Old 04-26-2019, 02:43 PM   #51
A tough rowing ho
If you switch to speed density/megasquirt you don't need a maf at all.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 04-29-2019, 02:38 AM   #52
Brotkasten
Jonas
Brotkasten's Avatar
Can't you just put the MAF after the turbos or does that not work with LH?
That works quite well actually. Ran it for 6 months without an issue.
91' 940 B230FB+T M90
Brotkasten is online now   Reply With Quote
Old 05-03-2019, 12:40 PM   #53
Swedbrick
Swedbrick's Avatar
Interesting, moving the MAF(s) would open up some options and allow me to get them away from the turbo manifold. Thanks for the tip!
My current plan was to first get the base map worked out on the car with the itb's (in an airbox) whilst also moving on with the turbo stuff on the engine stand. With a blow trough setup I could also keep the same wiring then.
After that I was planning to put the new engine in, and run it in without the turbo's after which I can start to add all of the complex bits for the TT setup and make it work. And then slowly increase the boost until I am where I wish to be power wise.
Sorry for the lack of actual updates for now, with the current study load I can only get to benchracing an a little progress each week
Oh and additionally, I finally got my eeprom programmer and eeproms, so soon I'll be trying to burn a couple of chips
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Old 06-03-2019, 03:41 PM   #54
Swedbrick
Swedbrick's Avatar
Default China intercoolers, put the head on, and got myself into 16v trouble
Finally some more progress on both the engine and the car itself, with some late nights and little tasks during quick study breaks
The first hurdle was cleared by drilling out the old oil pump drive gear, and installing a new one, with the installer made by a friend. These were only available from Volvo Penta, so I took the liberty of getting 2 at once for possible future projects.
The next hurdle, the intermediate shaft bearings was also cleared. I covered the new bearings in a good inside coating of vaseline top prevent gaulling of the surface, and used a m20 threaded rod to pull in the bearings nice and straight, finally they are in perfect
Youtube video for the fit:p
I also put in the rear oil seal in one go, so much win!
A few days later I spent a day porting, polishing and reassembling the oil pump, all should be well.
Moving back to the engine itself, I got the head installed with the 12.9 grade head bolts, and proceeded to spend ages to get the valve shims in spec (6 attempts required for perfection):p
With the valve clearance set, I proceeded to applying anaerobic sealant to the cam end caps and put in the rear and front cam seal, since I'll be going wasted spark with this setup.
The large intercoolers I ordered also arrived at the post office, hopefully they'll fit in the front with my measurements.
With all except the oil pan sorted, I proceeded to time the motor on the stand.
And discovered an issue with my plan to use a 24mm wide timing belt.
After a little read and contact with KGtimmning, I went on the lookout for 16v cam gears, which escalated into me buying a set of PZ 16v cams, the roller and belt for a 16v conversion for Strettman. Who I ended up helping to buy a very clean orange 242 which was local to me, pretty cool coincidence.
The crankshaft gear had a little damage on the key, which I managed to restore with a weld bead and a file to an acceptable result.
With this the issue was partly solved, more updates on getting a fitting timing cover and tensioner later.
Proceeding with a night of playing around with the welder and grinder I also managed to create v2 of half of the turbo manifold, which after a test fit on the car still required some adjustments, since my initial placement for turbo #2 was in the frame rail. Stupid mistake, but I modeled it without the car in winter in the driveway to check, so it was to be expected.
I'll soon be getting test fitting v2.5 to continue with the top manifold for turbo #2 (fitment will be different, but this should give an idea of the interfering framerail
Old 06-03-2019, 03:47 PM   #55
Cwazywazy
Single jingle
Cwazywazy's Avatar
Backwards? Black side faces out, pretty sure..
I don't know what I have
Old 06-03-2019, 04:16 PM   #56
80/20 speed parts club
You may have to re-engineer your coolant transfer tube with that manifold.
Old 06-03-2019, 04:54 PM   #57
Swedbrick
Swedbrick's Avatar
Hmm, probably then, seemed the most logical at the time, but rubber on the oil side is maybe less smart. I'll change it out by the time I've gone through run in and am ready to put my K-cam in Thanks!
Yes I already noticed indeed, with a little adjustment it should work however, I'm more concerned as to the turbo not hitting my strut towers
