Old 06-28-2016, 12:51 AM   #1
cosbySweater
cosbySweater's Avatar
Default converting a d30 240 axle to a 1310 ujoint
i remember reading a long time ago that someone converted a 240 d30 axle to a 1310 u joint using this flange. does anyone recall this or has anyone recently done this for themselves? thanks
1990 Volvo 245, Efan conversion, tcam, Aw71 FOR SALE
1995 Porsche 993
2013 VW Passat TDI
Old 06-28-2016, 10:34 AM   #2
you can also probably get a hybrid u joint that doesn't require a different flange
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-28-2016, 11:25 AM   #3
cosbySweater
yea i realize that, im getting a driveline built, also servicability on a standard 1310 ujoint will be much easier then a custom one.
Old 06-28-2016, 12:37 PM   #4
http://www.dennysdriveshaft.com/c196_dana_30.html
http://www.4wheelparts.com/Drivetrai...na+30+Standard
There are some pinion flanges that will work as well, but then you will need the u-joint flange as well. Your driveline shop should have no problem sourcing these for you .
Also, the Jeep TJ flanges may work. I can't remember if they're the same spline size on the pinion as a standard d30. The TJ pinion is a different length, and they use larger size bearings... I'm just not sure on the spline size.
Old 06-28-2016, 01:03 PM   #5
cosbySweater
i was looking at those but the rear end was rebuilt. i would rather not mess with pulling yoke off :/
Old 06-28-2016, 01:14 PM   #6
its not custom, its a standard part
Old 06-28-2016, 01:45 PM   #7
cosbySweater
yea but what if, say that u joint were to break, i think a 1310 would be alot easier to find same day.
Old 06-28-2016, 02:27 PM   #8
gsellstr
Vintage anti-ricer
gsellstr's Avatar
2-2-237 is whats on the receipt for the one I had done for the 140. 3" shaft, 1310's, stock 1030 flange.
Got it from Driveline Service in west sac.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-28-2016, 03:08 PM   #9
cosbySweater
thanks gary, i have a 1031 axles, i believe they are the same, the flange i posted the link too is out of testpoints old thread. ill buy both and if one doesnt fit ill just send it back, i already got the drive shaft made today for it with 1310s at both ends. ill report back with my findings
Old 06-28-2016, 04:16 PM   #10
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Same rear flange. I tossed in a late model 240 shaft in the 140, fit perfect.
Old 06-29-2016, 12:45 PM   #11
122power
dude
122power's Avatar
buy two and have one on the shelf?
Old 06-29-2016, 12:47 PM   #12
exactly.
If you are that concerned, just have a spare on hand.
Old 06-12-2019, 03:45 AM   #13
CTessmer
I know this is an old post but I need a new pinion companion flange or part numbers to convert it to a conventional u bolt pinion yoke. Did you ever get yours sorted? Any help is much appreciated. I installed a TrueTrac and new bearings, seals, driveline, etc, and really want to get the car off the jackstands. It’s been on them for 2 years now. Lol. Too many projects and so little time.
CTessmer is offline   Reply With Quote
