Old 12-01-2018, 09:12 AM   #1
xseto
Default wiseco piston on a b230
I bought wiseco piston 96.5 mm and i have conrod from maxpeedingrods but with The stand piston there is no clearace and with The wiseco piston The is 1 cm ?
xseto is offline   Reply With Quote
Old 12-01-2018, 11:00 AM   #2
xseto
Do i have The wrong rods?
Old 12-01-2018, 12:00 PM   #3
Assuming the rods are the same width, you’ll need some aluminum or brass/bronze spacers made to take up the space. Pretty common issue with piston steered rods and aftermarket pistons if the rod width ain’t specified when ordering.
Old 12-01-2018, 12:00 PM   #4
OG flat plane crank
How does the other end fit on the crankshaft?
Me for President
First candidacy driven entirely by smart phone.
Campaign slogan
"Trump, I wouldn't piss on him if he were on fire!"
Old 12-01-2018, 02:15 PM   #5
xseto
It fits on The crankshaft
Old 12-01-2018, 02:34 PM   #6
mikep
The MP
mikep's Avatar
What is the side clearance between the big end of the rod and the crank? Use a feeler gauge.
This shit belongs in the virtue signaling thread. Let’s go back to talking about nazis.
Old 12-02-2018, 06:51 AM   #7
xseto
I dont have The crankshaft with me right now but The original rods is 25 and The new rods is 25mm to
Old 12-02-2018, 03:42 PM   #8
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Looks like the Wiseco's are designed for crank steered rods, OE are piston steered. Check the fit of the new rods on the crank, should have around .010" or so side clearance.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-02-2018, 04:40 PM   #9
Quick question: is the pin height the same on both pistons (distance from the center of pin hole to the top of the piston?)
The pistons will work as is, you just need some spacers made for the small end of the rod.
Or get some stock length rods that are crank steered.
Old 12-04-2018, 01:11 AM   #10
John V, outside agitator
What is the width of the connecting rod BIG END...25mm or 29,75?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 12-05-2018, 05:15 PM   #11
xseto
Both 25 mm
Old 12-08-2018, 04:39 AM   #12
xseto
Both 25 mm
Autoshop made a spacer because volvo is piston steered
Old 12-21-2018, 09:12 PM   #13
Next time buy rods which are crank steered. Makes choice of pistons easier.
Old 12-23-2018, 05:13 AM   #14
Arewethereyet
I’d contact MaXpeeding as I’ve got their rods fitted to my Wiseco 16v pistons and they fit fine.
Arewethereyet is offline   Reply With Quote
