Old 12-10-2017, 02:59 PM   #26
2manyturbos
Originally Posted by thelostartof View Post
As far as I know the throttle shaft has never been apart. And a very sad way for a 531 to die along with and engine. The block looks like it should still be good. I am hoping a quick hone might remove the small mark on the bore otherwise it might be getting bored out for a rebuild far into the future. Now to put together the H beams I have here into my spare na block.
That head should be fine if you just smooth out the sharp edges. Do the same to all 4 chambers and have the head shaved.
Old 12-10-2017, 05:00 PM   #27
gsellstr
gsellstr's Avatar
Damn Mike, that's nuts! Or screwy?
Glad I put a little locktight on if I ever pull the plate, but still, wouldn't help with the snapped shaft...
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-10-2017, 05:06 PM   #28
culberro
culberro's Avatar
If you don't mind spending ~$200, that head could be fixed if it's just the chamber that's beat up.
I wouldn't even tough the roof of the chambers, just clean up the quench pads.
A little welding and some die grinder action, and a then get the head surfaced.
I've fixed much worse damage than that.
Old 12-10-2017, 06:23 PM   #29
thelostartof
unbalanced chemical
thelostartof's Avatar
Sounds like I will be taking this head to one of the local shops then and seeing what they quote me to fix it.
Old 12-10-2017, 06:49 PM   #30
tryingbe
Boosting along.
tryingbe's Avatar
I'd send it to culberro...
Local shop are mostly joke.
85 GLH 367whp
00 Insight mpg > yours.
Old 12-10-2017, 06:58 PM   #31
Tuff240
240 Ninja
Tuff240's Avatar
Sand down the top of the piston, shave the head and run it. (if it was a stocker )
-Patrick
Old 12-11-2017, 04:54 PM   #32
SquareD
An Anomaly
SquareD's Avatar
Reminds me of when I re-installed a IC pipe and a piece of one of those little clips that hold the hose pipes in place broke off and got sucked into a combustion chamber. Same damage. I had the head welded to fill the damage and surfaced and threw a new piston in that hole.
Old 06-02-2019, 01:37 PM   #33
iHateVolvoPeople
Lord_Athlons daddy
Wow back from the dead but I had that exact same clip sucked into my intake manifold as well a couple years back! Luckily for me, #4 intake valve stopped it in its track so it was basically just a simple head gasket swap instead of bottom end repair.
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
99' Camry A140E. Admittedly the newest car I’ve ever owned.
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
