Old 03-22-2019, 08:44 PM   #1
Cwazywazy
Single jingle
Cwazywazy's Avatar
Default I dragged home a white turd.
I'mma call it Whitey, because it broke my streak of buying blue cars. Bought for $675. Pretty crusty overall, you can tell it was kept outside, but the rockers and floorpans are 100% solid. 1988 244DL with legit 93k and an autotragic.
It had no spark, found the problem to be a crappy repair at the connector to the Chrysler box. Now it has spark at the plugs. Firing order is correct. Compression test showed an even 120psi. Still won't run on brake cleaner shot into the intake..
I don't know what I have
Cwazywazy is online now   Reply With Quote
Old 03-22-2019, 10:07 PM   #2
sbabbs
sbabbs's Avatar
Fuel pump working? I'd clean the fuses and the fuse holders. Check fuel pump relay. Usual turd stuff. Main 30 amp fuse to ECU connected to battery.
Old 03-22-2019, 10:39 PM   #3
Cwazywazy
Single jingle
Cwazywazy's Avatar
Found two things. One, the timing was waaaaay off. Like 30-40 deg after TDC. Two, the fuel pumps aren't running, even though they were earlier when I had no spark.
Old 03-23-2019, 01:51 PM   #4
Cwazywazy
Single jingle
Cwazywazy's Avatar
Popped in a spare fuel relay and eventually it sputtered into life. Has a pretty good miss at idle, runs fine under throttle. The top of the firewall is messed up for some reason.. Hood is gonna need some attention too.
Old 03-23-2019, 04:06 PM   #5
sbabbs
sbabbs's Avatar
Looks pretty solid for back east. Maybe when the put the new motor in it, it hit the firewall. Someone pushed in the cherry picker a little wee bit too hard and fast? Or dropped it too quick. A fresh piece of that foam board sound deadning stuff and you won't see the ding! Can't fix it, hide it!
Old 03-23-2019, 06:54 PM   #6
Cwazywazy
Single jingle
Cwazywazy's Avatar
Is that foam board still available anywhere? My '82 is the only 240 I've had with that thing fully intact. Still has the hood insulation too.
Old 03-29-2019, 09:48 PM   #7
Cwazywazy
Single jingle
Cwazywazy's Avatar
Got er reggo'd today. Still idles kinda rough but under throttle it runs like a stock 240 should. (Slow as hell) Trans shifts butter smooth through all 4 gears. Does need an alignment though, pulls right. I spent at least 2 hours just cleaning the interior today. Found a big mouse nest in the center of the dash and a little one in the left air vent. Has some issues, speedo doesn't work but it's not the speedo itself, temp gauge doesn't work and it is the temp gauge itself, and there's a nice loud clunking from the rear. Probably axle bushings. Also I put Virgos on it to make it, uh.. Snazzier. I like the white on black combo.
I've found that Rustoleum appliance paint is a pretty close match so I've also been getting the hood and fenders nice and flat for painting.
Also check out these buttcheeks.
Old 03-30-2019, 12:29 AM   #8
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
That pipe is kinda extra kinky too isnt it? It looks like it took a yump or two.
Old 03-30-2019, 01:23 PM   #9
Old Iron
I Roll
Old Iron's Avatar
Nice save. Wonder what this mileage is worth with a full stage 0 and apainthob! ��
Turbobricked
Old 04-04-2019, 11:36 AM   #10
Cwazywazy
Single jingle
Cwazywazy's Avatar
So I'm having some driveability issues. It's intermittently very hard to start, sometimes it fires right up. Still has a rough idle but before it ran fine under throttle and now it's surging at any throttle position between idle and wide open. Pretty much everything ignition related was replaced by the previous owner, and IIRC he changed the fuel pumps too. Hood came out decent tho.
Old 04-04-2019, 12:37 PM   #11
iHateVolvoPeople
Lord_Athlons daddy
Nice find. Just out of curiosity, how do you know the mileage is legitimate? Seems quite rough for <100k.
I have seen Chrysler ignition 240s idle like that, many of them kind of just idle crappy. It's hit or miss.
Check the fuel pressure regulator line for gas smell if it's hard to start when warm. Have you checked timing belt and made certain timing marks were spot on?
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
90' 745 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
99' Camry A140E. Admittedly the newest car Iíve ever owned.
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 04-04-2019, 12:48 PM   #12
Cwazywazy
Single jingle
Cwazywazy's Avatar
FPR is also shiny and new. The fact that it still goes WOT fine makes me think it's not fuel pressure.
When I got it the speedo didn't work because of a crappy connection in the wiring from the sensor to the trunk but I have no reason not to believe that it's under 100k. Trip meter wasn't at 0 so it may have just been from sitting. It doesn't even piston slap when cold.
According to the sticker the timing belt is about 50k and 25 years old. So I should probably do that, huh..
Old 04-04-2019, 01:52 PM   #13
iHateVolvoPeople
Lord_Athlons daddy
People often swap clusters instead of fixing the gear. Either way it doesnít really matter as long as youíre happy with the car.
Old 04-04-2019, 02:56 PM   #14
sbabbs
sbabbs's Avatar
Maybe the injector seals? Vacuum leak somewhere?
Yeah I use the rusty appliance white also. I just painted a serious wheel the other day with it. Now that is some nice shiny white paint!
Old 04-10-2019, 09:43 PM   #15
Cwazywazy
Single jingle
Cwazywazy's Avatar
Checked for vacuum leaks, found one, fixed it, no difference. Checked timing and it was bouncing around a little in line with the misfire. Tried my spare Chrysler box, no change, tried unplugging the knock sensor, no change, etc. Might try my spare distributor, I know the PO replaced the hall sensor. Also threw in an old Bosch o2 sensor I had, again with no change. It's had a crappy idle since I got it but the surging while driving only started happening after I registered it.. How do I check fuel pressure on an 88?
Old 04-11-2019, 01:01 PM   #16
iHateVolvoPeople
Lord_Athlons daddy
I'd still suspect the wiring at the chrysler box. Should go back a few inches and have a look.
Old 04-12-2019, 08:26 PM   #17
Cwazywazy
Single jingle
Cwazywazy's Avatar
Pulled these injectors out. I found some old ones that looked better, ran them through the ultrasonic cleaner, made a little injector clicker, and blasted carb cleaner through them. Put them on and the car barely ran. Then I realized they're turbo injectors so I cleaned the originals with the same process and the car's definitely happier now. It's still surging but the starting and idling improved. Might just be wishful thinking, but it feels a tiny bit faster too.
Old 04-15-2019, 05:14 PM   #18
Cwazywazy
Single jingle
Cwazywazy's Avatar
Changed the plugs even though they were basically new, good thing I did because the #3 plug had about zero gap. Still idled like garbage so I popped in a spare distributor. That was the golden ticket. It still doesn't idle perfect but it's about a million times better. Before it was so bad that I couldn't even brake smoothly at low speeds because the engine would make the car judder. Still has a little bit of hesitation accelerating which I'm betting a new MAF will eliminate.
It's now making a ticking noise at idle. Exhaust leak maybe?
Neat side note; after I shut it off there's a ticking noise as it cools down. My turbo wagon did the same thing before I gave it a new exhaust and apparently so did my grandpa's old 240, which he bought new.
Old 04-15-2019, 09:19 PM   #19
iHateVolvoPeople
Lord_Athlons daddy
Did you swap the whole distributor, or just the cap and rotor? Good find. A worn cap/rotor is giving my 93 wagon a bit of a hesitation and lumpy idle.
Old 04-15-2019, 10:12 PM   #20
Cwazywazy
Single jingle
Cwazywazy's Avatar
Whole thing, cap/rotor were new so I left those. Previous owner replaced the hall sensor in the distributor when he was trying to fix the no spark, I'm guessing he got something wrong or got a bad sensor. Maybe he set it too far away from the spinny bit?
Anyway, I now consider this car daily driveable. Just gotta take care of that slight hesitation/surge and it'll be running perfect.
Needs some more work on the exterior, some suspension work and alignment, then fix the AC, and then I should have myself a very nice cheap 240.
Old 05-12-2019, 01:30 PM   #21
Cwazywazy
Single jingle
Cwazywazy's Avatar
So I thought that ticking noise in the video above was a blown out manifold gasket. It did have two blown gaskets but that wasn't the tick. Valvetrain maybe? Doesn't really change at all with engine temp.
I ripped out the exhaust, welded up a hole in the header pipe, and threw on the exhaust from my diesel 240. No cat and homemade resonator delete. Got every manifold nut off without snapping or pulling a single stud. The best part is that it rolls coal cause of all the soot still in it. The cat was pretty clogged, I put a light behind it and I could barely see through.
I also cleaned the throttle body and IAC as well as replacing the ECT. Made absolutely no difference to ease of starting or idle quality.. If the car is stone cold it won't start at all unless I put my foot on the gas.
Old 05-24-2019, 04:17 PM   #22
Cwazywazy
Single jingle
Cwazywazy's Avatar
I counted 18 or 19 seconds to 60. Pretty sure it's supposed to be faster than that, IIRC my stock M46 wagon was about 14 seconds. Also note the not at all concerning clunk. Dunno what that is, looked over the rear suspension and it all appeared to be fine.
Old 05-25-2019, 03:18 AM   #23
nordmaschine
forced instruction
nordmaschine's Avatar
Maybe diff has some play?
Jetronic is romantic.
Whiteblocks
Old 05-25-2019, 03:42 PM   #24
iHateVolvoPeople
Lord_Athlons daddy
Itís probably mis timed.
Old 06-09-2019, 10:09 PM   #25
Cwazywazy
Single jingle
Cwazywazy's Avatar
Yeah, cam was off a tooth.
So.. I really feel like this car has been wrecked at some point. The front crossmember is red, not white. Plus that firewall. So I got a free Autocheck report by listing it on eBay and the odometer checks out but there are zero accidents on the report..
Here's the thing about that though, I got an Autocheck report for my 1988 245 a long time ago that also said 0 accidents, but the report I got from the insurance after the wreck had an accident from '99 listed on it. (Which explains why it came with the wrong bumper.) So I dunno.
EDIT: I daily drove this car for a couple weeks without touching a thing and it.. Just kept getting better. I mean, the idle was still crap because of the cam timing but even though I didn't do anything to it since I made the video above, except for fixing the AC, the 0-60 time went down to 15.0 seconds, and that was with the AC on. It also now fires right up every time.
