Old 12-07-2018, 03:09 PM   #1
towerymt
the real Towery
towerymt's Avatar
Default What are your injector cleaning / flow test results?
I just got a set of 4 injectors back from WitchHunter Performance (www.witchhunter.com) and I was concerned about the actual measured flow rate, even though it's even across the set.
They are Bosch p/n 0-280-150-785 for the orange 850 Turbo injectors. They flowed 207cc/min at 43.5psi.
Anyone else have measured data on the orange 850 Turbo injectors?
I wonder how it could be so much lower than published data. We ran the same injector on our lemons car with ~14psi boost, probably making close to 200whp....if they actually flowed that little, I think we run out of injector...but AFRs were safely into the 12s at WOT down the straights.
Other sources list their flow rate at 43.5psi at over 300cc/min, but that doesn't seem accurate. I noticed here that 310cc/min is given at 57psi instead of 43.5psi. At 43.5psi they're listed at 270.9cc/min...still considerably higher than 207-208cc/min.
http://users.erols.com/srweiss/tableifc.htm
My injectors yielded 208, 208, 207, 207 cc/min @43.5psi
Other measurements from the service:
Resistance: 14.5, 14.4, 14.5, 14.4
Static flow:
dirty: 102, 103, 0, 100
clean: 104, 104, 103.5, 103.5
Pulsed flow cc@2500rpm:
dirty: 115.5, 117, 0, 114
clean: 117, 118, 117, 117.5
static variance: 0.5% after cleaning
pulsed variance: 0.8% after cleaning
Old 12-07-2018, 05:41 PM   #2
gsellstr
gsellstr's Avatar
Don't think I have the results for the oranges I had on the R when they were flowed, but they were definitely more than 207.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 01-08-2019, 11:32 AM   #3
towerymt
the real Towery
towerymt's Avatar
Anyone else have results?
Old 01-08-2019, 01:05 PM   #4
shoestring
shoestring's Avatar
Not for this particular injector. You want cookies?
Old 01-08-2019, 05:07 PM   #5
142 guy
I have never used WitchHunter. Do they provide the performance results to you in cc/min or did they provide it in lb/hr or gm/sec and you did the conversion? Fuel injector cleaning services do not flow test with gasoline for safety reasons. They use a less flammable similar viscosity test fluid. The test fluid has a different density than gasoline. If they provided a mass flow rate based upon the test fluid and you converted that to cc/min using the density of gasoline, that will create an error. However, 208 versus 270 does seem a bit large because the density difference is normally much less than 30%.
If WitchHunter provided the results as a volume flow rate, then it is unlikely that the test fluid density is the source of your discrepancy.
Old 01-09-2019, 01:07 PM   #6
towerymt
the real Towery
towerymt's Avatar
Sure. Any injector with published flow rates.
They gave results in cc/min at 43.5psi. Fluid temp was 71F.
Thanks for the info.
Old 01-13-2019, 03:35 PM   #7
arsenix
Last time I had my injectors flowed/cleaned I tested them myself and found that their results were BS YMMV!
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust
- - > Project Thread < - -
My new project - 1990 740 SE Wagon
arsenix is offline   Reply With Quote
Old 01-13-2019, 03:58 PM   #8
Dirty Rick
Dirty Rick's Avatar
I clean them myself with Berrymanns compressed air and a 9 volt battery.
Many used injectors just have debris caught in the inlet screen, EZ fix.
Old 06-07-2019, 08:28 AM   #9
shoestring
shoestring's Avatar
Finally found my book on our build. We used Advanced Injector in Valley Center, Kansas. We had 8 injectors out of an '88 Camaro L98 done. Bosch # 0-280-150-223. Flow values at 3 bar.
Resistance: 16.0 16.0 16.0 16.0 16.0 16.0 16.0 16.0
Static Flow cc
Dirty: 242 250 250 253 253 250 253 254
Clean: 255 254 255 255 255 254 255 255
Pulsed flow cc @ 2500
Dirty: 121 125 125 126 127 125 127 129
Clean: 130 130 130 130 130 129 130 130
How is it your static flow was less than pulsed?
