Old 01-26-2019, 12:34 PM   #26
M.H. Yount
M.H. Yount's Avatar
Not too much of a stretch to say -- and this doesn't happen very often -- that Porsche got it from GM.
Old 01-26-2019, 11:21 PM   #27
300+hp on the shelf club
You also can try straps like ones on the hydraulic mounts in the picture.
Old 01-27-2019, 08:34 AM   #28
dbarton
Dejected by Volvo
dbarton's Avatar
I considered that too. My only concern was that the sheet metal might fatigue and break faster than a cable, considering the constant flexing. Maybe I'll try that if this one doesn't work out.
Otherwise it would be exactly the same, except made with sheet metal instead of cable. Not sure it that would make any difference in how it performs. It just needs to be able to restrain the mount from separation while not restricting it's movement or damping.
Dave B
Old 01-27-2019, 12:16 PM   #29
80/20 speed parts club
Just like the springs in your struts need constant replacement due do fatigue, right?
Old 01-27-2019, 12:55 PM   #30
M.H. Yount
M.H. Yount's Avatar
LOL - as if unibody sheet metal stampings and spring steel were the same thing.....
Old 01-27-2019, 01:48 PM   #31
I like your idea a lot. Having used diesel mounts on a couple of my cars. They can be too rough and I've even had the drivers side diesel mount separate. So something like this would have prevented the driverside mount separation which then led to the engine and driveline getting a bit crooked. My shifter bracket was over to the right in the hole.
Old 05-16-2019, 09:22 AM   #32
dbarton
Dejected by Volvo
dbarton's Avatar
After putting ~4000 miles on my car going to Davis and back and other driving since this install, I think i can say I have around 5k miles on these mount cables.
Are they failing yet?
Old 05-16-2019, 09:27 AM   #33
dbarton
Dejected by Volvo
dbarton's Avatar
nope.
Old 05-16-2019, 01:20 PM   #34
None of the issues that were presented can be determined by looking at them without taking them apart. Also 4000 miles is a barely a test.
It looks like the exhaust side crimp has failed?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-16-2019, 01:36 PM   #35
JohnMc
JohnMc's Avatar
How much HP are you pushing through them? Manual or automatic?
The geometry of those mounts just sucks. Too narrow - close to the crank centerline, they don't have as much leverage to work with against driveline torque. And angled backward - to balance against the trans mount pushing forward. It works with stock HP levels... barely.
If you use a ratchet strap you can keep squishy soft mounts on them, but all the added stress of a 1st gear turbo-assisted launch goes through the ratchet strap - which is located on the top of the engine, about as far from the crank centerline as possible under the hood.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-16-2019, 02:40 PM   #36
dbarton
Dejected by Volvo
dbarton's Avatar
Sorry. It's not my DD. I'll report back in 10 years
No it hasn't failed. Looks like new still.
Thanks, Dave
Old 05-16-2019, 02:45 PM   #37
dbarton
Dejected by Volvo
dbarton's Avatar
Just a bit more than stock HP. Maybe 200. 15 psi with a 15G, manual trans, G80, but I don't make a practice of clutch dumps very often.
Yes. The geometry sucks.
Someone with skills . . . make the mounts I really want (see post #20).
Dave
Old 05-16-2019, 02:51 PM   #38
JohnMc
JohnMc's Avatar
Skills = money, and the concept competes against a $5 harbor Fright ratchet strap.
Old 05-16-2019, 07:38 PM   #39
A tough rowing ho
Bose invented magnetorheological fluid and dampers. They sell a badass truck seat.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 05-16-2019, 08:12 PM   #40
In all fairness those do stretch and get ****ty in short order
Old 05-16-2019, 08:32 PM   #41
dbarton
Dejected by Volvo
dbarton's Avatar
But of course they keep the mounts from sagging.
Old 05-16-2019, 08:49 PM   #42
sbabbs
sbabbs's Avatar
Instead of crimping the cables you could put those cable locks that use bolts and nuts perhaps.
Old 05-16-2019, 08:54 PM   #43
Cwazywazy
Single jingle
Cwazywazy's Avatar
I used an HFT ratchet strap and it kept breaking.. Rather just replace the engine mounts every year than deal with that or vibrations from harder mounts. I'm interested in seeing the verdict on those torque rod things in the group buy.
I don't know what I have
Old 05-16-2019, 10:04 PM   #44
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Dave
http://www.retroturbo.com/?product=v...0#!prettyPhoto
Old 05-17-2019, 02:07 AM   #45
klr142
Turbo, what?
klr142's Avatar
Originally Posted by NotSoFresh View Post
http://www.retroturbo.com/?product=volvo-240-series-solid-engine-mounts-b230#!prettyPhoto
Those are going to be STIFF, not cushy at all like the hydraulic option Dave has pictured.
Old 05-17-2019, 09:10 PM   #46
dbarton
Dejected by Volvo
dbarton's Avatar
No kidding. Turn my dash into a jackhammer.
Dave
Old 05-17-2019, 09:56 PM   #47
SwedishBee
Drill em deep
SwedishBee's Avatar
where were those mounts made? just got some and they were all 3 made in turkey and brake pads were india.
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 05-18-2019, 07:25 AM   #48
dbarton
Dejected by Volvo
dbarton's Avatar
Negatory.
Dave
Old 05-24-2019, 11:03 AM   #49
Homer
OEMplus++
Homer's Avatar
Maybe could run the white block bolt in lower engine mounts I have and late 940 redblock upper mounts with the hydraulic cushions. Correct me if I'm wrong but the 960 whiteblock lower mounts are the same as the 940 redblock lowers?
-Jacob:
2006 A4 - Comfy DD
Old 05-24-2019, 12:40 PM   #50
dbarton
Dejected by Volvo
dbarton's Avatar
Originally Posted by Homer View Post
Thanks, Jacob,
There might be room on the passenger side for something larger, but the 240 driver side is seriously crowded with the steering rack, which is much closer to the engine than in a 700/900. I know you have a 240, but the only way I see for a mount on the driver side that takes more space or moves outboard with a tilted motor would be putting it up on the frame like my image in post #20.
I suppose if I wanted to make the motor upright I could find a place for a larger mount on the driver side. But I'm not going that route in the planned future.
Edit: Here's a pic from a 240 Green Book showing how crowded that driver side mount is. No room.
Dave
