... Don't ya know how it works around here?
Old 11-16-2018, 07:38 AM   #10
Sweep
It doesn't have anything fitted currently.
Thanks, I'm looking forward to it as well! I think it's the best thing to try, I don't like blow off noises so would prefer a recirc anyway.
That would be far too easy!
Old 11-16-2018, 10:03 AM   #11
crogthomas
crogthomas's Avatar
Then your problem lies elsewhere, don't complicate things by adding a recirculating bypass valve, it's not required for the engine to run or idle.
A rough idle is almost always down to a air leak somewhere. Unless there is something not set up correctly. Was it fine before?
Old 11-18-2018, 12:44 AM   #12
InferiorWang
InferiorWang's Avatar
I've noticed 3 things that can cause idle roughness on these engines:
1) vacuum leak
2) bad AMM
3) dead in tank fuel pump
If you know your pumps are good and you've tested with a spare AMM, I'd look for vacuum leaks like crogthomas suggested.
"I like anything fast enough to do something stupid in." - Xander Cage, xXx
InferiorWang is offline   Reply With Quote
Old 11-20-2018, 06:35 PM   #13
If that port isn't being used for boost control it should be plugged. If it is going to be used for boost control it goes to the wastegate actuator.
No connection at all is a large air leak causing a loss of measured air and idle roughness.
Old 11-21-2018, 10:53 AM   #14
Sweep
That's excellent, thanks! I'm on holiday on your side of the pond until December so it'll have to wait.
Old 11-25-2018, 10:59 PM   #15
2turbotoys
Have you seen me?
2turbotoys's Avatar
A dump valve is always a vacuum leak, its always slightly open while the engine is running. Re-circulation is not, because its after the maf and its not leaking un-metered air. Any Maf (or amm if you prefer) car will not run correctly with a dump style valve on LH 2.4 because of the maf.
Refer to post #6 Dirty Rick, he is correct.
Using no bypass or dump such as crogthomas says he does leads to premature turbo bearing failure, especially if running a decent amount of boost. When letting off the throttle under boost the air pressure backs up in the intercooler tubes, pushing back on your turbos impeller, trying to spin it backwards, its not made for that stress.
Did you hook that port on your wastegate to the actuator yet? Super important...don't even bother with anything else till thats done
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-27-2018, 06:02 PM   #16
Duder
Comes with a free Frogurt
Duder's Avatar
Almost but not quite. Surge won't try to spin the wheel backwards; and even if there is some torque reversal at the wheel it's not the main concern.
Compressor surge essentially creates a rapid oscillating axial thrust load, pulling and pushing the shaft in and out. With a journal bearing turbo that can quickly damage the thrust bearing since it will likely get overloaded with more thrust load than a hydrodynamic film can support. With a ball bearing turbo that has angular contact paths, there is no separate thrust bearing, and they can take a lot more abuse via surge without any real damage.
The reason the wheel and rotor group thrusts in and out in surge is due to the pressure differential from the front of the wheel to the backdisc. You always have a net positive force pushing the wheel out of the turbo on boost, because the cavity behind the wheel "fills up" and reaches close to full boost pressure. The cavity in front of the wheel is the intake tract of course, and will be slightly below atmospheric. So there's always a net force pulling the wheel outward. Hard compressor surge is a pressure oscillation and even some flow reversal, but the main impact is that the static pressure behind the wheel will vary rapidly, which beats the crap out of the thrust bearing (again, in a JB turbo with a separate thrust bearing).
The dorifto guys running no BOV at all and getting away with it are likely also using ball bearing turbos.
Old 11-28-2018, 04:11 PM   #17
Sweep
Are Holsets journal or ball bearing?
Old 11-29-2018, 11:29 AM   #18
LeedomtoFreedom
Mostly journal
Old 12-09-2018, 10:29 AM   #19
Thebrick_740turbo
F
Last edited by Thebrick_740turbo; 12-09-2018 at 10:30 AM.. Reason: Read forum wrong
Thebrick_740turbo is offline   Reply With Quote
Old 12-09-2018, 04:24 PM   #20
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
U
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 12-13-2018, 05:31 AM   #21
Sweep
Alrighty, so last weekend I went over the vacuum lines (I had replaced them all previously anyway) and also ran a line from the little port on the turbo to the wastegate just to remove that air leak (I haven't sourced an appropriate boost controller yet) and it idled much better until it got up to temperature, a few blips of the throttle and it died when the revs dropped back down, which then wouldn't start. I guess I need to obtain another 012 and check to make sure it's not the AMM that's casuing the problem as I bought this one from your side of the pond.
Old 12-13-2018, 05:48 AM   #22
Sjeng
Sjeng's Avatar
Something totally different. Where is your MAF located and how is your air cleaner connected to it?
Mine starts idling like crap and stalling when the distance between K&N filter and MAF becomes too short. Cruising and while accelerating it runs perfect.
Old 12-14-2018, 07:57 AM   #23
Sweep
Pretty close, I'm somewhat lacking in space!
Old 12-14-2018, 06:18 PM   #24
Sjeng
Sjeng's Avatar
Air cleaner directly on the MAF. This could very well be the cause of your problems.
Old 12-15-2018, 05:30 AM   #25
Sweep
Originally Posted by EivlEvo View Post
Where does that WG dump pipe go to? ^^ Also is that the OBX cut and flipped?
Secondly, even though Mike (TLAO) has stated a number of times AND has tried my exact (I sent it to him) BOV on his personal car and it worked fine... my VTA (I have an HKS SSQV) causes stalls. If I recirc, it's fine.
Just down towards the ground. No it's a custom stainless I did myself.
Interesting, why would that cause an issue?
