Old 10-11-2018, 06:24 PM   #1
Swedbrick
Swedbrick's Avatar
Default Budget 350hp b230fk build (9.3:1 compression)
Hi All, I've created this thread in addition to my 745 project build thread, since I would like to keep the engine build seperate, since it might end up in some other project eventually. For this first update I'll start with the beginning, the block and inspection. (first pictures taken with potato, sorry)
Car Thread: https://forums.tbforums.com/showthread.php?t=345041
Step 1: Buy a B230fk engine with all turbo bits, squirter block and thick rods
Step 2: Inspect and tear down said engine block, discover lack of oil changes by previous owner
Oil starvation on the rodbearings, not shown here but somewhat less on the crankshaft bearings.
Not the best starting point, but after some inspection, the cylinder walls look okay, the rods where already on the replace list, same for the pistons.
Step 3: Cleanup and block preparations
Oil port modifications
Cleanup with hone and drill (measurements were taken with calibers to assure within reasonoable spec)
Fresh paint
Removed Carbon, polished crankcase, ground oil return channels, cleaned up oil channels and mating surfaces.
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Last edited by Swedbrick; 11-19-2019 at 09:37 AM.. Reason: Fixed all images by moving over to imgur
Old 10-11-2018, 06:51 PM   #2
Hacksaw116
What's in the fridge?
Hacksaw116
Hacksaw116 is offline   Reply With Quote
Old 10-11-2018, 06:54 PM   #3
Swedbrick
Swedbrick's Avatar
Default Getting serious: headwork
For part 2 of the build, it was time to get into some headwork, I chose to go for a mild port and polish, with cleanup of the valve seat to port area, slightly worked valve guides, a controversial dimple port since the stock volvo injectors which I intend to use in pairs are not really great in terms of atomisation. The head worked was a 530 casting, since this was my first experience porting, and 531's are hard to come by.
The stock head ready for disassembly
The stock port
Reworking the sharp edges and blending the valve seat and port gently with the dremel tool
Deshrouding the valves with the head gasket for reference
Changing the chambers to more represent the 531 head in terms of flame front propegation from the sparkplug
The finished chamber, dimple port also included
Polished up the valves to a shine in the drill press with cloth to protect the surface
Relapping the valves
CC'ing the chambers, worked out well
Installing KGTrimmning dual valve spring kit with light weight retainers, ready for 7k rpm
Assembled head, ready for installation, only relube and chamber polish required.
Last edited by Swedbrick; 11-19-2019 at 09:24 AM.. Reason: Fixed all images by moving over to imgur
Old 10-11-2018, 06:56 PM   #4
Swedbrick
Swedbrick's Avatar
Many things, including caffeine and swedish mustard (no joke)
Old 10-11-2018, 07:22 PM   #5
Swedbrick
Swedbrick's Avatar
Default Polish all the things!
For part 3, clearances and polishing, since the oil starvation had taken it's toll on the crankshaft and the rods, I decided to refinish the crankshaft, buy chinabay rods, which would also have to be brought in spec and got to work on several other important aspects.
The polished crankshaft, the shoestring and sandpaper trick was used whilst repeatedly checking with the fingernails and the calipers for correct clearances. The choice was made to be on the wide side of the stock clearance, which after polishing ended up being with the stock bearing size.
Polishing the set of chosen b230et pistons, with 3.6mm dish for 9.3:1 compression, for better torque and fuel consumption.
Side by side comparison of skirt thickness for old type ET pistons (right) vs FK/FT pistons (left)
The chinabay rods, suprisingly well matched in weight and split, but did have to clearance pin bore slightly and had to deburr and improve oiling hole on top of the small end, since the machining edges were terrible. (Still looking for arp grease, if anyone has some in the Netherlands!)
Balancing the pistons, rings, pins and rods.
Painted several bits, cleaned up carbon from stock cam and auxilary shaft
Restored turbo, ported and polished, rewelded worst of cracks, should hold for quite a while
Two TD04-13C turbo's, rebuild with a budget kit
Next up, manifold construction, which is still in the pipe's, so more progress will follow soon. The assembly of the block will be somewhere in december, so that will take a little while to get to.
Last edited by Swedbrick; 11-19-2019 at 09:31 AM.. Reason: Fixed all images by moving over to imgur
Old 10-11-2018, 08:07 PM   #6
photoman327
photoman327's Avatar
Following along and finally doing a little work. Finally dove into the red wagon to see what the oil pressure issues were and pickup still slugged up and a torn transfer o ring caused oil starvation and bearings look like yours. I just changing the engine. This is movating me to think about a buget build also. Good start!!
Old 10-11-2018, 09:46 PM   #7
Satsukeshi
Satsukeshi's Avatar
Twin Turbo? This should be interesting
'90 740: MS3X, ID1000 Injectors, AEM Smart Coils, Head Mounted CAS, RSI Stage II Head, Stage III Cam, Shimless Buckets, td04hl-19t, NPR IC, SSQV 4, 3" Turbo Back.
Upcoming Remix... 2.5l Big Turbo FunWagon
Satsukeshi is offline   Reply With Quote
Old 10-12-2018, 04:22 AM   #8
Swedbrick
Swedbrick's Avatar
Yes unfortunately a pretty common problem with these engines, especially since they are pretty bulletproof otherwise. If you get along to making a thread for your build, I'll most definately tag along!
Indeed, more previews on the car build thread
Old 10-12-2018, 04:33 AM   #9
Sjeng
Sjeng's Avatar
I still have a little bit ARP grease left if needed.
Old 10-12-2018, 09:00 AM   #10
photoman327
The guy I got it from told me he was not much on service and with the oil coming out in chuncks I expected issues but I ran so good. This one a simple buget built and all will be good. Problem is time and space. Got to clean up a lot. You pics get me pumped!
Old 10-13-2018, 08:20 AM   #11
K9 240
K9 240's Avatar
Looks like you're making good progress so far!
following with interest as I have a block on the stand as a work in progress.
If I could quiz you over a couple of things.....
I've not seen the oil port modification (in step 3) done before - what is the purpose/reason behind this? I've done some chamfering & blending of the oilways & am now wondering whether to do this before cleaning the block (again).
I've also been looking at the maXpeeding rods (strange name!) so very interested to see you using them. Could you elaborate on how you had to clearance the pin bore and any other thoughts you have about them.
Tim
K9 240 is offline   Reply With Quote
Old 10-15-2018, 06:09 PM   #12
89_740Turbo
89_740Turbo's Avatar
Gunna follow this thread closely. I have a 8,000 mile b230ft at home I want to twin turbo
Old 10-17-2018, 05:49 AM   #13
Swedbrick
Swedbrick's Avatar
Tim
Hi Tim,
The oil port mod is to prevent swirl in the oil flow towards the head and to remove some resistance for the pump since the stock channel is just 3 holes drilled in a row. It was a whilst I'm in there kind of thing, just as the chamfering and blending of the oil channels which I also did.
The maxspeeding rods were clearanced since I cleaned up the pin bore, and prefer my pistons to not be pin-steered with a somewhat undefined clearance in a block that was designed to be crank steered as stock, so I followed the haynes manual for the stock spec of 'light thumb pressure'. I also was not too impressed with the machining work on the small end, so I removed all of the sharp edges, and added a chamfer to the oil port. I'm still in doubt about the provided ARP bolts, but from my research they seem very close to legit (we'll see if they hold), the only downside was the lack of provided grease.
Hi Sjeng,
That would be awesome, would shipping be possible. Maybe this is best discussed via private messages
Old 01-27-2019, 06:01 PM   #14
Sjeng
Sjeng's Avatar
Any updates?
Old 01-29-2019, 07:36 AM   #15
Swedbrick
Swedbrick's Avatar
Default Big update including manifold designs
Hi all, it took a while but since I've finally managed to finish my graduation project (also Volvo related, b230 engine modelling and datalogging, more on that on the car thread), I'll update you all on the progress during the past months, since the engine assembly will start shortly.
First of, a major setback, the intermediate shaft bearings which I pulled during disassembly and planned to replace had to be put back in after I got the engine washed at the machine shop. This obviously did not go to plan, and unfortunately the bearing went in crooked, resulting in the tapping marks to get it out again. I'll be addressing this by making a set of bearing pullers, and getting a new set of 3 bearings for 70$
To get going again after the fit that resulted from messing up these bearings, I cleaned out the oil channels, sealed the ends using permatex, and put the oil squirters back in. After this I smacked in the freeze plugs.
Next up was the installation of the stainless steel freeze plugs I made (the tapping of the block was as scary as one were to assume), to prevent catastrophic failure during future track sessions at 7k rpm.
All pretty and installed
Next up, due to the little time available during my graduation project, I started redesigning the manifold, since I was unhappy with the current inability to fit the stock oil cooler, and the what turned out to be less than ideal inside profile of the previously created runners. I started of with this idea for a log style manifold.
Ordered some cast bends, to hopefully result in a much smoother profile.
Had the realisation during one of my breaks, that better flow could be had without to much of a space penalty.
I then proceeded to model this in CAD, with some consideration to equal runner length.
Used my 3d printer to get an idea of the profile of the flange, and to asses the first design of the flange I had in mind.
After this I got to work on optimizing the manifold design for equal runner length, oil drain angle and fit in the bay. Resulting in a length of .28 m for cylinders 1 and 3, and .22 m for cylinders 2 and 4, close enough and possibly with a slight Subaru burble, which would be nice.
The side profile, plenty of space for two 2.5 inch downpipes
And finally the rear view
For now I'll focus on getting the engine assembled, after which I will get the flanges cut and will get to milling the K27 flanges step. For those in the Netherlands and Europe, I'll be setting up a small company to sell these flanges along with other goodies I've created for personal and graduation related projects (EGT readout, MAP readout, dataloggers, cooling fan control and such) So If you are interested let me know, so I can get an idea of the stock to start out with!
Last edited by Swedbrick; 11-19-2019 at 09:11 AM.. Reason: Fixed all images by moving over to imgur
Old 01-29-2019, 08:38 AM   #16
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice header ! i like where this is going !
why 9.3:1?
Old 01-29-2019, 10:07 AM   #17
Swedbrick
Swedbrick's Avatar
why 9.3:1?
Thanks! I chose the higher compression mostly due to the better fuel consumption and low end torque (drivability yay), the max boost for the 13c's of 14psi will not require much additional octane, so premium should suffice which is easily obtained in the Netherlands. The ET-pistons are a lot cheaper than a set of forged pistons, and should be plenty strong so I went with those.
Old 01-29-2019, 05:22 PM   #18
Somebody's actually doing it. Nice.
Old 01-30-2019, 07:13 AM   #19
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
do i interchange soemthign here? wasnt there another TwinTurbo guy with gold painted centers?
Old 01-30-2019, 08:19 AM   #20
Swedbrick
Swedbrick's Avatar
Hi, yes, that is probably me as well, I've split my project into the engine build and the build of the car itself, as found at the top of the thread
Old 01-30-2019, 08:31 AM   #21
mocambique-amazone
Hi swedbrick, where did you buy the ET pistons in Europe?
I'm looking for them too.
thanks, Kay
Old 01-30-2019, 09:13 AM   #22
Swedbrick
Swedbrick's Avatar
thanks, Kay
Hi Kay,
I got them via a request in the facebook group of the 'bangers' who tend to drive into each other in old volvo wagons for fun, interesting characters, but a cheap source of parts. As far as I'm aware, KGtrimning has them in stock as well for approximately 96€, which saves you the cleaning. I got mine for 20€ for four with a couple of crank sensors
I could also inform with the guy I bought them from, and ask if he can get another set. Just send me a private message, I can probably help you out
Old 02-01-2019, 04:16 AM   #23
moise
moise's Avatar
good job man
moise is offline   Reply With Quote
Old 02-02-2019, 05:29 PM   #24
Chilm
Double Dutch
Chilm's Avatar
I'm following this closely ;P
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 03-18-2019, 06:19 PM   #25
Swedbrick
Swedbrick's Avatar
Default Prepping for assembly of the bottom block
Hi, It's time I got back into a little update. I've finally gotten the bearing pullers turned up, and have completed my test with the remaining intermediate shaft bearings I had, allowing me to get to assembly. Soon the oil pump gear bushing and a new set of intermediate shaft bearings should be here!
Let's start off with the bearing pullers I got made by a friend with access to a lathe. I also asked him to create a tool to insert the oil pump gear bushings with as I found these to still be available through Volvo Penta. The pullers are used along with a M20 threaded rod and bolts, to allow for a fairly straight pull into their final location, and are made from mild steel.
The work quite well, but I am going to grease the surfaces for the new set to prevent this scarring. Anyhow, the bearings are now partly in
Next up cleaning out the oil pump, and fitting the new reinforced oil pump spring and ring for the oil pump gear, which I got to add for relatively cheap to my brothers IPD order (shipping to the Netherlands) And yes I'm aware that the spring only increases high RPM oil pressure increasing bearing wear etc, however this engine will probably get a baffled sump as some point and all the power will be made above 4krpm, and I expect to blow it up long before the bearings are worn down:p
The oem pump cleaned out (still had good tolerance), which will be ported before reassembly
The reinforcing ring to prevent the oil drive gear tabs from shearing at the edge
Said stiffer oil pressure spring
With my new found confidence in my bearing puller and oil pump usability. I got started filing the ring gaps, since the pistons were stock size ET versions, I chose to hone out the imperfections and live with slightly wider ring gap and piston to wall clearance. Since I was an idiot, as one tends to be after a long day, I filed the top ring to my smallest measured size for the second ring to get them all equal of .95 mm, I ended up having to go even wider with the top ring to allow for proper sealing. Yes I could have gone with another ring set, but I chose to get it together for now, and just make sure my PCV system is really overkill
The final spec:
top: 0,95 mm
middle: 1,00 mm
oil control: 0,80 mm
PWC max: 0.148 mm (pistons were divided to keep this as little as I could)
Obviously far from stock recommendations and what I would like to run (top: 0.70mm, mid: 0.80mm, oil: 0.40mm, PWC: 0.04mm). But since this is my first engine build, I chose learning and getting it done over getting it perfect first time around.
Last edited by Swedbrick; 11-19-2019 at 08:58 AM.. Reason: Fixed all images by moving over to imgur
